Page 32 of 86 FirstFirst ... 222829303132333435364282 ... LastLast
Results 3,101 to 3,200 of 8526
  1. #3101
    Quote Originally Posted by Pau11y View Post
    Remember I built a set of "heavier" AM Nancy rims... I'm gonna build a 2nd set soon, a lighter/standard set. But I won't even compromise the security of those Bonty strips for the weight of yellow tape...and I'm sitting on 2 rolls of the stuff.
    Did you notice a certain way you had to run the strips for them to work with the Nancy AM rims? Was there a "left and right" side that had to be put on correctly or can you just install them anyway and they will work.
  2. #3102
    im running 1" gorilla tape, I have my drive side spokes at 120kgf, I use a compressor to set the bead.
  3. #3103
    4 Niners
    Dec 2008
    simpy16: all parts are symmetrical. You can run the rim strip either direction.
    Full rigid SS, Hardtail SS, Hardtail Geared, Full Suspension Geared.
  4. #3104
    Sep 2012
    Quote Originally Posted by pimpbot View Post
    I'm almost convinced. I think I'm gonna pony up for the other Bontrager rim strip and do my rear rim. I did it with yellow tape, but the tire kept burping and rolling off. so I've been running a tube back there for the last six months.
    I hope you're kidding. 40 psi is really frickin high, especially for 29er tires, especially for tubeless. I'm 210# and I run 28 psi on my skinniest tires, a 2.0. I usually run 25 psi on my 2.3s.
    good to know, I was actually referring to the maximum stated in Stan's instructions. But yeah there's a chance I'd be trying to get near it and painted my room with latex as the result
    Regarding rim strips, I'm hoping the Stan's 29er standard will be fine, as it covers the rim from side to side, actually had to push it under the clinchers at some places.
  5. #3105
    Quote Originally Posted by simpy16 View Post
    Well...get them under the rim's bead seat, obviously. Other than that, just make sure you get the strips for the symmetrical rims.
  6. #3106
    Reputation: DRILLINDK's Avatar
    Mar 2012
    Getting ready to order a pair for a build. I havne't been following the thread for the last couple of months. What's everyone using to run tubeless?
    Stans tape?
    Bontrager rim strips?
    Gorilla Tape?
    TIA!
  7. #3107
    4 Niners
    Dec 2008
    Bontrager Rythm Symetric Rim strips.
  8. #3108
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    Quote Originally Posted by yourdaguy View Post
    same here
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
  9. #3109
    Bontrager rim strips here as well.
    I finally figured out why my Nevegals wouldn't seal up. It was the Bontrager valve stems, not the tires. Swapped them out for some Stans valves and they haven't lost a pound of air since.
  10. #3110
    Stans Yellow / Gorilla Tape
    Never burped or lost air - seated fine with a floor pump.
  11. #3111
    Sep 2012
    Whoa so I did my first tubeless today.. Stan's rim strips and sealant, rim tape which came with the rims, and instead of soapy water the Easy Fit from Schwalbe (which I suspect has made my noob experience many times better).
    I was getting desperate as it wasn't inflating even with a compressor and a removed valve, but then I learned how to do it - stretch the tire where the valve is so that the beads touch the rim sides (2 hands needed), then to free one hand, in that same place push the top side of the tire down closer to rim so that it stays seated (at that place anyway) - and then pump it with the other hand. That did it. Pumped both tires to 35psi, the pressure is stable, but only did a very small ride today, will test more soon.
  12. #3112
    May 2010
    Just finished building my first set of wheels using the wide Nancy 29'er rims with Superstar Tesla Hubs, DT revolution spokes and Bonty rim strips. Weight ended on 1650g.
    Have a question regarding the build: The wheels are laterally true, dish is ok, tension is around 19 (133 kgf) on the Park tool tensionmeter for the drive side/disc side front, and around 15 on the other side (88 kgf). The tension is also fairly equal all around.
    I only have a litte concern about the radial trueness. There is no high or low "spots" but on both the front and rear wheel there is a rather long section (about half the rim) which is a little lower. (Around 1 mm maybe). Could this be due to the manufacturing not being 100%, or can this happen because of not building it correct? This is as said my first build, and therefore I'm not sure.
