Page 28 of 87 FirstFirst ... 182425262728293031323878 ... LastLast
Results 2,701 to 2,800 of 8669
  1. #2701
    KLF
    KLF is offline
    Quote Originally Posted by BruceBrown View Post
    Bontrager Rhythm strip weight: 35g (strip) + 8g (valve) = 43gBB
    Admittedly picking nits, but the two Rhythm strips that I had my hands on in the real world weighed 42g each. (20% over spec.)
  2. #2702
    the train keeps rollin
    Reputation: snowdrifter's Avatar
    Weight Weeners should use Stans yellow tape, people who want the most secure tubeless interface should use the Bontrager strips.
    beaver hunt
  3. #2703
    ballbuster
    Reputation: pimpbot's Avatar
    And I'll add....
    The wider Light Bicycle rims are an all mountain bike rim. Outside of comparing pure weight to the Crests - which are far from being an all mountain capable rim - there is not much reason to compare the two. Comparing to the Flow (or other metal rim brands of comparable width), or AM carbon rims of similar width from other companies might be the better view in terms of targeted use and weight comparisons.
    I would use the following average weights for comparing the strip and valve for a 29"er wheel since it includes the valve:
    NoTubes weight: 6.5g (valve) + 8.5g (Stans wide yellow tape for a 29"er run) = 15g
    My Light Bicycle wheels with the wider AM rims/AC hubs/double butted spokes weigh 1540g + Bonty Strips and Valves = 1626g
    Crest Rims with DT Swiss 240 disc hubs/SuperComp spokes/yellow tape and valves = 1640g.
    I use both sets of wheels.
    BB
    I just rode at Annadel on my trail bike with these rims. I was pounding down Lawndale and other rocky trails there with the highest confidence. These rims are very stiff, very point and shoot. I ran a crest rim on my front wheel for about a month. I can't say it was confidence inspiring at all. For similar weight, the light bikes am carbon rim is a clear upgrade over the crest.
  4. #2704
    Dec 2011
    Had my first rim failure today. This was this rims first ride though as i have been running a pre-built wheelset off them for about 5 months now with no issues. Luck of the draw i guess.
    This rim is laced to an Ethirteen TRS+ hub. See how I go with warranty.
  5. #2705
    Quote Originally Posted by Egads View Post
    I placed my order over a month ago and am still waiting on my shipment. Not a happy customer now.
    My rims arrived today, exactly 42 days after placing my order. I'm not sure why the delay, but I do appreciate Brian's frequent contacts.
    The wider 29er rims look great, and weigh 371 gms each. Will build them up with DT 240s and Aerolite spokes.
  6. #2706
    Jun 2010
    These look really interesting!! How do you think the wider 26" rim would hold up under a 165lb rider on a Mojo HD140? Would the standard rims be strong enough, I've never bent or killed a wheel before, so I'm pretty good at keeping things together!
  7. #2707
    4 Niners
    Dec 2008
    Bruce: I just got 3 Bontrager stirps today and a put all 3 on the scale at one time and it was 130 grams. My first 2 weighed 44 grams each. You must have hit the lite weight lottery on the rim strips since all of mine are around 43-44. I also have Crests and these and feel that the comparison is good since these rims only actually hold the tire less than .5 wider and the weights are similar. I also have a set of Flow wheels and while they are much stiffer/stronger than the Crests, they weigh more but they hold the tire wider than the LB wheels. I can only compare the rims I have. On paper the new FlowEX rims are going to hold the tire much wider overall and they basically weigh the same as the old Flow's so I think someone that needed the extra volume would prefer them. The FlowEX rims might have the problem of holding the tire too wide such that at high lean angles you effectively have no side knobs. This would be tire dependent.
    Full rigid SS, Hardtail SS, Hardtail Geared, Full Suspension Geared.
  8. #2708
    Quote Originally Posted by lawman1991 View Post
    I have the wider 26" 3k weave normal weight of 370g each on my Yeti ASR5 (140mm forks) and have been abusing them on the Quantocks rocks and roots with the occasional drop/jump with no problems. They hold the line very well and make landings feel much more secure. I run the bonty strips with continental rubber queens 2.2 ust tyres. When I get some spare cash I will be purchasing spare rims for when/if they fail as they are superb and will not be going back to alloy, highly recommended.
    EDIT: Forgot to say I'm 190lb kitted out with full pack and ready to ride.
  9. #2709
    I placed my order for wide rims about 10 days ago (10/27) and I got notice that they shipped yesterday. They estimated 4 days to ship, so 2 weeks total.
  10. #2710
    Reputation: SwintOrSlude's Avatar
    A bit of whoring to keep the topic documented with images:
    Wider rim / CX-Ray / Tune King MK 20mm. Still in love with these rims!
  11. #2711
    Mr. Knowitall
    Reputation: hssp's Avatar
    Quote Originally Posted by SwintOrSlude View Post
    http://monimag.eu/upload/1048/2012-09-24%2018.54.26.jpg
    Weight? What about rear wheel? Tune there? Quality? So many questions.
  12. #2712
    Quote Originally Posted by hssp View Post
    Front wheel is 683g without the Bontrager strip (46g with valve).
    For the rear wheel I wanted something very stiff so I went with a Hope Pro II bolt-up (10mm bolts), upgraded to Ti bolts, with bolts the wheel comes in at 924g without Bontrager strip. (Wider rim / CX-ray / Hope pro II boltup+Ti bolts)
    I'm VERY happy about the tubeless setup which has been flawless for me (and I've burped many notubes setups). I just wish they made a 250-280g rim for XC now!
