Page 88 of 88 FirstFirst ... 38788485868788
Results 8,701 to 8,759 of 8759
  1. #8701
    mjw
    mjw is offline
    Feb 2007
    Quote Originally Posted by Lone Rager View Post
    On my Carbon fan rims, I couldn't see the angle until I put a close fitting drill into the nipple hole itself, then it was obvious. The clearance holes in the rim bed were all in line and did not reflect the angled nipple holes.
    At least they were inline. Nextie used to do offset rim's with spokes offset and then the holes on the other side centerline. Took quite a bit of explaining for them to change it.
    • 2015 Kona Explosif Ti
    • 2015 Kona Process 111
    • 2018 Canfield Riot
  2. #8702
    Reputation: Lone Rager's Avatar
    Dec 2013
    The Carbon Fan rims I got were also offset. The holes in the rim bed were appropriately offset too, just not staggered to reflect the nipple hole angles, as they would be if drilled in a single operation with the nipple holes, which, I believe, is the typical method. I figured they drilled the rim bed holes first and then followed up doing the angled nipple hole and seats.
    Do the math.
  3. #8703
    Nov 2017
    For those looking for a bargain, BTLOS has a 15% off coupon (IND15)for the next couple of days.
  4. #8704
    Jun 2016
    Quote Originally Posted by wayold View Post
    Total cost with that coupon works out the same as Yishun, EIE, and a number of other makes.
  5. #8705
    Quote Originally Posted by alexdi View Post
    You're looking at the premium series which has a 3.5 year warranty vs 1 year for EIE.
  6. #8706
    mjw
    mjw is offline
    Feb 2007
    Quote Originally Posted by givemefive View Post
    The BTLOS rims are great. I've been absolutely flogging my 36mm Premium rims, jumps, large drops, rocks and roots, and they haven't wavered. I've also laced a set for a guy who rides fast/hard on a small travel bike, and is 270lbs with gear. He has so far managed to absoluely destroy a dt350 rear hub, but the wheels were still perfectly true. Relaxed the wheel for him, good to go. He has had them since February.
    Lily at BTLOS is pretty great to deal with, they provide excellent support. Which is why I use them when people want more affordable carbon wheel builds.
  7. #8707
    Can someone explain how they make a smooth bed rim? When a nipple cracks how do I replace it. I used to almost always get heavy Mavic 819, 821, 823 etc because I loved the smooth bed and they were bombproof. I still had nipples crack eventually and they were easy to replace. I suppose someone could slide nipple into valve stem hole and use a vacuum. Seems a big pain though.
  8. #8708
    Jan 2009
    Quote Originally Posted by sxotty View Post
    Screw a cut spoke end into zee nipple use a magnet to fish it thru. One can also use string to make it go faster. There are spoke end products with bigger ends, better for magnet use as well.
  9. #8709
    damned rocks...
    Reputation: Aglo's Avatar
    Dec 2014
    ^that.
    It take some extra time to lace a wheel, but once you get the hang of it, you will be doing it while seeing TV or talking to your friends with no problem.
    I use a magnet and a small screw.
  10. #8710
    Barely in control
    Reputation: Schulze's Avatar
    Feb 2007
    The fun with spoke hole angle really starts when you are building a rear wheel and you want your drive side elbow out spokes to be trailing, your hub logo to line up with the valve core, and the valve core between parallel spokes.
  11. #8711
    Dec 2017
    I just want to give cred to EIE. I have i34 AM wheels. They are super heavy duty. I broke a rim and got a crash replacement even though the damage was not any manufacturing error just a very unfortunate accident. If I ordered today I would easily have picked a superlight i30.5 rim with lighter spokes and hubs, but I was a bit concerned they would not be strong enough.
  12. #8712
    Reputation: OregonXC's Avatar
    I won't do business with nextie anymore. Have purchased several rims from them no problem. One set developed cracks at the rim holes in several places on both rims. ~100 Kgf tension (i have pics). Contacted them - they said ok. Ordered replacements - need for a trip. A few days later the person that said ok to the replacement was out of the picture (Sophie). Replaced by someone calling themself (Brian). He paypal'd a refund of $85 for rims that were about $275 or so. Shady. never responded again
  13. #8713
    mjw
    mjw is offline
    Feb 2007
    Quote Originally Posted by OregonXC View Post
    I didn't get a good vibe from Nextie.