  13. #3113
    Mar 2012
    How do these rims compare to Stans crest rims as far as width and weight. Do they ride better for all Mt use?
  14. #3114
    Quote Originally Posted by Bhorium View Post
    It's the build. You likely added tension too quickly. As you add tension, if you tighten the nipples too much at once you will squeeze a hump into the rim.
  15. #3115
    4 Niners
    Dec 2008
    Bhorium I just built my 3rd front yesterday. It is the way you built them. As I was starting to get tension in the wheel I had the same problem. Most of the spokes were at around 10 one side and 5 other side. It was the most lumpy rim ever or so it appeared (not really since I bought 2 rims and they layed up against each other very flat and true-this is how I know it was not a manufacturing problem).So then I kept tightening spokes in the high areas until it is all the same. Then I go back to truing the wheel left right and dish periodically checking the height. I ended up with one of the truest wheels I have ever built and around 20 on the Park guage on one side and around 16 average on the other.
    You need to loosen up the spokes to around 10 and 5or 6 and get the radial trueness under control and then retrue the wheel.
  16. #3116
    Has anybody gotten 3x wide rims shipped lately?...just wondering about the turn around time. I ordered my wider 3x matte pair on December 28th and haven't seen them ship yet, but am not sure if they send a confirmation when they send them out. I am really looking forward to building these up.
  17. #3117
    4 Niners
    Dec 2008
    They will email you when they send them out. I just got my latest 2 yesterday that I ordered sometime in December. I usually figure about 4 weeks with shipping and I live in the center of the country.
  18. #3118
    4 Niners
    Dec 2008
    Also, I was thinking these might have taken close to 5 weeks, but China was shut down sometime in late December for Chinese new year so they lost about a week. Don't worry about it, they will email you.
  19. #3119
    Quote Originally Posted by ypocat View Post
    One trick that is similar is once you get the tire on, roll the wheel while pushing down to get the edges of the tire to spread closer to the sides of the rim.
  20. #3120
    Nov 2006
    yourdaguy - FYI - 2013, the Year of the Snake, begins on February 10, 2013. The Chinese new year varies every year in relation to our western calendar since it is based on their lunisolar calendar. If it was the same date it wouldn't need to be called "the chinese new year". So plan those orders around the Feb 10th - Feb 24th celebration of their new year:-)
  21. #3121
    Mar 2012
    Thanks. So, what is the exact process with the Bontrager rim strips?
  22. #3122
    Your "hop" is off?
    Are you building w/ the gauge to the rim lip or the shoulder of either the vert rim wall to angled sidewall, or angled sidewall to the flat surface of the nipple seat? I got the wheel close w/ the lip, then used the angled/flat shoulder to fine tune cause my T2 has a plastic cover on the tips of the horseshoe. If you use one of these shoulders, the true and hop can be better gauged w/ your stand since these surfaces are from the machined surface of the mold. Also, the rims I ordered had a gloss finish, so it reflected light a bit more.
  23. #3123
    radial trueness is something you have to do explicitly. loosen the spokes for a low spot (pulled in too far) You may have to loosen up to 4-5 spokes from the center of the low spot. Try to loosen them on both sides so you dont mess up the lateral true too much. However it probably will mess up lateral true so you might have to go back and forth. It took 6 hours for my first wheel and about 2 for my second.
  24. #3124
    4 Niners
    Dec 2008
    Andy13; what was the vacation they took in December? I know they had one, all the Chinese sites had big banners at the top saying they would be closed for a week.
  25. #3125
    Prob the same one where the entire Western world took off...?
    I mean, how are you supposed to get work done w/ your trading partners when they're all taking a week off? Just sayin'
  26. #3126
    Mar 2012
    Quote Originally Posted by DRILLINDK View Post
    Arch EX rims are 450 grams each and 24.6mm wide. The Crest rims are 380 grams each and 24.4mm wide.
    Light-bicycle has thier rims listed at 30mm wide. Is that accurate!? I know they're coming in at around 390g.
  27. #3127
    Internal width is what matters.
    Crest EX & Arch EX are 21mm.
    My LB wides are 23mm.