  13. #2713
    Nov 2012
    good whellsss
  14. #2714
    ...laced in my 4th pair of LB rims .... good to work with and very nice to ride...
    my "wide tires wheels"(DT240/Hope/CN Spokes) in use:
  15. #2715
    Reputation: kreater's Avatar
    Quote Originally Posted by zweigelt View Post
    wow nice quiring, and scenery.
    Product designer @RSDBikes.com
    "Live dangerously and you live right."
    Johann Wolfgang von Goethe
  16. #2716
    thanks
    i have forgotten to tell you, i use my rims(wider 29") with cutted to size Duct Tape...
    Very good to handle, and no burps(2.3 S-Works Ground Control) yet...
    Thanks Brian for the nice contact and your perfect and fast service!
  17. #2717
    I was looking at the light-bicycles site and the wider 29er wheels look interesting for my Endurance XC racing machine. Using Crests currently, and these seem like they would be about the same weight but much stiffer and also stronger.
    Does anyone build/sell these with different hubs? I'd rather do a "name" hub vs the no name hub that's on their website, but don't have any desire to get it custom build here at my LBS.
    I'd like to either do a ZTR hub, or AC.
    Any idea?
    -Tom
  18. #2718
    Reputation: freebiker's Avatar
    Mar 2006
    why
    Quote Originally Posted by trhoppe View Post
    Any idea?
    -Tom
    why not get a local shop to build them up for you. otherwise you will end up paying much more for them with a middlemans markup. the whole point to these rims is bypassing much of the price gouging by buying them direct from the source.
  19. #2719
    ballbuster
    I'm 208#, and they feel solid to me. They feel more solid than the WTB SpeedDiscs I replaced, as well as the DT X470s and Sun Inferno 23s, although the Infernos are the most solid of the alu rims.
    I don't tend to tweak rims... once in a while. I don't do big drops or anything, but I do plow rock gardens at speed.
    I think you'll be fine, but it all depends on where and how you ride. If you ride sloppy and land sideways on a regular basis, all bets are off.
  20. #2720
    Quote Originally Posted by freebiker View Post
    Doesn't seem that there is a local shop here (in town Atlanta) that won't price gouge me anyways. So I might as well see if anyone is building these with custom hubs and shipping em around.
    -Tom
  21. #2721
    Quote Originally Posted by oldm8 View Post
    What happened? Big hit?
    Small ring in front makes it easier. Small ring in back makes it harder. That blows my mind.
  22. #2722
    4 Niners
    Dec 2008
    My second light build done! AC hubs, Revolution spokes, alloy nipples:
    Front: 670
    Rear 780
    Total 1420
    Adding skewers, Bontrager rim strips and Stan's valve stems=ready to mount tires + 1650
    I didn't go with quite as much tension since theses are much thinner spokes and the hubs are not as stout. But, I have been riding the other build of Shimano M529 hubs and Alpine III spokes and they are so solid I think they will last a lifetime. This build, while lighter by over 500 grams (and around $300 more) looks to be close to equally stout. The super cheap Shimano hubs, while weighting a lot, are quite as hell. I am now constantly running up on deer, squirrels, foxes, and coyotes. If the American Classic hubs are this quiet, I will probably hit some wildlife in the next year.
  23. #2723
    KLF
    KLF is offline
    Quote Originally Posted by yourdaguy View Post
    Front: 670
    Rear 780
    Total 1420
    Oh? I guess I need to re-calibrate my abacus.
  24. #2724
    4 Niners
    Dec 2008
    Well my rims came in around 380 or less and the AC hubs are very light and the Revolution spokes are the lightest round DT spokes. The Revolution spokes come with brass nipples, but I substituted alloy nipples. These are going on a SS bike and the engagement of the AC rear hub is quick but not instantaneous. In other words, it engages not all at once. I read a review on 29inches.com and they liked it and so far, it looks like it will be good from dry testing. I am going to mount tires this weekend and first ride is probably Tues.
  25. #2725
    May 2012
    Upated carbon 29er clincher rims weight at 350g each piece, and come with Novatec 711/712SB hubs and Sapim CX-Ray spokes and Sapim nipples, the weight of comeplete carbon 29er wheelset can be around 1430g/pair.
  26. #2726
    Reputation: metrotuned's Avatar
    Caution;  Merge;  Workers Ahead! 15mm trade for 9mm with 30mm carbon clincher
    Anyone build up a 30mm carbon clincher 9mm front wheel and want to trade upgrade to QR15 Maxle? I got a Chris King large diameter LD*** pink ISO 15mm front hub handlaced with Phil Wood & Co double butted silver spokes, Phil brass nipples, to a 30mm carbon matte rim. 4 rides on the wheel, less than 150 miles. Flawless. Makes a 2.4 Ardent jumbo-sized. I want to trade for a 9mm front end (going to rigid due to the CX off road touring specific riding I do nowadays).
    Based in Bay Area Nor Cal. Photo of actual wheel attached - at Marin Headlands Hawk Hill on its maiden voyage to the summit of Mt. Tam! PM or email me thanks.
    p.s. moderator, if this is spam, let me know and i'll gladly pay mtbr 3 bucks finders fee.