    BTLOS has been by far the best of the lot for me, and I have tried a bunch. Amazing service, and quality as good as anything with a big brand name.
    I've started building with nipple washers also, after some discussion with one very experienced builder after some nipple bed/spoke hole deformation at 110kgf on some very expensive brand name carbon rims. Carbon rims are the weakest at the spoke hole, and it makes sense eotnme to use a washer. Might be worth considering on your next set?
  14. #8714
    Jun 2016
    I want to spotlight a couple of new rims from EIE:
    https://www.eiecarbon.com/A29C23D19S...ompatible.html
    23.5 / 30.5 / 300g
    https://www.eiecarbon.com/A29C25D25S...ompatible.html
    25.5 / 33.5 / 340g
    https://www.eiecarbon.com/A29C30D28S...ompatible.html
    30.5 / 38.5 / 360g
    I *really* like this rim profile. Thick, blunted bead walls for better impact and pinch-flat resistance, asymmetric, and relatively low-profile to keep the weight down. It's similar (and IMO, superior) to Enve's new design. I've linked the ultralight layups, though they've also got a standard XC layup that's 20g heavier and $40 less per rim.
    I'm tempted to build a new wheelset just to give them a go, it's been all grins for over a thousand miles on my existing set.
  15. #8715
    30.5 is not wide enough inner for 2.35 or 2.6 29 tires I ride from Bontrager. I would need 35 and 40 inner.
    But I like the profile and weight.
  16. #8716
    Barely in control
    Feb 2007
    For 165 to 205 a rim, I'd give eie a try. They aren't trying to charge me $15 more per rim to have no decal like Carbonfan, which is nice.
    So far I've built up 3 wheelsets on the Nextie sale rims for $250 a set and haven't had any problems. How far can I go rolling the dice like this? It's fun.
  17. #8717
    Jun 2016
    Quote Originally Posted by eb1888 View Post
    I think 30.5 is enough for 2.35. Ideal, even, IME. But check back later if you disagree; the 30.5 wasn't listed a month ago, they may well have a wider version of same in the pipeline.
  18. #8718
    Dec 2017
    I would run my 2.6 on i30.5. I think it is perfect. Both Enve and Maxxis recommend i30-35 for 2.5 WT and 2.6.
  19. #8719
    Jun 2016
    Quote Originally Posted by H-akka View Post
    Bontrager's 2.35 is a special case. It's an oversized Goma-class tire closer to 2.5". There's an argument for running that one up to i35, though it's hardly underperforming at i30.
  20. #8720
    Dec 2017
    Ok, I didn't know about that one. I run 2.5 DHF and 2.6 Rekon on i34. I think they work just fine with anything 29-35. I have tried both on my alu i29 and it no problem, tho i30.5 is probably better.
  21. #8721
    May 2017
    I have been using a wheelset I bought from EIE and have nothing but positive things to say so far.
    Rims:A29C30D28 AM,UD,Matte,32H,NO decals 2PCS
    HubsT Swiss 350S BOOST(Front:15*110mm,Rear:12*148mm) ,SRAM XX1,6-bolt
    Spokes:black,DT Swiss Competition
    Nipple:Black Brass
    That was what I ordered, they arrived safely boxed up in a few weeks. I taped them up and have a DHF EXO 2.5 front and a Chunky Monkey 2.4 on the rear with cushcore. Tyres went on easy enough (even with the cushcore), inflated first time and I've been running about 20psi front and rear with zero issues. I put them straight onto my new bike and have never run carbon wheels before. This bike is also coil front and rear and is pretty incredible anyway so until I go back to the oem alloy DT Swiss wheels I guess I can't really comment on how good or bad the wheels are in use.