  28. #3128
    Nov 2006
    I would not be surprised that it is related to the west's holiday season like Pau11y says. I'm definitely no expert on Chinese holidays but I have been ordering electronic stuff from China for awhile (mostly for bike lights) and so I am familiar w/ the chinese new year delays.
  29. #3129
    Sep 2012
    Quote Originally Posted by goodmojo View Post
    thanks, will try that
    i think i now know what you mean - did my first bigger ride with tubeless today, and got a puncture on the rear wheel - these are tires previously used with tubes so there might have been a crack waiting to pop, anyway, it looked like a bigger cut/hole - and it did not want to seal until the pressure dropped i assume close to those 25psi you stated, maybe even less.
  30. #3130
    Any idea how much it costs to have a full wheel set shipped from light bicycle to the states?
  31. #3131
    As stated by there website, after shipping, as full wheelset will set you back $666. That's how much mine cost and I have been loving it ever since.
  32. #3132
    LB production interruption
    Just ordered a pair of wide mountain 32H 3k rims today.
    Delivery schedule according to Nancy for Jan 21, 2012:
    The lead time for wide 3k matte rims is around 15days, and for cross country rim is 10days.
    The wide rim is the most popular, there are quite a few orders these days, so if you order today, we can ship them before Chinese (Feb 4th to 17th) New Year vacation for you. If you order in the next days, the rims can not be finished after Chinese New Year vacation.
    The lead time for 12K is longer, it is the same for UD rims as 3k rims
    And my sincere thanks to each and every poster on this thread. I scanned/read the entire opus this weekend. Very useful exercise in sifting for clues.
    Sort of like Opera -lite with less costume changes.
    Thank you all!
    "Life is tough, but it's tougher when you're stupid."
    John Wayne
  33. #3133
    ballbuster
    Reputation: pimpbot's Avatar
    About as light...
    ... and not noodely at all! The carbon rims are nice and stiff.
    The Crest is a total noodle. I felt as if the bars often pointed in a totally different direction than the front wheel at times.
  34. #3134
    Mar 2012
    I've read through the entire thread. It sounds like there have been about 10 or so failures so far. I'm on the fence about buying these rims. My local bike shop is scaring the crap out of me saying a couple guys purchase Chinese carbon rims and the all had failures. One guy broke a few front teeth.
  35. #3135
    The fact that they're talking about "chinese carbon rims" makes me discount their opinion. It means that they are either consciously or subconsciously thinking in a bigoted and/or illogical manner. Specifically which brand or model of rims are they claiming are failing at a higher rate than which other brand or model of rims?
    These are distinct companies that have no relation to each other. But some people appear only concerned with the nationality of the company's owners. These companies have names and if talking about products, lumping every Chinese owned company together is at best naive and at worst, bigoted.
    Seriously folks, we should be talking about "Light-Bicycle" rims. When talking about ENVE rims do we say "Expensive American Carbon Rims"? The answer is no, because the specific company matters. It matters if the rims are ENVE, Easton, or sram. Similarly, the brand still matters when the company is owned by Chinese people.
    I wish the mods would change the title of this thread. It is perpetuating this insanity.
  36. #3136
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Quote Originally Posted by dfiler View Post
    Get a grip. Just because someone uses a very common descriptor does not point to bigotry. Ignorance yes but bigotry is a huge leap.
  37. #3137
    These Chinese "brands" (there are more than one) don't really brand their stuff that much. Except for the web address there was no branding of any sort on the rims or packaging I received.
    ENVE rims say so big as life on the side of the rim... six times on each rim, IIRC. That's a little easier to remember.
    And... going back to the OP, he was asking for any direct-source (i.e., from China) rims, similar to the frames people have been getting for quite a while. Why should mods change the name of the thread? Saying "Chinese carbon rims," if you can keep your emotional reaction at bay, provides a better picture of what someone is talking about than "light-bicycle." Oddly enough, that's why people say it.
  38. #3138
    A lot of drama around you I'm guessing.
    OG Ripley v2
    Carver 420 TI
  39. #3139
    Quote Originally Posted by AZ.MTNS View Post
    You must have missed how every sentence that said it was possibly bigoted, also said it could be simply illogical or naive thinking.