    *** ISO 15mm LD Large Diameter, Super large bearing with 24 ball bearings per side for unparalleled strength & durability, 197 grams (complete hub), Can easily swap to a 20mm thru axle or 24mm Maverick American axle
    Attached Thumbnails Attached Thumbnails (Cheap) Chinese Carbon Rims?-illnacord-mtbr-trade-c.jpg
    Producer, Actor Will of the Sun, Author Platform Pedal Shootout 900K+ views
  27. #2727
    Nov 2012
    Quote Originally Posted by pimpbot View Post
    I've had the same experience. I think carbon rims are going to be one of the next big things if they aren't still. Still, beware of the rocks...
  28. #2728
    Always Learning
    Reputation: BruceBrown's Avatar
    Quote Originally Posted by illnacord View Post
    Anyone build up a 30mm carbon clincher 9mm front wheel and want to trade upgrade to QR15 Maxle? I got a Chris King pink ISO 15mm front hub handlaced with Phil Wood & Co double butted silver spokes, Phil brass nipples, to a 30mm carbon matte rim. 4 rides on the wheel, less than 150 miles. Flawless. Makes a 2.4 Ardent jumbo-sized. I want to trade for a 9mm front end (going to rigid due to the CX off road touring specific riding I do nowadays).
    Doesn't that hub easily convert to 9mm? I know my King front hub converts back and forth between 9mm and 15mm.
  29. #2729
    Reputation: Nater's Avatar
    AFAIK, it does. Kings go from 9mm to 15mm and back, 15mm to 20mm and back, but not 9mm to 20mm.
  30. #2730
    Tom - talk with Chad at Red Barn Bicycles. He builds great wheels and has good prices. Several people have had the LB rims delivered to him for build up.
    -Shane
    -Tom
  31. #2731
    Brucebrown, the SD does convert between 9 and 15. However, I should add clarification - CK large diameter "LD" hub swaps 15, 20 and 24 only.
  32. #2732
    Always Learning
    Got it.
  33. #2733
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    That's if you're using factory Chris King parts. Using an aftermarket conversion you can get the 15 to 9, SD or LD.
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
  34. #2734
    Reputation: TXNavy's Avatar
    Quote Originally Posted by meltingfeather View Post
    Just curious, what aftermarket providers are out there? I spent a long time waiting for Chris King 135x10 through axles and their 15mm SD conversion and felt like both were steeply priced...
    Sent from my Galaxy Nexus using Tapatalk 2
  35. #2735
    Quote Originally Posted by Pau11y View Post
    Fixed it for ya
    To the limp-d!ck who left me a neg-rep and this chickensh!t unsigned comment: China homer plus grammatical ******... weak
    Do the world a favor and duct tape a plastic bag over your own head
  36. #2736
    beer is good
    Reputation: Nels's Avatar
    Quote Originally Posted by TXNavy View Post
    Here's one on ebay:
    Mountain Bike 15mm Thru Axle to Standard 5mm Quick Release Wheel Adapter | eBay
    Attached Thumbnails Attached Thumbnails (Cheap) Chinese Carbon Rims?-%24t2ec16h-ue9s3weg5fbqhgwocguq%7E%7E60_3.jpg
    Steve
    "looking California, feeling Minnesota"
  37. #2737
    Well...that's to convert any wheel with a through axle down to a QR.
    The Chris King conversion kit to go up from a QR to a 135x10mm through axle in the rear on the other hand is pricey for what it is and slightly rare. I'd like all of my King wheelsets to have the through axle, but not so much that I'm going to pay Chris King prices for them...
  38. #2738
    Oct 2012
    Wheel report- Pulling the trigger
    I ordered 3k 32h Wider rims from the site on the 21st of October and Brian emailed me within an hour to confirm information. They shipped the rims with a USPS tracking number just five days later and I received them on the 30th. I have been saving for Enve wheels for months, but the thrifty side of me had to see if these could work first.
    They come in this type of packaging which seems sufficient and made it easy to transport to my lbs:
    IMG_1318 | Flickr - Photo Sharing!
    I inspected the rim and was not impressed with some of the sanding-like feature of the rim bed and all of the holes did not look perfectly circular. However, I thought it over and have come to believe that unless it is way off then it is really an irrational worry. The Rhythm strips really do seat perfectly along that space making it pointless to be concerned about how smooth it needs to be.
    IMG_1321 | Flickr - Photo Sharing!
    Carbon rims look great built up! I went with DT 240 20mm front/10 mm TA rear, DT Swiss Comp spokes, brass nips, old X7 cassette, Avid rotors, and the same Specie tires. I had asked for silver nipples, but instead got black completing the all too hyped 'murdered out' look. Other than that, they are perfect.
    IMG_1348 1 | Flickr - Photo Sharing!
    For anyone skimming through dozens of pages to get more info, I'll try to help here:
    Buy (2) of the rhythm 29"er size strips Bontrager: Tubeless Replacement Parts (Model #02566). It will come to a total of about $30 and they allow you to go tubeless.
    If you are doing a low budget build then go for Hope hubs. High-end, DT Swiss or Chris King. DT Swiss spin smooth, have a 'low' 18 POE (can be upgraded to 36), and are low maintenance. CK hubs have a distinct sound when coasting, has color options, has high POE at 72, and require specific tools for periodic servicing. Both hubs are essentially fully convertible and have all around solid reputations.