  22. #8722
    Bontragers are designed for wide rims by Frank Stacy Testing. They'll give the best performance on wider rims at low psi, but you can run them on skinnier rims by adding some pressure and giving up some of the bigger footprint you would get. If you're building a new wheelset of course go for the size that gives you the most performance. The XRs have flexible sidewalls and light weight. So not for high speed runs through sidewall cutting shale. But a good tire on the right terrain.
  23. #8723
    I'm running XR4 2.4 and XR3 2.3 on 27mm inner and it's just fine.
    Also ran them 29mm inner, also fine.
    Tallboy 3.1
    OG Ripley v2
  24. #8724
    Hi
    Is there someone who have some experience with the XC rim (XM930) from Carbonal ?? I think both in terms of the rim itself and the service when ordering.
  25. #8725
    Reputation: Fat29Tire's Avatar
    Advice for a 650B plus build from BTLOS?
    First thanks to all the posters for the education and experience with the different companies, very valuable for a newbie to China carbon build.
    I have a Specialized Stumpy FSR 6fattie and i toasted the crap Roval/DT rear hub so that's what brought me here.
    I weight 190+ and ride New England roots rocks raggae in a cross country style, very few drops or hits.
    The Rovals were only i28 and I was riding 3.0" nobby nics.
    I am considering an i35-i40 (if they have) laced to a DT350 with ratchet upgrade.
    I haven't a clue on assymetrical vs inline construction so could use some pointers there (didn't find a good explanation yet but there's sort of a few posts to look thru)
    For bomb-proofing was going to go with 32h on rear and brass nipples, need help with spoke recommends as I've popped about 10 on that Roval wheel I'm trashing.
    Also not married to the DT350 but need boost, iso and sram XD features.
    Thank you wheel experts for taking the time to reply to me.
    Steve from NH
    Update, here is what I have selected from their website so far
    Premium WM-i34, 32h, 650b, AM version?, matte, 3k weave
    DT350 w/36t ratchet upgrade RED SRAM XD 6bolt iso
    Sapim Race spokes, j-bend
    Red decals
    Tear me up!
  26. #8726
    Jul 2016
    Quote Originally Posted by Fat29Tire View Post
    Steve from NH
    Red decals
    Tear me up!
    Go with XM carbonspeed. I had Peter from their build me a wheelset a few months back and they are VERY good. They are also a lot cheaper than the other good ones. Search this thread for others who have reviewed XM Carbonspeed and Peter. All good.
    I would recommend this wheel with the DT 350: 27.5er AM mtb bike wheels carbon clincher
    Spring for the 54t ratchet upgrade. It is way better than the 36t.
  27. #8727
    May 2017
    Heya Fat29Tire, I have a pair of BTLOS I34 DH rims laced to Chris King iso hubs using dt swiss competition 2.0-1.8 double butted spokes. I use brass nipples from dt swiss to prevent corrosion giving a longer life. The wheels are bomb proof and relatively light. The surface is perfect and looks really good. My rim is 34 internal, 40 external and 31.5 deep. I got the DH spec with the premium option. The people from BTLOS helped me tons in choosing the right rim for my riding style. I am 160 lbs and I have these wheels on a 160mm banshee rune. Love them and I would definatley buy from BTLOS again due to their amazing customer service and their dedication to help me. I am not running plus tires though, I am running maxxis 2.5 wide trail, ask the people at BTLOS what kind of rim would be perfect for you. Good Luck!
  28. #8728
    May 2017
    Fat29Tire, after some research I have found these two wheel options from BTLOS for you. The WM-I39A is asymetric with 39mm inner
    https://btlos.com/mountain-bike/asym...-bike-wheelset
    I also found out that the rims I use, the i34s are also great for plus bikes, altho these are not asym
    https://btlos.com/mountain-bike/34mm...arbon-wheelset
    For your weight, Sapim race sound good because they are bombproof altho a bit heavier than the D lights. for the engagement question, unless it is too expensive, go with the 54t it makes a huge difference and you would tottally love the close to instant engagement.
