Page 244 of 322 FirstFirst ... 144 194 234 240 241 242 243 244 245 246 247 248 254 294 ... LastLast
Results 6,076 to 6,100 of 8040
  1. #6076
    I would go 32 hole 30mm outside 24mm inside hookless rims about 400 grams each, give or take 5 grams. Project 321 hubs, Sapim Laser spokes with alloy nips 2 cross lacing.
    Killer wheel set, light, strong, great engagement and long lasting. Great bling factor!!
  2. #6077
    Reputation: SDMTB'er's Avatar
    Feb 2014
    Quote Originally Posted by ThrottleAbuse View Post
    Just got a hookless 29 with the 22 internal width. 28 hole and it only weighed 340 gm on my scale! Ordered it on the 7th and got it on the 26th so not bad. Looks really nice. I tried to search the thread, but I can't seem to find which rim strip is recommend. I thought I saw something about a bontrager strip fitting perfectly in these. Or am I better off just trying to seal it up with some of the stan's yellow tape?
    Just got my second set. First set for trail (AM version of hookless 29, 32 spokes, DTSWISS 350 hubs). Second set for XC (lighter version of hookless, 28 spokes, DTSWISS 240 hubs).
    First wheelset has been nothing short of spectacular. Both wheelsets built up without issue.
    New wheelset weighs 1440 grams! Lighter than ENVE M60 and 1700 dollars less. Mounted Spesh S Works Purgatory 2.3 on front and 2.1 S Works Ground Controls on back for blown out / super dry conditions here in SoCal. Bike is Pivot Mach 429 Carbon XT/XTR. Bike weight with KSLEV dropper post is 27 lbs. even.
    Anyone hesitating to pull the trigger because of the "China" thing - give me a break. Heck, even my a Pivot carbon frame is made / manufactured in Asia. If you are on the fence, do it!
  3. #6078
    Waiting for my new Frame Pivot Mach 429 in green, should be next week. It should build up at 24.5 with XX1, LB rims, Enve stem bars and seatpost. Enve rims are just way to much money at 1 k each. I wish I went lighter on my hubs "Hadley" like Project 321 or Dt Swiss 240.
  4. #6079
    Reputation: DeeZee's Avatar
    Jan 2005
    Quote Originally Posted by dgw7000 View Post
    "I wish I went lighter on my hubs "Hadley" like Project 321 or Dt Swiss 240"
    I have one set of Hadley hubs and two sets of DT Swiss 240's. If I was to do it all over again it would be Hadley for all three bikes. A few grams is worth it
  5. #6080
    Jan 2011
    Has anyone ordered from carbonbicycle.cc? Seems like the same stuff/website but a bit cheaper. Any feedback would be great.
    Carbon Bicycle,carbon frame,carbon rim,carbon wheel,carbon wheelset,carbon mountain bike,carbon road bike CarbonBicycle
  6. #6081
    Feb 2014
    Nice! Green definitely makes the bike faster ;-)
  7. #6082
    Tubeless tire mounting experiences on various LB rim profiles?
    Can anyone compare/contrast their tire mounting experiences on the various LB rim profiles? I'm specifically interested in differences among the three most common 29er versions:
    35mm hookless rim
    27mm hookless rim
    30mm "wider" hooked rim
    I have lots of experience with various tires on the 30mm external width "wider" 29er rims. I'm hoping others with experience on both those older "wider" rims and the newer hookless rims could offer observations regarding tire mounting on the hookless models.
    The 30mm external model has been OK w.r.t. tire mounting. I've tried it w/ the Bontrager strips and also with tape. Some tires (notably TNT versions of Geax) are impossible to mount, regardless of one's technique or experience. Others mount w/ some difficulty (Michelin). And in my experience none of them have aired up particularly easy.
    Do the hookless profiles represent an improvement in this regard? Anyone mounted Geax TNT on either hookless model?