    Results:
    I do not have any numbers to compare the loss of weight over my stock, however my calibrated arms detect an easily noticeable difference. I am sure that my stock 2011 SJ FSR Expert wheels with 520SL rims and Speci Hi/lo hubs must be a durable, yet heavy and slow rolling set of rubbish.
    Pluses noted after just two ride in a week:
    These wheels hold air better when stored than my Stans Arch wheelset. It was never really a problem before, I just had to be mindful to check pressures every once in a while. Now I doubt I will even be doing that. I also am going to experiment with lower pressures because I have burped Stans wheels when landing into a turn with pressures in the low 20's
    I am much faster now and have no interest in stopping at spots where I normally push myself to get to before stopping for a break. I consistently ride my 2x10 drivetrain at 3-5 gears higher than before. I note 3 early on and then even five gears later in my ride when I guess I used to be too tired to maintain the same gear.
    I did not fully understand what 'flexing the wheel', 'tracking', and 'vibration damping' meant in terms of mountain biking before but all those terms became clear to me on just my first ride. I can now sprint up on a climb and I feel better correlation between my pedaling and the acceleration of the bike. Hell, I can even lift up the front of the bike easier which is making me reconsider purchasing a shorter stem.
    I have noted a drastic drop in my upgraditis over the last few days.
    I am going to sell my xc bike because I no longer feel fatigue on my long travel bike like before.
    I can not be sure how much of a difference can be attributed to the rims given that I also upgraded straight to DT Swiss 240 hubs with a 10 rear TA versus the stock RWS 5mm and rode the wheels freshly built up. I also noted how much more true they spin on my wheel stand. What is important though is that I know it was definitely worth the ~$1100 that I spent.
    Clearly this is all subjective and my main point is that if you are considering a wheel upgrade, then do not let the rationale that a pound here and there is probably not worth it because it sure as f'n hell was for me. I wish I had pulled the trigger on these things months ago instead of thinking that I would be 'cutting corners' or something.
    I will report on if they do not hold up for whatever reason. Clearly that is an unproven element in my review and it seems like I had such a huge change that I may be an outlier within this thread in terms of first time quality, communication with the distributor, shipping speed, and performance difference between my old set all coming together.
  39. #2739
    ballbuster
    Quote Originally Posted by actickuff View Post
    There are many people who would like to have gomoncleroutletsale com/]cheap moncler jackets coats which can be both equally fashionable that will both ensure that they can safeguard just one in the chilly winds while in the winter season and also appear good concurrently The ideal solution for such folks is actually opting for the trendy and stylish jackets
    To ensure that gomoncleroutletsale com/]moncler sale lady's current wardrobe being considered to be complete, that means that you need to have a ladies jacket This can be the primary closet thing that will be sure that their costumes will be able to find with numerous pizzazz By way of example, when dressed in a couple of denim jeans, the ladies may also don a jacket to compliment everything
    In traveling into the fashionable and classy leather coats for women, you will find that gomoncleroutletsale com/]moncler outlet you'll find quite a number and many of them are slipping of cloth which might be designed for donning above the nighttime outfit Of these applications, you also be able to find there are other types that will assist in protecting one through the rainfall You will even find other sorts of spencer that happen to be worn by women who aid you in ensuring that their business enterprise attire is accompanied It may be like sun dresses that are suitable for a suit
    Seems legit
  40. #2740
    Reputation: krispy@go-ride.com's Avatar
    My warranty CCC rim came wrapped in a very comfortable leather jacket. I think i am going to include some denim jeans in my next order.
    Santa Cruz Bronson 2 27.5/Rockshox Pike/Sram XX1
    Salsa Mukluk/Rockshox Bluto/Sram X1
  41. #2741
    Reputation: Gobstopper's Avatar
    Krispy, do you mind chiming in on what happened to your original rim? I've been following this thread for a while patiently waiting to pull trigger on a set for enduro races next year and I'm still sitting on the fence.
  42. #2742
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    Seems legit
    That is f () cking fuuuunnnny!
  43. #2743
    bt
    bt is offline
    Nov 2007
    Quote Originally Posted by Art.C View Post
    Results:
    whiskey tango foxtrot?
  44. #2744
    Quote Originally Posted by Gobstopper View Post
    Hey all,
    My CCC rim suffered a crack on the bead hook when i clipped a rock on the edge of the trail i didn't see. I was running 27psi, probably too low, and i instantly tore the casing of the Racing Ralph SS 2.25 as well. Hard to say if it was just the right hit to just clip one side just right to crack it or if these rims crack kind of easily....
    The crack went down the sidewall a ways, but didn't go into the hollow box, or near a spoke hole or anything. Some material flaked off of the bead hook. The rim was still true and under even tension. I threw a tube in and rode it for a couple days.
    I shot some super glue deep into the crack and held it in the vise under pressure. Then i epoxied the rim with an expensive boat epoxy. I rebuilt the bead hook a bit and i left a bit of a glue dome on top of the crack. LB warrantied it for $20 shipping. I set it up Ghetto Tubeless to get a better seal just to be safe.
    Since it was still holding together I decided to ride it longer. I was really curious if it would still hold up. This was a huge gamble since The Whole Enchilada was the next weekend and was the focus of my whole season!! Over the 23 miles and 6000' of rock punishment it held up!! I started freaking out about 1/3 of the way into the race (on Hazard) because i was running second at that point out of 75 and the rear wheel was making some reeaaly loud sounds. I wanted to stop and feel the spokes but i was in a battle of death for the lead. I thought for sure it was coming apart so i backed down a little and decided to ride a little lighter. After another 30min i realized it was fine since it hadn't come apart on me yet so i pinned it down Porcupine WFO and clobbered the wheel at least 100 times into sandstone. I think the carbon rims and a fat tubeless tire put out some harmonics on the rock, Carbon wheels on road bikes certainly have a hum as they go by.