  29. #8729
    Dec 2017
    I have the same bike and run 29:ers with 2.6 now. Much nicer imo. But that's perhaps not what you want to hear. I went with EIE and i34. If you want to run Purgatory/Butcher 3.0 I'd go with at least i34 assym. Perhaps these http://www.eiecarbon.com/carbon-rim-mountain-bike/--650B--PLUS
  30. #8730
    Thank you H-akka.
    What do you find nicer about 2.5 29?
    Why assym geometry, what is advantage?
  31. #8731
    I like turtles
    Reputation: TiGeo's Avatar
    Assym allows the drive and non-drive spokes to have a similar angle improving strength. I run assym on 3 sets of carbon wheels...it's just a better design.
    Sent from my SM-G950U using Tapatalk
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro AF
  32. #8732
    Quote Originally Posted by xyzwheels View Post
    FREE SHIPPING 26 / 27.5" / 29 MTB CARBON 6 SPOKE WHEEL SET, ONLY 999USD PER PAIR NOW. If you interesting in carbon fiber bike rim & wheels, welcome to leave a message, hope we can give you a best products.
    #xyz #xyzwheels ##xyzcarbontechnology #customwheels #cyclingworld
    Hey XYZ, this is not a place for your advertising. Companies pay for advertising you see in the columns to the left. Surprised you are not yet banned.
  33. #8733
    Nov 2017
    So, how do folks here choose their wheel/rim source? In this thread there have been mostly favorable reviews of Light Bicycle, CarbonFan, XMCarbonspeed, BTLOS and several others. There are some differences in rim profiles offered and the newer brands seem to offer a bit lower prices. Are these the main bases of everyone's choice or, if not, what other factors do you use?
  34. #8734
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    I look to see what other people have had positive experiences with and what seems to be the most legitimate/going to be around for a few years-company. Nextie and Light Bicycle are probably the two biggest right now. There are a bunch of others though that also make a decent product. Oxive gave me a set of rims to test out and they worked beautifully for their intended purpose this race season. They are definitely legitimate and want to put out a good product. T800 is a bit better than T700 layups, but T700 is usually more cost-effective. You choose the internal width that suits you best. If you are using older 142 hubs then asymmetrical rims may be something to look into as well.
  35. #8735
    May 2017
    Here are my BTLOS 34mm rims on king hubs, Banshee Rune 2018. Love the rims! I laced them myself and it was a pleasure.
  36. #8736
    Reputation: dirtyjack's Avatar
    Quote Originally Posted by dirtyjack View Post
    Since I don't see too many long-term reviews, I thought I would post an update on my experience with Light Bicycle rims.
    After almost 3 years or abusing these wheels, I've probably replaced 2 or 3 spokes on the rear wheel, and can't honestly remember having to true them other than when replacing spokes. My shop owner was on the fence about using the CX-Ray's, he thought they might be too stiff, but I'm happy with that choice. The rims are sporting lots of external scratches, but no signs of stress or cracks anywhere. I only wish I had gone directly to a 30mm internal width rim rather than the 25's, but other than that I've been very pleased with the rims and the wheels that my LBS built up.
    I'm 170lb and not a huckster, but I do love pounding through the chunk on my Tallboy.
    Now 5 years in with my Light-Bicycle carbon rims, I've rebuilt the rear wheel with Force after snapping one too many CX-ray's. The front wheel is still the original build. Both rims are still intact, despite the pounding they've taken.
    Still a happy customer!
    SantaCruz Tallboy C
    SantaCruz Solo C
    Specialized Fatboy
    Trek Madone 8
    Kestrel RT 700
    Lemond Zurich
  37. #8737
    Reputation: OwenM's Avatar
    Oct 2012
    30.5 / 38.5 / 360g
    Since my rims don't lead a hard life(rough terrain, but no jumps or drops >2ft, no rim strikes, and no damage to my al wheels), I'm semi-interested in their T800 blend in this or the 35mm/i29 rim. At least for the front.
    Having no experience with carbon rims, I'm not sure how much rim I actually need, though. I'm wary of putting too much emphasis on weight, and going "stupid light" over 40g per rim.
