Results 1 to 45 of 45
Thread: Conti X King..
    Reputation: HillbillyTom's Avatar
    Sep 2012
    Conti X King..
    Anybody using the Continental X King tires? And what do you think of them?
    Salsa El Mariachi 29er
    Giant CFR Team Road Bike
    Kona Jake the Snake
    '03 Yz250
    '05 Ducati 749
    Reputation: zyzbot's Avatar
    I bought a pair several months ago and put them on my hardtail. Noticed an immediate improvement in handling. I'm very satisfied with them. My LBS guy says they sell more of that 29er tire than any other.
    Aug 2013
    I'm using it as a front tire on a SS hardtail and pretty happy with it. Good traction for the dry trails I ride and a fast roller. Price is also reasonable and readily available online and at lbs.
    Weaknesses: Sometimes takes time to seal the tire when going tubeless. Tire tends to wobble even on a completely true rim. Width is smaller than advertised.
    Sep 2012
    I'm riding mostly hard pack dirt with quite a bit of rocks and roots. Was looking at the Protection versions, and the choice is between the X King and the Mountain King II. Looking for a replacement for the standard Trail Kings that came on my bike. Those work good, just need some in the protection versions, but don't think Conti makes them anymore.
    Kona Jake the Snake
    '03 Yz250
    '05 Ducati 749
    Reputation: chrisgardner73's Avatar
    I ran X-King's for about 6 months, and had to pull them. We have a lot of loose stuff here on the Front Range (Colorado), and I found that this tire came up short with regards to maintaining control. Maybe it was just me, who knows. I've since switched to a 2.35 Maxxis IKON up front, 2.2 Maxxis IKON in the rear, and this setup seems to work really well.
    Sep 2012
    May go with the Mountain King II then. We do have some pea gravel and loose dirt stuff here and there, so better grip will likely offset a slight bit more rolling resistance. MKII was my original thought, but figured I see how the X King compared.
    Thanks for the advice!
    Kona Jake the Snake
    '03 Yz250
    '05 Ducati 749
    Reputation: Epic_Dude's Avatar
    May 2010
    Have a set, like them, will be buying them again.
    Sep 2012
    Quote Originally Posted by Epic_Dude View Post
    X King or Mtn King?
    Kona Jake the Snake
    '03 Yz250
    '05 Ducati 749
    Mar 2013
    I'm running the X-King Protection model in 29x2.2 and like others have said, it's narrower than advertised and harder to seal up tubeless. I've had them on for over a month now and I still drop to 20psi after a few days (I inflate to 32-35 before every ride). I think this is semi normal for tubeless but this is my first tubeless setup so I can't really compare.
    I came from the Bontrager XR1 that came on my Superfly and they aren't quite as fast of a roller, but the increased traction is well worth it.
    Feb 2013
    I have an x-king 2.2 on the rear tubeless, it 'wept' a bit through the sidewall but set up nicely and has been trouble free. I raced it last winter/spring in moist, dry, heavy rain/mud, roots etc, and in rougher conditions in the summer. I have no complaints, I found it to be 'confident' in all those conditions. I like this tire, but it is a bit narrow, measures 2.08 actual width.
    I went with a Specialized Ground Control 2.3 (also narrow) in the front, I like that tire too.
    Sep 2012
    Given the wide variety of trails that i ride, I went with the Mountain King Protection 2.2s. Have everything from hard pack dirt to creek bottom gravel, so after some thinking, traction seems like a better plan at the moment than low rolling resistance. As I gain fitness and get stronger, I'll try something a bit more speed oriented.
    Just mounted them up tonight, and so far they're much more cooperative than the OEM Trail Kings with tubeless sealing. Be heading to the trails in the morning for a ride test.
    Kona Jake the Snake
    '03 Yz250
    '05 Ducati 749
    1*14*29*2.1 & 1*1*29*2.4
    have an x king on the rear and it's OK...agree with a previous post on tyre wobble and usual bleeding. Feels soft compared to my old crossmark, but happy with it on the whole...am trying some MK1's I got for $15 as a rear, figured can't go too far wrong for the price.
    Reputation: JSumner13's Avatar
    I picked an X-king up from the shop about a year ago and mounted it up front. It aired up nicely (tubeless) but wobbled like crazy. I tried the tire on a different rim and got the same result. I brought it back and the shop gave me another one. The new tire wobbled just as bad; about .5in side to side. I unmounted it and threw it in my used tire pile where it still sits today! lol
    Reputation: 29ger's Avatar
    Jan 2011
    My go-to tire for balance of weight, grip, rolling resistance, fit onto Stan's rims, and cost is the X-king protection 2.4. I ride kind of hard for XC, and have ripped some knobs of the 2.2", but the 2.4 seem to have better knob support. Keep in mind that the 2.4 is really more like a 2.2, and the 2.2 is not much over 2.0. I've only had one puncture with X-king protection, but it was a stick or rock right near the bead. I don't think any tire has protection there, so they have fairly durable sidewalls. I've had too many tread punctures with Maxxis EXO tires, and way too many sidewall tears with non-sidewall protection tires, but by the time you get a Scwalbe with good rubber and sidewall protection, the cost $20-$30 more than the X-king.