    It's one of those things, ...if you clip one bead and pinch your tire and would have dented an alu rim you will probably crack the CCC rim. If you hit super hard evenly on rounded sandstone, come up short on a gap jump or land sideways on a hip jum they are pretty tough.
    No doubt though, they are SO STIFF AND SO FAST that i cannot live without carbon rims anymore. If you can afford it just buck up and buy ENVE's. If you just rip trail and don't dent alu rims then CCC are just fine, but consider buying 3 instead of a pair!
    Would i still recommend them? For $175 a piece, yes.
  45. #2745
    Reputation: saruti's Avatar
    Krispy.
    so did you finish on the podium? :-)
  46. #2746
    Quote Originally Posted by seleniak View Post
    -Shane
    Ditto. Had mine built there. High quality professional build and very reasonable price.
  47. #2747
    Have smashed my 29er wide 380g rims off many rocks with my 200lb loaded weight with no issues, they actually hold air better than my old stans crest wheels - even at 20psi smashing them off rocks there is not a single issue with them.
    I have also smashed my 88mm clincher roadie wheel off some potholes which actually hit the rim bead with no issues, just a small cosmetic mark on the rim.
    Bike tracks great, very responsive in left / right motions and there is more cornering grip with the wide rim profile. I can put the power down better now I feel, and my times are quite a bit faster vs. the old Crest combo (weight savings was .7lb)
  48. #2748
    Dab-O-Matic
    Reputation: Simplemind's Avatar
    Quote Originally Posted by broadwayline View Post
    Are you running Bontrager strips, or what is your set-up?
  49. #2749
    Quote Originally Posted by saruti View Post
    Krispy.
    Yeah man i did!
    I went off a drop and landed on a sharp rock yesterday, pinched the rear tire, no crack. Go figure. I did help an old lady across the street the other day though.
  50. #2750
    Reputation: red5jedi's Avatar
    Feb 2006
    Freaking carbon rims.
    Now I can't stand my Arch and 355 rims on my SS, feels way to flexy that I can't stand them. Time to upgrade them also.
  51. #2751
    Quote Originally Posted by Simplemind View Post
    Just 1 layer of Gorilla tape with a Rocket Ron up front and a Bontrager 29-0 in the rear tubeless.
  52. #2752
    4 Niners
    Dec 2008
    I can definitely tell the difference in steering precision on the front but almost prefer the cushier ride of my Crests on the rear, but I am not going back.
  53. #2753
    Nov 2006
    Anyone know what the weight of a single layer of gorilla tape is?
  54. #2754
    Reputation: JHwick's Avatar
    Quote Originally Posted by Andy13 View Post
    A single wrap of 24mm wide Gorilla tape added 24g per wheel with my 26-inch AM rims. Add 10% for a 29er. Yellow tape is more like 8-10g per wheel.
  55. #2755
    It's about 8-14g heavier than yellow tape from what I have found personally depending on width. It's what ENVE suggests for their carbon wheels, even though I am a weight-weenie I went with what the carbon makers recommend.
  56. #2756
    Dab-O-Matic
    Wow, you are running the 29-0 in rock infested trail...I would never believed that skinny, thin walled tire would hold up to that abuse and a tire like that offers minimal rim protection. You must be a pretty graceful trail technician.
  57. #2757
    To be honest I thought it would be much worse than it was, tire is surprisingly grippy and extremely fast in the dry (scary in the wet). The wide LB wheels actually made the footprint much better than my old Arch EX
  58. #2758
    Jun 2005
    Hi Folks,
    This is a cross-post from wheels and tires, but it is a question regarding the Novatec D822SB on the rear wheel of my CCC prebuilt wheelset, so I thought I would ask here as well...
    I am super happy with the wheel set, other than the weight of the rear wheel. The rear hub is a wee bit on the heavy side. I am pretty certain that that model hub is all steel...steel hub shell, freehub body and axle. I am wondering if it is possible to swap out the freehub body and/or the axle for aluminum replacements. It looks like they sell aluminum freehub bodies but I don't know if they would be compatible with this hub. I have poked around on line quite a bit and tried to contact Novatec and their US sales guy, as well as some other online Novatec resellers. I can't find a conclusive answer myself and nobody I have reached out to has gotten back to me.
    Any thoughts/suggestions are appreciated!
    MSH
    MSH is offline
    Reputation: MSH's Avatar
    Jun 2005
    Quick question for folks using the Bontrager strips. Are most folks using the strips with or without sealant? As far as I can tell, from the many pages of the thread I have read, most are using sealant as well, but the original post (#131) by "indyfab25" that I believe initiated the idea of using the Bontrager strips seems to use the no-sealant approach-->
  60. #2760
    MattSavage
    Reputation: mattsavage's Avatar
    Sep 2003
    Quote Originally Posted by JudgeMorris View Post
    Hi Folks,
    Here's the specs on it... D882SB (RH) - Novatec
    and some resources:
    http://novatecusa.net/wp-content/upl...atalog2012.pdf
    http://novatecusa.net/wp-content/upl...2012-02-08.pdf
    "I wrote a hit play! What have you ever done?!"