    They're so close together...what I'd really like to know is how these 360g T800 mix rims stack up with the 380g XC and 400g AM versions. Or, perhaps more importantly, with al rims like my Flow Mk3 front/ Arch Mk3 rear, which are perfectly adequate for my needs, but significantly heavier at ~990g for the combo.
    Right now, I'm leaning toward the 40mm/i34 for the front and 35mm/i29 rear, which would make this a moot point for me, but I'm still curious.
  38. #8738
    Dec 2017
    Quote Originally Posted by OwenM View Post
    I have EIE i34 AM 32/32 and the are super heavy duty. I would say you would't need that for your riding. Unless you are going to run 2.8 or more front I would go i29 28/28 or 30.5 28/28.
  39. #8739
    Apr 2014
    Lat time I did carbon wheels, I ordered the rims, spokes and hub separately. I was concerned about having the factory in China build my wheels with a sight-unseen hub. Frankly, when it comes to things like hubs and china, I'm too worried about fake stuff.
    Is this an unfounded concern?
  40. #8740
    Reputation: sissypants's Avatar
    Sep 2016
    Quote Originally Posted by McGG View Post
    Other people can correct me if they want, but this is my opinion. Chinese companies that sell lots of wheels and are discussed on these forums are generally as trusty as your LBS. If it's a DT 350 hub, it's authentic. I have several wheelsets built up by Chinese sellers with DT Swiss hubs, Pillar spokes, and house-brand carbon rims and they are all great. No bad experiences yet!
    Stay away from Novatec and Powerway if you want your wheel to last a long time. These hubs are cheap, but I've broken every pair I owned. Where it gets interesting is when these companies come up with their own hubs (i.e. Speedsafe hubs) and you don't really know what's inside. Koozer hubs are another example, basically a knock-off of Hope with half of the technology, and they happen to break more easily. The same factory that makes Koozer (ECC Tech), however, also makes some great hubs, and you just don't know who slapped their logo on last (Salsa "Brickhouse" and HED come to mind)
  41. #8741
    Apr 2014
    Okay guys, I'm trying to decide between two wheels:
    1. The new AM930 from LB
    and
    2. The XY series, T800 from CarbonFan
    The Carbonfans are about $100 cheaper per rim than the LBs.
    I weigh about 230lbs without gear (yikes!), so I'm leaning towards the Carbonfan ones.
    My LBS is going to lace the wheels for me to Onyx hubs.
  42. #8742
    Reputation: CrozCountry's Avatar
    Mar 2011
    and
    I don't know much about those specific rims, but assymetric is a big selling point, especially if you are stressing the wheels a lot. Also since the AM version of XY is only 20g more than XC, definitely go with that if you buy XY
  43. #8743
    Reputation: IPA Rider's Avatar
    I didn't get responses over on Wheels & Tires BTLOS thread...so here it is again...
    I can't find any BTLOS rims that match the lighter weights of those from Nextie (their ultralights, which use T1000) (note the 34mm is external):
    https://www.nextie.net/ultralight-mo...34mm-NXT29UL34
    or these from eie carbon:
    super light 29er 34mm wide MTB hookless tubeless compatible carbon rims
    or these from Carbonfan...
    https://www.carbonfan.com/t800-tubel...28mm-33mm-35mm
    I'm looking for i25-i30 (I think 27-28mm would be ideal) that are at most 360g for i30, and less than that for narrower rims. Am I missing something from BTLOS???
    Riding: '91 Carbon Epic Stumpjumper w/1" Slicks and a Rack on the Back
  44. #8744
    Sep 2016
    Just wanted to pitch in my experience with the cheapest set of carbon 29er rims available online right now:
    https://www.aliexpress.com/item/2Pcs...318352290.html
    It's $182 USD incl. shipping for me in the United States for a pair of these. I got them on an Aliexpress sale almost 6 months ago for $160, I expect Christmas sales to lower the price as well. They weigh 425g each. I had Velocity USA build up a pair and have about 600 miles on my gravel bike so far. I've done about 50 miles of singletrack as well which wasn't easy on them considering the Maxxis Rambler 700x38Cs I'm running and my brutal riding style. They took a lot of knocks.