    I bought some 29x2.4 X-Kings exactly a year ago. The shop I got them from either didn't have the 2.4s in protection or they didn't make them at the time, so I ended up with regular non-Black Chili's in 2.4. I could have gotten the 2.2s in Protection and Black Chili, but went with the 2.4 because I really wanted a 2.2 and the Continentals are so badly undersized. The 2.4s measured right around 2.2.
    Now to the point of my post. The tires were great until I hit a VERY small jump. When I came down, the front tire deformed throwing me to the ground. I broke both of my hands! Continental quickly replaced the tire, but it went straight to eBay and the Snake Skin Racing Ralphs are back on my bike and I'll never use Continental bike tires again.
    Quote Originally Posted by besnard View Post
    This is interesting to see. I run X-King 2.4 tires as well (set up tubeless), and they've worked out fine for my XC needs. When I went to spirit mtn in Duluth, MN (kind of a DH style trail, but nothing extreme), I came down off of one of the jumps and the front tire deformed or folded or something, and I enjoyed skidding across the ground for about 10 feet, fortunately I landed well and didn't get hurt. The tire burped a bunch of air, I could fill it and it held air, but it was so badly deformed with a wobble that it was hitting my fork. I simply bought a new one and have been running it since, but noticed a tendency for it to want to fold or lose support when a lot of force is applied to it, such as coming down from a jump or down and up through a ravine, seems a bit sketchy to me.
    I might try a different tire next season. Too bad, since I've been pretty happy with these tires in all other respects this season.
    Sep 2012
    Quote Originally Posted by Stormwalker View Post
    Where on the tire did it deform at? Sidewall, or did the whole tire warp? Given others commenting that the X Kings leak sealant through the sidewall a lot like my Trail kings did, I'm wondering if they just have weak sidewalls and are just lightly constructed for pure XC riding/racing more on the lines of the Race King.
    Kona Jake the Snake
    '03 Yz250
    '05 Ducati 749
    For you guys burping, can I ask what rims you were using? Cheers.
    Nov 2012
    Rolling resistance on the mountain king is significant. Makes a great front tire... Not so much for the rear.
    Reputation: EndoanaJones's Avatar
    Oct 2011
    I have an X-King 2.2 on rear for about 10 months. It rolls well. Good traction for me. It's skinny for a 2.2 tire. Weight is reasonable.
    Down side:
    Low volume. It does wobble a bit. I run tubeless and sidewalls are really weepy - I think they get worse over time - gotta keep the Stans juice in 'em or they'll lose 10-15 psi on an 1hr ride. I had Race Kings and they were weepy too. I don't know if all Continental tires have weepy side walls? I've had a Maxxis Ardent on the front for over a year and it hold air great - might lose 1 psi a week. Had a panaracer Rampage for while and it held air great too.
    Sep 2012
    Quote Originally Posted by EndoanaJones View Post
    Down side:
    Were they the Protection versions? Weepy sidewalls was the original problem that I had with my OEM, non Protection, Trail Kings. They did seal for the most part after a few rides, but then I ripped the sidewall out of one and it was a moot point.
    Got Mountain King Protections and they haven't oozed a drop of sealant, and took a week to loose 3-4psi. When I first mounted them on the Stan's rims, they didn't leak noticeably even with no sealant at all in them. Went ahead and put 3oz in each tire and have been good to go ever since.
    Kona Jake the Snake
    '03 Yz250
    '05 Ducati 749
    Oct 2011
    Quote Originally Posted by HillbillyTom View Post
    Were they the Protection versions? .......
    Yes - the X-King is a PROTECTION version. I don't think the older Race Kings were Protection versions. I honestly cant tell the difference in their 'weepiness'. Last week, after my X-King kept going flat, I sprayed the the sidewalls w/ soapy water and they foamed up like shaving cream! I put 2 oz of Stans in in the tire and rode it a 1/2 mile. The next morning the tire had lost little air. I like the tire, but Maxxis & Panaracer tire don't seem to weep. Maybe rear tire sidewalls take more abuse?
    Sep 2012
    That is strange alright. Glad I didn't get the X Kings now, I would have been really bummed if I had paid big $$ for them and had the same issues as with the Trail Kings.