    Have Ashtray, Will Travel....
  61. #2761
    4 Niners
    Dec 2008
    I believe 99% are using sealant. Those using true UST type tires could probably get by without sealant if they never ran over a thorn.
  62. #2762
    Quote Originally Posted by MSH View Post
    The Ikon EXOs I mounted sealed and held air with no sealant but I still added sealant. It can't hurt, right?
  63. #2763
    Jun 2005
    Thanks for the links. I did come acrossed that info myself when I was doing some research. It didn't seem (to me) to answer my questions. However, I did hear back from Henry at Novatec US. He has been very helpful so far. I'll be happy to post back if/when I make some progress if anybody is interested.
  64. #2764
    Always Learning
    You'll need sealant with 99.x% (just a guess at %) of the tires available. Post 131 is a typical example that one should air up and test the tire to make sure it will air up before adding sealant. Indyfab was just testing the bead and the tire on the rim with the strip to make sure it was golden to go after the Hans Dampf without the Bonty strip blew off the rim. Most tires will hold air for a certain duration before the air seeps out - some a few seconds to minutes, some even longer such as the tubeless ready Nobby Nic pictured in post 131. During that time frame you can test, as Indyfab did, for possible burping issues as pictured in his post. He was looking for security and a bombproof set up.
    The only tires I own and have found to be able to be run on a 29"er without sealant would be the Maxxis LUST versions of the Ardent 2.25 and Crossmark. Of course, they both weigh 200-300g more due to the extra rubber to make them tubeless. Even then, you have to dip the valve in sealant every now and then to plug up any air escaping around the valve stem hole. I have not tried them on the L-B carbon rims to see if they would run without sealant (they do fine on my NoTubes rims without sealant). The other caveat with the LUST tires is - if you do get a thorn or other puncture, you will have to patch the inside of the tire like one does with any tubeless tire run without sealant if you want to continue to run it sealant free. I've yet to puncture mine.
  65. #2765
    The idea of the rim strip is to let them seat easier with just a floor pump by forming a tighter fit from the tire lip to the bead of the rim, or avoid rolling the tire off the rim at very low PSI - nothing to do with sealant.
  66. #2766
    MSH
    MSH is offline
    Jun 2005
    Thanks for the feedback on the rim strips everyone.
    I only have experience with the Stan's rims and yellow tape, so this is great info to get my set sealed up once I receive them
  67. #2767
    Reputation: Dpca10's Avatar
    Sep 2012
    Thought i should chime in. i built up a set of AM heavy 29er LB wheels with Chris kings. Been beating the crap out out of them. Went totally sideways and dug in after being thrown by a root. Rode them hard in rock gardens, taken some hits, totally bombproof. Really havnt gone out of true even. I had nobby nic rear and Hans dampf front. Switched to a purgatory rear and butcher front and love the combo, faster rolling seemingly. Just bummed the King hub isn't xx1 compatable or upgradable at this point in case I want to make the switch. Oh yeah, bonty rhythm strips (with sealent) on both although I had gorilla tape for a while that was fine. Strips really snug it up.
  68. #2768
    Let's ride
    Reputation: rensho's Avatar
    Either Stans or Gorilla is fine. Pull the Stans tape tight when you wrap it. Start away from the valve stem and overlap more than 3". Pull it tight!
  69. #2769
    Quote Originally Posted by rensho View Post
    Yes!!
    Don't know where the dingbats on this forum who recommend overlapping at the valve get it from.
  70. #2770
    4 Niners
    Dec 2008
    I believe they watch the movie on Stan's web site. I have done it both ways, and it doesn't seem to matter.
  71. #2771
    You mean the "Yellow Tape Install" video below, where he says at 1:25 to start at the weld (opposite the valve hole)?
    <iframe src="http://player.vimeo.com/video/34568003" width="640" height="385" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe>
  72. #2772
    4 Niners
    Dec 2008
    That is his new video. The one I watched 4 years ago said to start just before the valve hole and then come back around to past the valve hole. I didn't know they updated it.
  73. #2773
    MSH
    MSH is offline
    Jun 2005
    Thanks Rensho! I'm pretty versed in taping up the Stan's rims. I've never used rim strips so didn't know how folks were using those.
    I haven't decided which way I'm going to go once I receive my set (strips or tape), but leaning towards the Gorilla tape. I'm a XC weenie anyway so no big hucking stuff for me.
  74. #2774
    lol
    whatever you need to believe, dood. that's the same video that's been up for years. they don't even make the alpine rim anymore and that's an old school logo on it.
    I guess they used a time machine to upload that same vid to YouTube in June of '08, right? link
  75. #2775
    4 Niners
    Dec 2008
    Well I know you don't believe me, but the video I watched was from a longer shot and it might have been longer than 4 years ago. June of 08 was a little over 4 years and they have had video's way longer than that.
  76. #2776
    lol
    well, fwiw, that's how I learned to do it as well (starting at the valve stem)
  77. #2777
    HatrickPatrick
    Carbonality wheelset quality?
    I'm also wondering about the pre-built carbon wheels with Novatec hubs from Carbonality.
    I'm thinking about upgrading my stock Vuelta wheels to some carbon ones on my 29er. I saw that Carbonality is selling some wheelsets here:
    NSS M923C - GD - 29er mtb clincher wheelset - 29er MTB - Wheels
    I'd like to know if anyone has bought these and how they have held up. I'm looking for something a little on the light side but pretty tough. I'll probably run them ghetto tubeless with 2.1 tires. I do a lot of long distance XC racing so I'd like something reasonably light, but rugged.