    They have handled everything very well, I did have to true the rear wheel after about 400 miles. I get a sense that the rims are bit stiffer than the ultralight Speedsafe rims I also have, but I like them and for the price they have been excellent. I also had two instances where sharp rocks gouged into my tire sidewalls, letting out a bunch of air, but in both cases the tires sealed up again, thanks in part to the tall sidewalls on these rims.
    I have another set of these rims I'll be building up. The deal was too good at the time not to buy two sets.
    I haven't taken pics of just the wheelset, but bike pics are here: ICAN GRA02 Gravel Bike Frame - The Riding Gravel Forum
  45. #8745
    Sep 2016
    and
    Wow buddy I don't know how you're built but sounds like you need to shred some trails long and hard and leave some stuff out there! If I were you I'd stay with stiff carbon fiber (T700). IMHO LightBicycle is overpriced. The only time I'd use them is when they have something nobody else has (i.e. 27.5er fat 75mm carbon rims). Their quality really isn't much better than anybody else--there's lots of people who have had issues, even though it may not happen that often. They are better at marketing and have built a more robust brand identity, hence the bigger markup.
    I'd do the Carbonfans. If you're sold on Onyx hubs that's the best way to go, but sometimes you can save a bit by getting the build done in China just because their labor rates are super low and they often let you in on dealer pricing for the hubs.
  46. #8746
    Apr 2014
    Quote Originally Posted by sissypants View Post
    indeed...I should probably be walking around at about 205-2010.
    I like pastries.
    I think I'll get the CarbonFan ones, but with WWC and other discount parts places, I can get hubs for a reasonable deal, and then get LBS to lace them up. Just looking at pricing of built chinese vs just rims, it doesn't seem like they give you much of a deal on labor or hubs.
  47. #8747
    Sep 2016
    I like pastries.
    You can reach out to individual suppliers on Aliexpress and ask to do it by PayPal via email. They will usually knock 10% because they don't have to pay seller fees. The difference isn't huge though. You've gotta go with low-margin suppliers though like Elite, Speedsafe, or a company like XMCarbonSpeed, Hongfu, etc. I do support local brick-and-mortar when I can't get a good deal out of china though.
  48. #8748
    Nov 2017
    Is anyone using rims with t800 for anything more than xc racing?
  49. #8749
    Sep 2016
    Quote Originally Posted by n1cholasj View Post
    I use T800 rims for everything. Why not?
    Have your own opinion, but don't be opinionated because you've been brainwashed by marketing propaganda.
  50. #8750
    Nov 2017
    All the companies list them for XC use. Im a 200lb dude - Trying to avoid under rimming myself
  51. #8751
    Sep 2016
    Just to set the record straight, the tensile strength of T800 fiber is more than 10% greater than T700, the strength under compression is a little greater than T700, it's lighter, and it has a faster return response reaction. It's more expensive, but it's kind of a standard in the high-end chiner rim market.
    At 200 lbs I don't think you'd need to worry too much about under-rimming yourself--just don't get the lightest rims out there. Try to go about 350 grams or heavier for a 29er rim. I recommend buying from manufacturers that use monocoque layup, like Light Bicycle or Speedsafe (on aliexpress). These will be much stronger than rims with two or three seams.
    The real-world difference between T700 vs. T800 is so nuanced you'd never know the difference on the trail when double-blinded, maybe unless you're a Pinkbike reviewer.
    Edit: A few posts back I recommended someone who was really heavy to stay with T700 carbon fiber. That's not because I thought it was a better material, but because these wheels generally have many more layers of carbon fiber and are not inspired to satisfy the weight weenie populace. They are also slightly cheaper.
  52. #8752
    Nov 2017
    https://www.oxivecarbon.com/products...=5692939927579
    Im thinking of this for the rear and the i30 for the front. About 400 shipped for the pair, both sub 400g. Theyd get used for xc-trail and occasional enduro trails. Maybe some enduro racing? Maybe Im expexting too much out of these.