    Quote Originally Posted by meltingfeather View Post
    Interesting point about branding on the side of the rims. However, inclusion of a sticker does not seem like logical criteria for lumping multiple manufactures together.
    Quote Originally Posted by TwoTone View Post
    None of my post was written with heated emotion. Although it is understandable if it was interpreted as such without the body language, vocal tone, or facial expressions that would be apparent in person.
    If someone says don't buy rims because they have a history of breaking, what matters is the brand and model of rim, not the nationality of the owners and website developers. After all, most bicycle products are made in china.
    [edit]Removed two paragraphs that may have derailed the thread.[/edit]
  40. #3140
    Why even include the inference? Histrionics are best left to 13 y.o. little girls.
  41. #3141
    Quote Originally Posted by floydlippencott View Post
    Because it is true and important to how people perceive product quality from different brands.
  42. #3142
    My gloves stink
    Reputation: Appendage's Avatar
    Novatec axle adapters
    Quote Originally Posted by erikrc10 View Post
    Hey Erik, did you get the Novatec hubs with the replaceable end cap axle adapters? How easy is it to switch back and forth between adapters? I would like to use my wheels for both 9mm QR and 15mm TA forks, and want to know if this is a practical idea.
    I dreamed I ate a 10 lb marshmallow. When I awoke, my pillow was gone.
  43. #3143
    ballbuster
    Lemmie guess...
    ... because they aren't making money on it? I found a lot of LBS shop rats will poopoo stuff they don't sell, or don't want to sell. I one had an LBS tell me in no uncertain terms that at my weight (200#... not that heavy) I would break the frame on a sub $500 bike (back in 2000) the first ride out. I rode the crap out of that frame for 10 years before I finally sold it.
    Inexperienced sales people always seem to resort to scare tactics. Scare tactics to sales people are like Mrs. America contestants wishing for wold peace. Amateur stunts, basically.
  44. #3144
    And good sales reps turn that fear into profits.
    One of my wheel builders provides a life time warranty on builds. For parts that he orders $80/wheel. If you bring your own parts, it is $140/wheel.
  45. #3145
    Greystoke
    Reputation: geo025's Avatar
    Dec 2010
    They may of failed to add that was in a bar brawl post ride..
    I have an LB beefed up (437 g) rim as a front & an Enve am rear (26ers).
    I went with the Enve rear as my thoughts were a proven design & the R & D had been extensive. But I decided an LB would be worth the risk as a front.
    At this stage ( only been on them two months) the LB is are holding up well.
    I did some DH shuttles over the Xmas break in some very rocky terrain, no problem.
    Then a crash that rolled the tire & collected dirt & debris in the bead , no problem.
    Most of my riding isn't on rocks so they probably wont get the beating some of you subject your wheels to, but I am hard on my gear.
    Remember people have also been breaking the Enve rims & the internal alloy nipples are a pain.
    If I was going to purchase again I'd just go LB front & back , it's hard to ignore the price difference.
  46. #3146
    Quote Originally Posted by geo025 View Post
    I'm not saying the the LB rim is going to break on you earlier than the Enve, but your logic of putting the more proven rim in the rear wheel seems flawed.
    Rear rim folds at high speed - the wheel blocks, you come to a sliding stop, maybe a light crash.
    Front rim folds at high speed - you can probably figure out what that means. A lost tooth might be the least of your worries.
  47. #3147
    ballbuster
    Quote Originally Posted by messias View Post
    The way rims fail, even carbon rims... I highly doubt that a breaking rim is ever going to cause a crash. More like the other way around. A bad crash probably would be the cause of a broken rim... if it broke. It's not like... hmm hummm, riding down the smooth trail and BOOM! Broken teeth.
    Also, I think any aluminum rim would fail long before a carbon rim would fail in real world situations. The only exception is hitting a big rock hard enough to break a sidewall, causing the tire to come off. Even then, that is a really extreme situation... the kind where the big hit would have knocked you off the bike in the first place. I've seen folks come down from air sideways, tweaking a rim so bad it stops turning in the frame. Really, it was the bad landing that caused the failure, not the rim.
  48. #3148
    ... if it broke. It's not like... hmm hummm, riding down the smooth trail and BOOM! Broken teeth. .