    I've read through about 30 pages on this thread, so if I missed a relevant post, please point it out too, thanks!
  78. #2778
    Reputation: fire_strom's Avatar
    Is there a reason everyone is using the Bontrager rim strips instead of the Stan's rim strips? I know the Stan's cost more but I was just wondering if there was any other reason too.
    I am about to order the LB wider rim wheelset to run with 2.25" nobby nics. I am tempted to try to just run with yellow tape but I haven't decided yet.
  79. #2779
    4 Niners
    Dec 2008
    The Bontrager rim strips are not rubber like Stans. They are a stiffer higher strength plastic that turns the rim into a tubeless rim by having a high ridge just inside the bead seat. Tires are actually harder to push off the bead with the rim strip on these rims than on a real Stan's rim. Makes it totally secure.
  80. #2780
    MattSavage
    Sep 2003
    Quote Originally Posted by hatrickpatrick View Post
    I race them on my SSCX bike. They're super good, no problems with skinny 33c tires and a tubeless conversion. Super stiff, light, nice quality build from appearances. I bet they'd hold up well for marathon racing.
  81. #2781
    Thanks, that's the sort of info I was looking for.
    G
  82. #2782
    HatrickPatrick
    Quote Originally Posted by mattsavage View Post
    That's awesome news. Thanks for the feedback. I'll put it on my christmas list and hope. hehe...
  83. #2783
    Can anyone compare and contrast these with American Classic MTB Race 29 wheels? I've heard that the AC's are lighter, have a 24mm internal width (wider than LB) and are pretty stiff. Anyone that can confirm, refute, or add their thoughts on the comparison between the two complete wheel sets?
  84. #2784
    Oct 2007
    I've ridden both but on different bikes
    I have an older set of AC 29er wheels on my hardtail and built up a set of these with DT Swiss 240s for my fully. No contest as to stiffness. Depending on build the ACs may be lighter. I also own two sets of AC road wheels 420-aeros and Sprint 350s
    In my opinion some design shortcomings in AC hubs, which have been touted as advantages that should be mentioned:
    AC hubs have narrower flanges, which reduce the lateral stiffness of a wheel build (all other things equal). The reason given is that the wheel will use identical length spokes drive and non drive side, and will have roughly equal tensions. But having a wider flange puts a larger portion of the tension in the lateral dimension and gives a laterally stronger build. The inequality of tension between drive and non-drive sides is a red-herring.
    In addition my AC road wheels have started breaking spokes. The spokes exit the nipples at a rather extreme angle and I think this is a contributing factor along with the flexing, which causes metal fatigue. The use of proprietary nipples and spokes on my 420 aeros has been a source of unhappiness as well.
  85. #2785
    lamer
    Reputation: llamma's Avatar
    I ordered a pair of the "wider" LB rims the other day. They're estimating 15 business days to make them. I'll hopefully see them around Christmas.
  86. #2786
    There is an invoice in my inbox for a set of the wider LB wheels to be built with DT Swiss Super Comps on the d711sb/d712sb. I am only waiting to verify that at least the front hub can be converted to a through axle. A qr15 specifically. There seems to have been a recent change in the hub that allows this but I was wanting to confirm. Anyone have a recent set that can set the record straight?
    MattSavage
    Sep 2003
    Quote Originally Posted by fire_strom View Post
    Good question... Lots of the 2011 9mm models floating around. The US website shows the new one, Taiwan shows the old ones.
    Not to thread jack too much, but I'm surprised Novatec doesn't make a SS disc hub...
    Edit: Nevermind, didn't look in the DJ section. Several of them there...
  88. #2788
    Nov 2007
    Even if the hub is convertible, you still have to figure out where to get the conversion caps.
    If I were you I'd look into the Novatec D881/D882 hubs. Those are convertible for sure and you can use the Transition Bikes conversion caps for them since the Transition bikes hubs are rebranded Novatec D881/D882 hubs
    Or, your other option if you need 9mm QR now but you want to future proof is to just get a 15mm front hub and then get one of these for 9mm. It'll be heavier but that's the trade-off f
    Mountain Bike 15mm thru Axle to Standard 5mm Quick Release Wheel Adapter | eBay
  89. #2789
    MattSavage
    Sep 2003
    Quote Originally Posted by pwu_1 View Post
    I'm sure LB can get the adapters from their supplier to include with the wheelset. If not, you can probably email the US distributor and get them there.
  90. #2790
    Saw this more appropriate thread so posting here also - sorry for the duplicates.
    First off, do not expect these rims to be of equal quality as the ones built by a well-known manufacturer. All rims are manufactured in China, but the quality is not held to the same standard everywhere.
    Pros: They are cheap, they are light, tubeless tires seal quickly. The Novatec hubs are good although I've only ridden them about 500 miles so far.
    Cons: You get what you pay for. Warranty is sub-standard. The wheels are built very light and I've had spokes rip out of the nipples. They are advertised as AM - this is questionable. They are an XC rim.
    So, quickly my story.