    Kona Jake the Snake
    '03 Yz250
    '05 Ducati 749
    After 2 rides, the 2.4 X King is off the front wheel and the 2,4 Ardent is back on. It didn't take more than 1 or 2 high speed off camber descents to decide that.....
    Mar 2013
    Quote Originally Posted by Ray Raton View Post
    Give it another shot... My x-king took a couple rides to not be slippery. There must have been a coating that wore off.
    Quote Originally Posted by Alias530 View Post
    OK, I might do that. Another thing that was z bit disappointing about the tire is that in a 2.4, it looked a lot smaller than my Ardent in the same width. Uninflated, and rolled up, the tread looked pretty wide when I bought it. I'm just happy that I got them both on close-out. I got a 2.2 also.
    Tomorrow, I'm gonna go ahead and do a ride with the Ardent up front, and after I'll consider re-mounting the X-King.
    Mar 2013
    Quote Originally Posted by finch2 View Post
    They aint saying, crucial info I reckon. I just posted in another thread that I burped a 2.4 X King on a Mavic TN19 and broke my shoulder. I've known there's too much sidewall deflection with this combination and been waiting on frequency i25s.
    In hindsight I should have been running at least 5psi more than 25psi. All it took was the familiar clay these tires stick to like the proverbial and cornering a little later and harder than usual.
    both of my 29 xkings are warped. they had wobbles but the rear got even more screwed. when i rode off the side of a log ride by accident. the front was a downhill turn on hard pack claydirt to much grip. i think the bars got crossed up, sent me into a tree head first. pretty sure it was my ass hitting me in the back of the head that was the cause of the concussion. the worst was the dislocated pinky.
    the xking is a super grippy tire. i'm finally getting a 27.5 to replace a racing ralph. the ra ra just don't inspire the same confidence in the corner.
    Reputation: Niner_Boy's Avatar
    Sep 2012
    Having trouble with tubeless Xking 2.2. Set up a 2.4 in the front no problem with no leaks at all, but the 2.2 at the back loses all pressure in a matter of a hour. Tried using 3 scoops of Stan's with Crest rims- still no good.
    Anyone have any ideas on how to fix. Does anyone ever coat the inside of the tire with some kind of elastic paint, in an effort to seal the micro-pores?
    Any advice would be very welcome...having to run a tubed Nevegal on the rear at the moment. Sacrilege using tubes on a Crest! lol
    Current Stable: 2011 Niner EMD, 2011 Vassago Jabba
    Oct 2011
    I discovered a leak on my X-king 2.2 at the bead. I haven't been able to seal it with a new shot of Stans juice. That's never happened on any other tire. I put a Maxxis Ignitor on the rear with no leak. Hmmm....
    Sep 2012
    Deff not the bead leaking. It's the sidewalls. I'm not sure if it's a Protection or Black Chilli tire- I don't think it's either of those. I can tell you that it has the diagonal patter on the sidewall, and not a chequered pattern like I see online.
    The Original Suspect
    Reputation: HitmenOnlyInc's Avatar
    A couple of thoughts: I've been running Race King Protection in the rear tubeless with a X King 2.2 non-Protection and tubed (long story) on my 29er SS. Anyway, I like the Race King but it does lose more air than I have been used to on other tubeless set ups. Now the X King is another story. I have about 100 trail miles on the pair and I have to say not liking the X King. I don't feel confident with it in loose turns. In fact had a nice crash due to front tire wash out. It just doesn't seem to grip at all. Taking suggestions for front tires. This is my first experience with Conti tires. I bought them because I could get a great pro deal and from the suggestion of some other riders. I really wanted to run the X King 2.4 protection...(the tire I ordered...out of stock...asked for 2.2 instead and they sent wire bead).
    Anyone running the 2.4 X King Protection as a front tire and liking it??
    Sep 2012
    Quote Originally Posted by Niner_Boy View Post
    That sounds like the way my Trail Kings (non Protection) were. Extra Stan's sealant and just kept working with them and riding. Air them up, spin the wheels while holding the bike horizontal to seal the immediate leaks, then ride. After 3 or 4, 8 mile trail rides, they had pretty well sealed. Would take several days for them to go down. But then I cut the sidewall out of the rear on a rock and I took them off.
    Figure the X-Kings are the same way, take some doing, but they will seal eventually.
    Kona Jake the Snake
    '03 Yz250
    '05 Ducati 749
    Mar 2013
    Yeah that was my experience although I couldn't keep it from burping on the rear at any useful pressure. Still waiting on wider rims hoping they'll solve that.
    change is good
    Sep 2004
    Quote Originally Posted by gumby. View Post
    Good luck. Mine would burp and then pinch flat. XK and MK2 on ENVE AM rims.