  8. #6083
    May 2012
    Quote Originally Posted by InertiaMan View Post
    35mm hookless rim
    27mm hookless rim
    I just got a new LB wheelset today with 30/35 hookless rims. They were very easy in every way with Maxxis Ikon 2.35's. I used cheap tape and Stans Valves. They blew up fast and easy but I had a 105 psi 3 gal compressor and it makes a big difference.
    Before these wheels I used Giant P-XC2 wheels with the same tires. I couldn't get them to seal with tape and any valve. I finally gave up and tried the split tube technique which was real easy. Later I heard that those Giant rims are easy with Trek Bontrager strips and valves.
  9. #6084
    May 2012
    Info on tracking shipments from LB into the USA. LB ships from China via EMS. Once it gets through USA customs, USPS gets it and, in my case, deliver the next day. EMS's tracking systems stops showing progress once the package goes to customs. However, you can enter the same tracking number in the USPS tracking system and it will track your package through delivery.
    Lastly, my USPS mailman always deliver my mail around 4pm but he delivered the wheels at about 10am. I think he likes to get the bigger packages out of his truck and out of his way early. Since you have to sign for these packages, you might want to be around in the morning to do that.
  10. #6085
    Received my LB hookless 30 mm ID weelset last week.
    Used Stans Yellow tape 21 mm(leftover from a previous wheelset) and American classic valves
    I managed to put a Schwalbe Rocket Ron 2.25 on the rim with my bare hands and it was easy to inflate with a floorpump without removing the valve core and without milk.
    I still have to put in some Stan's however, the next day I have a flat tire.
    I am waiting for a Racing Ralf 2.25 and a Nobby Nick 2.35 but wich hopefully will mount as easily.
  11. #6086
    May 2012
    I've yet to report on the performance of my new 30mm ID wheelset from LB. The performance exceeds my expectations. In fact, I'd say the performance has gone from adequate to perfect. I couldn't imagine being able to notice better performance out of wheels. I was using 2.35 Maxxis Ikon tires on good but heavy 19mm ID rims and they always felt soft when inflated to the low 20's psi. If I inflated more they were bouncy. With the new wider rims I inflate to 17 front and 19 rear and the performance is rock solid in corners. The traction is better and the ride cushion is about the same.
    I was worried that the wider rims might be more vulnerable to rock damage but the tires are still much wider than the rims. The max width of the tires is 61mm and the rims are 35mm wide.
    Climbing up steeper hills I feel a little more resistance. At first I thought it was because of less flex in the wheels but now I believe it is from better traction. When my tires would slip a little it kinda feels like a lower gear. Now that they are slipping less it feels like my lowest gear is higher. I didn't notice them slipping before but I am getting better Strava scores than before.
    Downhill I feel a big improvement. It feels like I have much more precise control and it is easier to make sharper turns with these wheels.
    I haven't noticed any flattening of the profile but my Maxxis Ikon tires have a very round profile. Also, the widest point has gone from 57mm to only 61mm in spite of the increase in ID of 11mm which is more than 50% (19mm to 30mm).
    I've only been mt biking a couple of years so, although I try to be accurate and helpful, take anything I say with a grain of salt.
  12. #6087
    Aug 2013
    I was thinking of getting the light-bicycle 650b rims and building a light wheelset around them.
    But then i found a rather good deal for a wheelset with Duke rims. The price would be about the same and the duke rims are somewhat lighter. Duke seems to be some small french company, and there has been some good results in competitions with their rims.
    Anyone has any experience with said rims? They are tempting to get, but im kind of concerned about the durability, as i would use them very regularly for training and xc racing.
  13. #6088
    74 & 29 pilot
    Reputation: MTB Pilot's Avatar
    Oct 2010
    Quote Originally Posted by SDMTB'er View Post
    Hey what did your first set weigh; I assume you used the 35mm wide rims?
    MTBP
    "GIVE ME LIBERTY OR GIVE ME DEATH!"