    Ordered whole wheel in early September, received them beginning of October. I rode them for a month and broke the front rim on a creek crossing (rocky and I wasn't going slow). I'm 175 lbs, riding a 2011 SC Tallboy C with 35 psi. I rode through the creek at a good clip, hitting all the obligatory rocks along the way. I heard a loud crack, followed by a violent tire blowout, followed by a nice endo (flesh wounds only). The rim broke in 2 places, simply broke off a 20" section. The breakage was at the holes drilled in the rim. I contacted Nancy and sent in the serial # along with pictures of the break. A bit of back and forth. She now agreed to send me a new rim (not a new wheel) and I have to pay for shipping ($29). When it gets here I'll have to get some new spokes and likely pay someone to lace up the hub.
    I also spoke with a friend of mine in AZ who ordered the road rims. He told me the front was very nice but the rear should not have passed QC. Like I said... you get what you pay for. Do not expect the quality to be equal to those built by well-known manufacturers.
    IMG_20121114_182033 | Flickr - Photo Sharing!
    IMG_20121114_181714 | Flickr - Photo Sharing!
  91. #2791
    Nov 2007
    Quote Originally Posted by dhegglin View Post
    wow I think that's the first complete failure that I've seen for these rims.
    Glad you are (mostly) ok.
  92. #2792
    JMH
    JMH is offline
    Sugary Exoskeleton
    Reputation: JMH's Avatar
    Feb 2005
    I just use 1" Gorilla Tape. No need to go all Bontrager on this unless you want to. Yellow Tape worked for me but allowed a bit of seeping so I went with the burlier tape.
    JMH
  93. #2793
    Stans tape has worked fine with the Ardent 2.4 on my bike. I ride aggressively but this setup hasn't burped, not even once. Granted, this is with just one season of riding.
    I have experienced precisely one flat so far. This was because the Stans had dried out and I hadn't bothered to put more in. Something large punctured the tire so the problem wasn't related to the tubeless tape but just that there wasn't any fluid left to seal the hole. I rode home slowly, stopping to put more air in the tire about every 1/4 mile. Even when it got down to rolling on the rim, the bead never unseated.
  94. #2794
    Bad break there. What do you think an arch ex rim might have done? Big dent or roll over?
    I found a supplier that deals with novatec parts. rbopbicycles or something. I think I googled "Novatec end caps". They're in Taiwan but were good with email. Said they didn't think the older versions of the 711sb hub would take the new end caps which they didn't even have yet. I think the new version of the hubs are not yet available. I asked Nancy if she could check on their availability. If I can't get the convertible ones I may punt on the whole carbon thing and get an arch ex set on the 3.30 hubs. I think they'd be about 150g heavier than the LB wider set on 711/712's but $200 less too. I suppose I could just wait a couple months for the winter to start then end and the hubs to be released.
  95. #2795
    Greystoke
    Reputation: geo025's Avatar
    Dec 2010
    Not looking good.
    How many others have front wheel failures?
    I've opted for a Chinese front & Enve rear, my thoughts were the rear has to take a larger beating than the front, but in retrospect if I was going to break a rim I would prefer the rear.
  96. #2796
    True about the AM recommendations, I wouldn't go beyond XC in them
    So, since you're the first full catastrophic rim failure, can you explain a bit more.
    What does "good clip" mean exactly, and "hitting all of the obligatory rocks"? Is that 30mph hitting boulders, or 15mph hitting fist sized rocks, just so we can get an idea.
    I've seen plenty of alloy rims fail in similar fashion at xc races (saw a mavic rim totally taco itself last race ) but most times it's from a frontal impact.
    I've had mine for 4 months now on novatec and rotaz hubs riding only xc - done some pretty rough rides with 0 issues. Love them
  97. #2797
    The guy who broke the rim was also pulling the spokes out of the nipples so we shouldn't jump to conclusions about the durability of these rims.
  98. #2798
    Nov 2007
    Just received 2 29er wider rims that I ordered. Took about 3 weeks total, 2 weeks to manufacture(Brian told me there would be a delay since there were like 60 orders before mine) and then 1 week shipping. Both weighed in at 400grams and both measured 603erd.
    I now own 3 sets of light-bicycle wheels. 1 set in each size.
  99. #2799
    Trail Ninja
    Reputation: Varaxis's Avatar
    The guy with the break is just trying to make a point that emphasizes quality inconsistency issues. Anyone with a holistic perspective should see that.
    He's also warning that if you're the AM type, maybe the kind that likes to look for and ride rougher lines fast on purpose, that you shouldn't feel very confident on these rims. Most riders should know how much confidence is worth on the trail, in determining how daring you want to be.
    He's also implying something about the full wheel build quality, and how that doesn't guarantee a problem free wheel, with issues such as spokes pulling out of the nipples. Wheel builders should know that shouldn't happen if you use new nipples, spokes, and hand build them carefully, but who's to say that wheel was built that way?
    Warranties in the US typically means a brand is confident in their product and that you should also trust in it, as they are backing it up. In this case, I get the impression that it should be more like a "ride at your own risk" disclaimer, with a generous "crash/accident replacement" cost, rather than a warranty.
    He mentions Nancy, so you should know which factory he's talking about here, which may have some amateurs working for them and/or some poor QA standards.
  100. #2800
    All of that is possible. But with only one reported complete rim failure, should we assume the worst?
    I've personally witnessed the failure of pretty much every brand and every component while "just riding along". Does that mean that those brands have poor QA standards? Or is it that every product can break?
    Posts in this thread will help build a reputation one way or the other. But so far I don't think there are enough bad reports to constitute a bad reputation.
Members who have read this thread: 842