    Sent from my iPhone using Tapatalk - now Free
    Mar 2013
    What sort of pressures were you running DrDon? I'm gonna have to try it if only to give me some idea where catastrophic failure might be up front.
    change is good
    Sep 2004
    Around 32 or 34 on the rear which is on the high side for me. I typically run a pressure that will give me the occasional rim strike. Many tires can tolerate that pressure tubeless but the Contis failed. I suspect I would have better luck with the higher volume, heavier, but slower TK.
    I have to chime in and agree with the sentiment on these tires. After waiting for a LONG time for the 29x2.4's to come out in Black Chili rubber, I was really disappointed in how they felt. I had the protection casing. They weren't supple in the least to me. I either had to have the pressure up to where they wouldn't conform well, or if I dropped the pressure lower, the sidewalls felt floppy/foldy.
    My front tire warped too. On something absolutely simple. Let out a loud shriek. It seems that the sidewall weave must have failed and the air pushed forcefully through the then un-reinforced rubber casing. That area became the bulge/warp. The tires were brand new. Took them right back off, got the warped one warrantied and they are now collecting dust.
    I had the original Racesports in 26x2.4 and they were awesome. Had high hopes that these would have been as good. They weren't. They aren't even as fat as the 26 version. The 29x2.2 were just ridiculously skinny. Disappointed with Conti right now.
    Stans Crests. And my tire didn't burp on the rim. The sidewall forcefully farted. Protection version.
    I wonder if there is any connection between the constant set-back of arrival date of the 29x2.4 Black Chili tires, and the seemingly apparent warping/deforming/wobbling issues that are being talked about in this thread? Those tires took a long time after they were slated to be available...to actually be available. And I recall speaking with a guy at Highway Two, just kindly asking when he thought they might be available, and the defensive attitude riddled response I got from him alludes to some stress over these tires in hindsight. Or maybe he was just having a bad day, but it did seem at the time like there was some pressure regarding those tires.
    Regardless, I used to rave about the X-kings and Conti. My love has definitely grown cold.
    Reputation: Swerny's Avatar
    I would try running it with a tube at higher pressure to get the tire shaped to the rim, then pull the tube and try the Stan's.
    I had to do that with 1 of my Schwalbe RaRa's.
    Mike
    Toronto, Canada
    2017 Trek Farley 9.6 with Lauf
    2017 Diamondback Haanjo Trail Carbon
    2016 Scott Solace 10 Disc
    Sep 2012
    Quote Originally Posted by Swerny View Post
    Thanks. I will give this a go, although I will say that because the tyre is so tight on the rim, I have already busted a couple of tubes in an effort to stretch the tyre as you suggest.
    Still think it's the micro-pores on the sidewall that is the issue, rather than tyre contact at the rim. Don't really wanna use 5 scoops of Stan's but I might have to lol
    Mar 2013
    You've gotta be doing something wrong. I'm using the X King and mounted them straightaway with a $20 floor pump and added sealant after the fact and it was my first time with tubeless.
    Sep 2012
    Sounds like beginner's luck to me. An online search will reveal that Conti's can be notoriously difficult to seal sometimes.
    Mar 2013
    Maybe... Could be the rims too. I'm using bontrager race lites with rim strips (not tape)
    So I got a good deal on a 2.2 X King protection as a rear and kept it on for about 5 months. Mounted easily tubeless with Stans on a Mavic UST rim. I found in soft/wet or dry smooth trails they gripped very well, but on the more rocky/rooty trails they seem to pop and slip off a lot of features. The profile is squared off on the edges and that may be part of that problem. They worked slightly better at very low air pressures, but still not as well as a Schwalbe Rocket Ron, which I've gone back to. So for me the tire may find it's way onto my hardtail/gravel grinder, but probably not my trail bike. I do like that the sidewalls seem beefy for such a light tire and that the bead is tubeless compatible.
  1. Stan's Flow 29 old vs new (EX) ?
    By keen in forum Wheels and Tires
    Last Post: 07-23-2013, 11:40 PM
  2. Replies: 1
    Last Post: 07-23-2013, 05:08 AM
  3. Stan's wheels ad
    By Mojo Maestro in forum General Discussion
    Last Post: 06-13-2013, 08:10 AM
  4. New Stan ZTR Hub vs. CK and I9
    By OriginalDonk in forum Wheels and Tires
    Last Post: 02-25-2011, 02:04 PM
  5. Stan got a new website
    By meltingfeather in forum Wheels and Tires
    Last Post: 02-24-2011, 01:19 PM