    This visual is priceless!
  49. #3149
    To update on shipping times my rims shipped yesterday morning. I ordered 12k matte wider rims on Dec. 31. On Jan. 3 I was told they would take 15-17 days plus QA before they would ship. Pretty much dead on with the timing.
  50. #3150
    Mar 2012
    I know, I haven't heard of any catastrphic failures here on MTBR, but after hearing that 3 guys on the LBS race team bought Chinese rims (Unknown manufacturer at this point) and all three broke them I'm very apprehensive. I keep flip flopping between the LB rims and Stans Arch Ex rims.
  51. #3151
    Reputation: DeeZee's Avatar
    Jan 2005
    Do these guys on the race team have a history of breaking parts?
  52. #3152
    Mar 2012
    I don't know, but just hearing that all three broke their rims is making me apprehensive. I don't beleive they were LB rims though.
    I've been following this thread for awhile now. I'm finally building a custom wheelset, but all of a sudden I'm getting gun shy about the LB rims.
  53. #3153
    Another shipping time update - I ordered yesterday (UD, matte, 32 hole) and was told they will ship by Feb. 4.
  54. #3154
    Jan 2005
    FWIW
    My buddy that weighs 210 lbs has about 1,500 or more miles on his.
    I have beat mine up through rock gardens etc...
    Getting ready to build up a new set with the LB rims.
    The only rims I have seen many many many fail were the Rovals.
  55. #3155
    Reputation: Brisco Dog's Avatar
    3 different people from the same LBS race bought the same carbon rims and broke them??? I would be way more concerned about using their wheelbuilder than using the rims.
  56. #3156
    I ordered on December 28th and my rims shipped today. I ordered 32h 3k matte wider and stronger and Brian said the ones they had were 407 and 411 grams. I'm happy with that, and real impressed he took the time to ask me if I was good with the weights before he shipped them. Seems like a good operation, with impressive communication so far.
  57. #3157
    Mar 2012
    Screw it, I purchase the UD Matte w/ 32H. Here goes nothing!
  58. #3158
    Quote Originally Posted by Haymarket View Post
    Hum...my wide/stronger...3K gloss...were 431 and 429g.
  59. #3159
    ballbuster
    Quote Originally Posted by DeeZee View Post
    Were they built wrong? Did they have the correct spoke tension? Did they run them tubeless and let the pressure go too low and roll the tire off the rim? Did they over inflate the rim and blow the sidewall off?
    Were they the uber-light XC rims, or the AM rims?
  60. #3160
    Mar 2012
    These are all questions that I'll have to find out. Nonetheless, I ordered some rims. What tension is everyone going with 120?
    Where can I find the gorilla tape?
  61. #3161
    Lowe's, Home Depot, etc...
    Small ring in front makes it easier. Small ring in back makes it harder. That blows my mind.
  62. #3162
    Mar 2012
    Great, thanks for the reply.
    I thought I had that tape when I was at HD the other day. I just use the tape as I would a rim strip or Stans?
    What spoke tension is everyone using?
  63. #3163
    Mar 2012
    Also, Nancy said they were going to be implementing the new production process on the 29er rims after the Chinese New Year.
    Technology Improve Of Light-Bicycle Carbon MTB 650B Rims Light-Bicycle
  64. #3164
    This was an interesting read on LB's site:
    Looks like the new process will be extended to the 29er AM rims... Think I'll hold off getting another pair till summer...
    Edit: ...and I don't know about you guys, but their logo looks okay by me...I'd rock it on my bike!
  65. #3165
    They look like Rovals! The best graphics are the Chinese Letters a guy did. Subtle and cool.
  66. #3166
    Quote Originally Posted by Adroit Rider View Post
    Didn't happen w/o pics
  67. #3167
    Greystoke
    Dec 2010
    Not really , the rear wheel has to put up with a lot more stress compared to the front.
    If you look at the failures most of them are rear wheels.
    I have my fair share of crashes over the bars, some times you get hurt & sometimes you don't ,It's the nature of the sport.
    If I was riding on sharp edge rocks every ride ,I may well be a little more concerned.