    Turn on the truth: http://www.ronpaulchannel.com/
  14. #6089
    74 & 29 pilot
    Oct 2010
    Hey folks, I've used the Chinese carbon rims in 27.5 and Derby's wide rims in 29, and have a set of 27/22mm LBs on order for a lighter, stiffer set on my LES. I'm thinking of order the 30/24mm from the link above to replace the Derby's, trying to shave .30-.50 lbs, but I can't decide on the hubs. I think the Project 123 or I9 are the two I'm trying to choose between. Bling is not a factor. I can't figure out what the difference is though, same price and internals, but the 123 has a 3 year warranty.
    Anybody got anything to convince me to go with one or the other?
    MTBP
  15. #6090
    Feb 2014
    (Cheap) Chinese Carbon Rims?
    Quote Originally Posted by MTB Pilot View Post
    About 390 grams for each rim. Didn't order the 35mm wide ones. Just these:
    http://www.light-bicycle.com/bead-ho...l#.U7t4bNq9KSM
  16. #6091
    Apr 2013
    Those are the 27mm rims. Most guys here seem interested in the 35mm rims.
    Just thought I would mention.... Broke a spoke nipple over the weekend racing. Got a replacement on the way home and pulled everything apart to sort it out. While I had it apart I checked out all the nipples for corrosion. All looked good including the broken one. My wheelset is almost 6 months old. So even if corrosion shows up after a year, you could just swap out all the nipples for new ones.
  17. #6092
    MTB Pilot,
    Go with the new Pro 321 hubs, they do share the same 120 points of engagement drive system, but the Project 321 use angular bearings and have adjustable preload with better end caps. Better anodizing also, and better Warr. They are both great companies, but I think Project 321 rear hub is now better, and about the same weight.
  18. #6093
    74 & 29 pilot
    Oct 2010
    MTB Pilot,
    Cool, thanks! I was kind of leaning that way, and will probably be the end result.
    MTBP
  19. #6094
    Also I like the Sapim laser spokes or CX Rays if you have the money, 2 cross for 29er carbon rims with alloy nips. Just my opinion!! Makes for a killer light weight/durable wheel combo.
  20. #6095
    Quote Originally Posted by rusto View Post
    I put in my order. 2/353.90
    Leadtime 10 days.
  21. #6096
    74 & 29 pilot
    Oct 2010
    SWEET! I'll look into them. The wheel set I'm trying to replace, I built with Derby wide rims(455g) DT Swiss 350 hubs, DT Swiss Comp DB Spokes and alloy nips. They weigh 1910g with valves and tape, which isn't bad for a wheel that could be used in a DH race, but for my everyday chunk, I want something still quite durable and lighter.
    THANKS!!
    MTBP
  22. #6097
    Yea, that's not bad!! My 30mm outside width, hookless 29er 32 hole LB wheels with Hadley hubs and Sapim Laser spokes and alloy nips, tape and valves came to 1798g. Your Dt Swiss 350 hubs are lighter than Hadley. The 240 DT Swiss are way better than the 350 and are made in China that's why the 350 are so inexpensive. How are the bearings holding up? Getting ready to put them on my new Pivot Mach 429 carbon "green" the frame just came in!! Can't wait. The Derbies look like nice rims !!
  23. #6098
    May 2014
    The 29" carbon wheelsets i got from China are NICE!!
  24. #6099
    Has anyone had any experience with the iPlay rims, or is there a separate thread for these?
    Lapierre XR29ei, Chris King LB Carbon, XTR 1 X 10
    Planet X Dirty Harry
    Chiner 29er SS
  25. #6100
    74 & 29 pilot
    Oct 2010
    The Derby rims are great, but I want to use that set for more gravity, super chunk as they are quite beefy at 455 grams. The 350s are great hubs, just 30-60 grams heavier, due to the hub body that is maid in Taiwan, not China. I've never had problems with the bearings on all three sets of wheels that I run them on, but I live in the desert and don't wash my bike as much as most. I use a 36 or 54 tooth star ratchet in all my 350s just like the 240s, so not worth the money since they aren't rotational weight.
    Welcome to the 429 team green club. Best bike I've every owned and makes up for the Kawasaki dirt bike I never got when I was a kid!
    MTBP