  53. #8753
    Jan 2009
    T800 isn't necessarily better though it is slightly stronger and lighter but it is more brittle and more susceptible to abrasion. T800 fibers are thinner than T700. And within each grade their are grades within the group and frankly we don't know what they are using, but then again the percentages between each are small. The gain from T700 to T800 is 10% roughly, but the loss of abrasion resistance and more brittleness... hmm not sure what the equitable balance for each individual is.
    Those are for weight weenies. I'd rather go for their wider asym rims around 420grams personally for the width and heft. And your not exactly a lightweight right?
  54. #8754
    Jan 2009
    Also, I should mention that the Oxive rims can be annoying as hell if you prefer to build wheels with a wrench from the rim bed versus spoke side. I prefer building wheels that way. The Oxive rims are not drilled asymmetrically in regards to the rim bed holes. I'll be honest, it really pissed me off because I often use straight pull spokes. If you use straight pull spokes, you would use a spoke holder to stop the spoke from spinning when adding tension. And when you are forced to add tension on the spoke side, the holder cannot grab the spoke closest to the nipple. AND then you are forced to grab the spoke on the butted section which sort of reduces your ability to stop the binding. Its aggravating as F!
    Below you can see the rim bed hole doesn't line up. I emailed them to show them this and ask wtf were they thinking? They replied a couple times but Chinese is a big road block to explaining things and after two emails they stopped responding lol.
    I managed to build my set up, it just took longer. The rims are decent, I'm just not sure I'd do it over again but Oxive's pricing is very good so maybe.
  55. #8755
    Barely in control
    Feb 2007
    So far I've seen no reason to prefer Oxive or LB over Carbonfan. The photos Jayem posted of his rims make them look cheaply made, similar to a set of $235/pr promotion Nexties I have. I have two sets of Carbonfan and they look great. 18 months of riding on one set and no problems.
  56. #8756
    Well, those are more substantial than the 290g Oxive XC racing rims I have! At 28mm, they are fine for XC racing and I did most of the racing season here on them. As light rims get wider though, they do get more exposed. I ride carbon rims everywhere, no qualms riding them on full DH rides that I do, park days, etc., but IF I lived back in Arizona and IF I did South Mountain frequently, I might think twice, just because you get damage from things like ricocheting boulders and things sticking out into the trail. In most places, that's not anywhere near as big of a concern. Just based on your description of what you want to do with them, I wouldn't be looking for any "ultra-light" rims. I'd just be looking at the normal layup rims. The T800 and ultra-lights should have thinner sides and while outright strength may be the same or even more, impact resistance due to a rock when your pressure is too low may be less.
    Those 380g Oxive's aren't really all that light though. Most of the carbon rim manufacturers are offering something around 30mm and 400g or less these days as their "normal use" rims. My old standbys are 30mm 29er nexties that have been beaten to hell and back and still work great every day. They were 400g if I recall correctly.
    My much wider and beefier Nextie 35s on my AM bike are 50g heavier.
    I have LB, Nextie and Oxive. I can't tell any difference in how they were made or laid up, they all work great on the bike. I'm in favor of the in-line spoke holes to get them off the shoulder of the tire-channel, I don't build with straight-pull spokes though.
  57. #8757
    Nov 2017
    Cool, thanks for the response. I'm also looking at carbonfan HM series, (https://www.carbonfan.com/carbon-hoo...32mm-35mm-42mm). Probably the i26 or i29 rims, maybe narrower in rear wider up front. I'm curious if these use t800 as well. Everything else I am seeing in similar dimensions clocks in the 440-465g/rim mark.
    The vast majority of my riding is in WA/PNW for what its worth.
  58. #8758
    Jan 2009
    Dude, read the specs.
    Rim Material: full carbon Toray T700
  59. #8759
    Nov 2017
    Quote Originally Posted by thesmokingman View Post
    Whoops. Thanks for taking up the slack for me!
Members who have read this thread: 711