  68. #3168
    Yeah, I almost ordered mine with the Light Bicycle decal, it does look good. I decided against it last minute though.
    I'm glad to see they are striving to improve their products. I'm happy with my "old" rims though. They are still running strong and true. Couldn't be happier, especially for the price.
  69. #3169
    I was debating what wheels to get for my new Jet9 RDO; this may have just made up my mind
  70. #3170
    I am thinking of getting a complete built wheelset from LB. Can anyone comment on the build quality and novatec hubs quality?
    ballbuster
    Read back a few pages.
    Quote Originally Posted by winkplay View Post
    It's been discussed.
    Wow... IMHO, those are really gash! I'll stick with plain non-decaled, thankyouverymuch.
  72. #3172
    Reputation: DITD's Avatar
    Nov 2012
    SUBSCRIBED!! Really thinking about pulling the trigger on these..
  73. #3173
    Reputation: eurospek's Avatar
    The less decals, the better.
    konahonzo
  74. #3174
    Reputation: five5's Avatar
    It's been discussed..
    So he's supposed to sift through the 3100 comments? Why not just help him out with an answer? If its been discussed, and you know the answer, or the page where it was discussed, why not help out? I would be interested in hearing as well, but I also got flamed the last time I asked a simple question here, just because I didn't read 3100 comments. What is the problem with being helpful around here?
  75. #3175
    Quote Originally Posted by five5 View Post
    people have written that they are a solid mid range hub. Not the best, not the worst.
  76. #3176
    Yea do some reading, that's why it's here.
    Otherwise every other day the same 3 questions get asked and the thread becomes useless because its the same crap rehashed over and over.
    OG Ripley v2
    Carver 420 TI
  77. #3177
    Same crap? Who cares? What else needs to be talked about in a thread about Chinese Carbon Rims? I'd think that the quality of the hubs these rims come with should be a continued part of this conversation. How does that make the thread useless? I'd say there are tons of pages of useless crap being discussed here besides the quality of the hubs.
    A forum is for asking questions, that's also why it's here.
    I'll add, I get it.. I'm a part of a number of forums. One in particular, there is a thread with 600+ pages. I've been there for a long time, so I've pretty much read every page, because it has been of interest to me from the beginning. Yes, a noob walks in, sees this thread, because it's something he's interested in as well. He doesn't have the time to read 600+ pages, or sift through the garbage that is posted there. He asks a question, I roll my eyes because I've seen the same question 100's of times.. but I'm polite, and either PM the guy with the answer, recal a page it might be on, or simply do what goodmojo just did, briefly summarize the jist of what has been discussed. It's not that hard to be helpful, even if it's a little annoying to someone who has been around for a long time.
    I guess we could talk about nipple corrosion some more though..
  78. #3178
    4 Niners
    Dec 2008
    It took me weeks to read the entire thread but I still try to help a new guy out.
    My answer is that the hubs are just below mid level based on weight, durability, upgradability, price, etc. and I would build my own wheels with something else.
  79. #3179
    Always Learning
    Reputation: BruceBrown's Avatar
    Nothing wrong with being helpful - that's for sure. Unless somebody has some specific posts bookmarked that are pertinent to the question - it is going to require anyone to do a bit of searching for the forum member who asked the most recent question about the hubs.
    The point others are raising is that there seems to be no shortage of information available on the interweb for reviews of Novatec hubs. And we do have "The Google".... I can type in Novatec hubs in Google and immediately get all kinds of hits, information, reviews and opinions. Took me a few seconds - that's all. Digging through this thread would take me, or anyone else - a lot more than a few seconds.
    I've read all 3100+ comments on this thread, but wouldn't know where to look outside of reading the thread to get a summary, but I wouldn't treat it as legitimate enough as the Light-Bicycle 29"er pre-built wheels may not have enough field testing, time, distance, duration out on the dirt to come to conclusive evidence to form an opinion from this thread alone. Yet, my memory seems to recall from all the posts on the hubs that there are plenty of better hub options available and ordering the 29"er rims by themselves, and having a quality wheel build done at your LBS - or on your own - seems to be a better golden ticket.
    I would like to think that somebody doing their research for buying a product certainly owes it to themselves to make the time commitment by investing in doing some searching, reading and opinion forming (outside of asking others) before making a decision with their $$$.
