Results 1 to 8 of 8
    Reputation: Midle Age Warrior's Avatar
    Nov 2006
    Chub Hub problems
    I was trying to change the bearings of my Chub hub to start a new build and I am end with this.
    I hit the axle with a hammer and one of the flanges came appart.
    It is glue together do you think is safe trying to glueing againg and if so what type of glue I must use.
    Thank guys in advance for any help
    In my workshop, dirty hands is a state of mind
    WHOA!
    That might work, but I would contact the hive/e13 or whatever name they are using right now just to see what they say.
    Reputation: Ryandurepo's Avatar
    Nov 2012
    you would have to align it correctly so that your spoke holes werent way out of line. i would contact manufacture for sure!
    awesome
    Reputation: dblspeed's Avatar
    Hey Midle Age Warrior was this the 15/20 thru front axle? If so could please share the bearings size and where you were able to source them?
    Thanks in advance
    1*14*29*2.1 & 1*1*29*2.4
    Good quality super glue would probably do it, but yes, don't try anything till you talk to them. You only want to do it once.
    Nov 2006
    hi dblspeed
    since I am not in the states the information about where I got them is not relevant but about the numbers I will check tomorrow and let you know, but for sure you could get them in any place that sales bearings they are not bicycle industrie specific design
    awesome
    Quote Originally Posted by Midle Age Warrior View Post
    hi dblspeed
    Hi Midle Age Warrior, I'm not in the US either, I'm in Europe. I found the original bearings here: http://www.silverfish-uk.com/Product...A-hubs-25x37x7 : Size should be 25x37x7, could you confirm that?
    Were you able to fix the hub btw? I will get a bearing press for sure!
    Cheers
    Hi all, I have the same hub and I need to change the bearings, but don't want to end up like the OP!
    Can anybody offer some advice, do you need a special tool\extractor for the bearings or even the axle? Would any shop bearing extractor do?
    The behive dedicated tools are extremely expensive for a one time bearing job, it's almost like buying a brand new wheel!
    @ Midle Age Warrior, were you able to fix your hub?
  1. AC Chub Hub repair??? (1995 vintage )
    By mcphoto in forum All Mountain
    Last Post: 04-25-2012, 04:27 PM
  2. Chub Hub
    By slip20 in forum Singlespeed
    Last Post: 04-13-2012, 07:54 PM
  3. The Hive Chub MTB wheelset
    By DFYFZX in forum 29er Bikes
    Last Post: 01-08-2012, 04:55 PM
  4. Semi-chub
    By Lord Humongous in forum Fat bikes
    Last Post: 07-01-2011, 07:10 PM
  5. Chub Hubs?
    By FROZENSS in forum Singlespeed
    Last Post: 04-27-2011, 08:28 PM