    Nothing is free or easy in life, so the bottom line is the poster who asked about the hubs needs to spend some time digging.
  80. #3180
    MSH
    MSH is offline
    Reputation: MSH's Avatar
    Jun 2005
    Mine arrived today and look sweet! Had Wider 3K Mattes drop shipped to Chad @ Red Barn. I shipped him an old set of 240S hubs to build up with DT Revolutions. Will be converting the hubs to 15mm front and 142 rear for a Ibis Ripley once it finally gets released. In the interim, will probably test them out on the Tallboy.
    Weights below are without any rim tape or valves. Will be using the Bontrager strips & valves which the set I have came out to 86g for the strips and 18g for the valves--> 104g total
    So complete weight = 1626g (1522g wheels + 104g strips & valves)
    BTW - this is the first time I have worked with Chad at Red Barn and he was great to work with. My old wheelbuilders (Larry @ Mtn High and before that Mike @ Odds&Endos) are no longer around, so I have been looking for someone new. Reasonable prices, great reputation, and a genuinely nice guy
  81. #3181
    My gloves stink
    Novatec hubs
    I have no experience with them but here's a write-up: Ride It, Fix It: Novatec MTB Hubs Review
    The trouble is that although the US Novatec website shows a 15mm TA option for their lightweight model, the D711, LB says they're not yet available. I've emailed various Novatec distributors 3 times asking when the convertible D711 will be available but have received no replies. I've also called the US distributor but all I ever get is some guy's voicemail. I've asked Brian at LB to notify me as soon as they are available. I won't need the wheels for a few months yet so I'm willing to wait.
    D711SB (FH) - Novatec
  82. #3182
    ballbuster
    Actually, I didn't...
    ..."know" the answer. I only sorta loosely got the gist of what other folks have been saying about it. I try not to engage in 'I heard this form somebody else on the interwebz' kinda conversations, because that's how bad information becomes even worse. The poster in question would be getting my regurgitated impression of what other folks have said here, and since I have never owned a set, don't really care to own a set (or, maybe I'll try them out someday... who knows? Not really on my radar at this time..), or even known anybody personally who owned a set... or never even saw one myself in the flesh, I would just be handing out more bad info.
    Yeah, Google is your friend... mostly. You can easily find the posts in this thread by searching for Novatec. It ain't that hard. The machines do all the work for you.
  83. #3183
    what's wrong with suggesting a search? even maybe how to do it? like THIS
    it benefits the community. you roll your eyes, then make that person all the more likely to do the same thing again by answering and/or doing the work for them?
    this thread wouldn't be a fraction of as cumbersome as it is (and I personally would have been saved clicking and deleting hundreds of notification e-mails) if people did some searching . you don't have to read every post to find stuff... just learn some basic search skills.
  84. #3184
    Dead horse.
  85. #3185
    I'll just converse with Google, ...blah blah blah
    Later
    So you are going to search then?
    Good boy for not being a slacker and asking for things to be handed to you on a platter. Just about everyone who contributes here did their own legwork...just sayin'
    Edit: hey wetpaint...
  86. #3186
    You hurt my feelwing!
    Actually, I was thinking the verbiage should be along the same lines as, "Enve," of advertising "I have carbon rims"... Something along the lines of, "Plastic Fantastic!" What do you think?
  87. #3187
    trail shredder
    Dec 2011
    pau11y- if you read the comments in the 650b rim technology post the lb sent out, you'll see that you don't need to wait until summer to get 29er rims w/ the new process. Nancy says:"the rims shipped after Chinese New vacation ( Feb4th to Feb17th) will be with new process. You can start to order these days, but the shipping will be after Chinese New Year vacation. You can make a note on the order that you like rims with new process.''
    new rims made even better!!
    my carbon footprint has cleats
  88. #3188
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    I don't get it
    Are we not meant to help people out as much as we can ??
    If you know the answer why not just answer the question ?
    We are in the same sport & I for 1 like to help out were I can, Saying do the leg work yourself isn't what a forum is about IMO.
    It's about chatting with others that have already done the leg work & can offer you an over view.
    Just say'n
    No need to respond to this post, I will just search for the responce I''m happy with.
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
  89. #3189
    Quote Originally Posted by xc biker View Post
    This is correct. I ordered a pair of wider 29er rims the other day and then the next day, this new process was announced. I e-mailed Brian and asked that my order be delayed so they could be made with this new process. He promptly e-mailed back and said that wouldn't be a problem. He says that they will not ship until after Feb 20th when they ramp up production of the 29er rims with the new process.
  90. #3190
    Love the sinister look of your bike! I'm thinking of building one very similar (albeit geared for the CO terrain). Did you build your own wheels? If so, any tips on using the light bicycle carbon rims? (Also, how are they holding up?) Thanks for any help you can provide in the gray world of chinese carbon...
  91. #3191
    ballbuster
    Uh...
    Quote Originally Posted by muzzanic View Post
    I don't get it
    Just say'n
    That's an awful large amount lot of outrage, eh?
  92. #3192
    ballbuster
    Bonus points for making that in a logo with Mandarin letters.
  93. #3193
    And get rid of the red! Black on black or white!
  94. #3194
    Reputation: ktm520's Avatar
    Hopefully the new logos are removable. No thanks.
  95. #3195
    ballbuster
    I could be wrong....
    Quote Originally Posted by ktm520 View Post
    .. but I think they are optional.
  96. #3196
    Quote Originally Posted by adroit rider View Post
    and get rid of the red! Black on black or white!
    + 1
  97. #3197
    Thanks to those who are kind enough to help. I am actually more concerned about the quality of the build? Seen some posts that says tension is uneven but would like to know if they improved recently. Also, how is the quality of the spokes lb use? Never heard of them and Google could not help.
  98. #3198
    As with any machine or factory build you should check the tension upon receipt and make adjustments. Your LBS may charge $20-40 to do this.
    There are many reasons why people prefer local builder or DIY. From this thread, it has been made clear that aluminum nipples need a lubricant to prolong lifetime and you don't know what LB uses for nipple prep.
    The flip side is value. $666 for a carbon hoop wheel set is unbelievable and the worst case scenario may be a rebuild with new spokes and nipples in a couple years.
  99. #3199
    The initial response wasn't "Suggesting a search", the response was "It's been discussed". Which isn't helpful at all, and.. I wasn't even the one asking, only interested in the answer... so I don't need to "Learn to search", I'm just not understanding why people can't be helpful, and answer a question. Maybe this is the first step to their research? Simple direction might be all they need.
    I'll be sure not to ask another question here. It seems way to bothersome to be polite, and help someone with a question, for many here. All good.
    I'll just converse with Google, seems that there's no reason to actually talk, ask, or have conversations with real people.. just do a search, do a search, do a search, it's all on Google, don't ask questions... they'll spread like cancer.. Got it.
    Good luck protecting this pristine doctrine. (Which all the info can be found in Google, or it's just opinions that don't count from what everyone is telling me).
    I won't bother you guys anymore.. sorry for wasting everyone's time.
    Later
    lol
    first, i guess you missed the "read back a few pages."
    second, you weren't even the guy who asked the question that has been discussed at length over and over and over. you're just the guy who got upset about a contributing forum member pointing out that discussion of novatec hubs is plentiful and available to you easier than asking (the same effort put into a forum search would have yielded much more useful information than asking a question that has been asked 1,000 times). click this link to see how many threads have been started asking about novatec hubs.
    this forum is about sharing information and helping people. i spend most of my time here offering information and answering questions (helping people). that doesn't mean it's wrong to suggest someone look at the VAST archives of useful information before asking a question for the hundredth time.
    i search before posting a question. i know it's a crazy concept, but what you'll find is that most questions (e.g., does anyone like trek bikes?!?) have been answered already and in the time it takes you to post the question you can have your answer many times over.
  100. #3200
    lol
    Like I said, there is not a problem with telling someone to do a search, the response was "it's been discussed".
    Keep talking down to people. It fits you well.
    Again, you've proved how much smarter than me, hope putting me down makes you feel better. I'm simply trying to help the person.
    Again, sorry to interrupt all of you vast knowledge.
Members who have read this thread: 724
