Page 2 of 88 FirstFirst 1234561252 ... LastLast
Results 101 to 200 of 8740
  1. #101
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Quote Originally Posted by indyfab25 View Post
    It is what they call the AM rim. I do not know what the other rim bead looks like.
    Did you guy weigh the rims and wheels after you'd built them up? What spokes and hubs did you use? Any problems with th wheel builds?
    How are they holding up?
  2. #102
    Reputation: bholwell's Avatar
    Oct 2007
    Quote Originally Posted by Le Duke View Post
    Ah. The "XC" rims definitely do not appear to have a "UST" profile.
    The "AM" rims do, though.
    The AM rim might look closer than the XC rim to UST, but neither rim has a UST profile.
    The bead shelf diameter is the most critical dimension that plays a role in tubeless compatibility, but this is not shown in either drawing.
    Tire Design & Development Engineer. The opinions expressed in this forum are solely my own.
  3. #103
    Jan 2009
    Light Bicycle XC 29 Rims with what they told me was the 'old' slightly beefier lay-up (415g). I should add, that I used nylon strapping tape for rim strip (my usual), and got them running tubeless without any problem.
    Tires
    F: Specialized S-works Ground Control 29x2.1
    R: Maxxis Ikon 29x2.2
    American Classic hubs.
    F: 32 hole, QR15
    R: 32 hole, 142x12
    Spokes: Sapim CX-Ray, 3x, all 292mm
    Didnt weigh after build with Sapims. The math says high 1400's.
    Im 210lbs, theyre on my Niner Rip9. I gave them another bashing the other night and all is still well!
  4. #104
    Got A Lust for Life...
    Reputation: indyfab25's Avatar
    Quote Originally Posted by meltingfeather View Post
    Do you mean the Park tensiometer? or 2.0mm on the DT Swiss meter?
    Also, the reading is meaningless without the spoke gauge in either case.
    You are right. Park. DT Competition. Brass nips.
    Would you have built them differently?
    I am immune to your disdain.
  5. #105
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    I probably would have taken the tension a bit higher.
    20 on the Park TM-1 = 94 kgf if you're using the 2.0/1.8 Comps
    I'd probably go to 21.5-22.
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
  6. #106
    Oct 2007
    vwn8 can you confirm an ERD of 603mm
    I guess I could back it out of for 292mm spokes. Just too lazy. I'm considering the XC rims for a build, if I an get some hubs cheap.
  7. #107
    subscribed
  8. #108
    Quote Originally Posted by Jwiffle View Post
    I think our "argument" was kind of silly. In my original statement, I was responding to what tension should be used, and I mentioned I would use a normal to slightly high tension of 120-125 kgf. But I can see how you took it as relating tension and wheel stiffness. Which I was, and generally, I was wrong on that aspect.
    10-4
    I have seen wheel manufacturers state that the high tensions they allow make for a stiffer wheel (Koolstof for one).
    I have also seen this error made by reps for manufacturers. unfortunate...
    I did find a site with various tests and theories that state that spoke tension does play a role in wheel stiffness. Great wheel test Part 3 Stiffness | Roues Artisanales Their data asserts that "high tensioned spokes...delay the moment when the wheel loses all its stiffness." If I'm understanding them correctly, they're saying that the higher tension doesn't necessarily add stiffness, just keeps it from losing stiffness under load (i.e., keeps the side being de-tensioned under load from going slack, causing the loss in stiffness).
    That's why the qualification, "as long as no spokes go slack" is usually applied to the statement that stiffness is not affected by tension.
    They are clear in separating the two, but I think the way that they tied them together can contribute to confusion.
    Normal bike wheels are not designed to get to the point of slack spokes. They become very unstable and often buckle under that condition.
    Brandt does, though, state that spoke thickness plays a part in the stiffness of the wheel.
    Spoke gauge does affect stiffness because it affects the elasticity of the spokes.
    I think, though, that we were more in agreement overall than not. 180kgf is too high to build a wheel, and normal tension in the 120 kgf range should be fine.
    agreed.
  9. #109
    I just purchased a set of the Light bicycle 29er AM rims (155 each). I put them on the scale. 380 Grams. They look identical to my Specialized Carbon Roval SL rims. I'm lacing them to Chris King hubs. I'm curious to see how they compare.
  10. #110
    I live to bike
    Reputation: Jwiffle's Avatar
    Quote Originally Posted by Cantbeataktm View Post
    Whoa, that's light. And quite a difference from indyfab's 440g.
    Let us know how they do! I'm still waiting on mine.
    Stop in at Element Sports. www.elementsport.com
    Get Out! Have Fun!
  11. #111
    Reputation: figo's Avatar
    Interesting weight difference, what kind of finish did you get?
  12. #112
    Reputation: ne_dan's Avatar
    Can you get a picture of the 2 next to each other?
  13. #113
    mvi
    mvi is offline
    Quote "Spoke gauge does affect stiffness because it affects the elasticity of the spokes."
    I understand where you're coming from and appreciate your posts.
    Any idea though why the wheels in Paris Roubaix supposedly are laced at a low tension?
    Probably the hardest stressed wheels in racing and I'm sure the spokes would almost go slack on the cobbles. (1 day wheels until the next year).
  14. #114
    Reputation: Brisco Dog's Avatar
    How long did they take to arrive? Are you setting them up tubeless?
  15. #115
    Would love to see pictures of some of the wheel builds you guys have done.
  16. #116
    No kidding. That is cool.
  17. #117
    Reputation: two-one's Avatar
    Quote Originally Posted by mvi View Post
    Hmm, never heard of that... but I speculate it might be something like this:
    I always got the impression that wheels with higher spoke tension seems to transmit (or cause) more high-frequency vibrations, giving you the "feeling" that you're hitting objects harder. This can be wrongly interpreted as a stiffer wheel. For the cobblestones of Paris Roubaix, this kind of vibration or resonance is highly unwanted, and as wheel longevity is not that important, they might just lower tension.
  18. #118
    please let us know how these wheels are doing. I have a set of the carbon Rovals on order, scheduled to ship late Feb and am tempted to cancel that order and build up a set of these to try instead.
    Do you know the weight of your wheels?
    www.quinnphoto.smugmug.com
    07 S-Works Enduro SL - Sold
    08 Epic Marathon - Sold
    2012 Stumpy EVO 29er frame up build
  19. #119
    I've never heard that either and I don't believe it. There are a lot of things that "supposedly" happen that don't make any sense.
    One explanation could be that teams tend to use higher spoke counts on Roubaix wheels, which drives down the required tension, but that's not what it sounds like you said at all.
    lol - they are one day wheels... no next year about it.
  20. #120
    Our test set was having a bit of trouble tubeless so I threw a Bontrager Rythm rim strip on the 28 hole rim we have. It fit perfectly. I see no reason the rims would be bombproof tubeless with that strip.
  21. #121
    Did it burp in the corners? Or lose air?
  22. #122
    Quote Originally Posted by two-one View Post
    No idea. Our "tester" isn't really saying much about it. He seems to not want to share information and perception about them. Kind of defeats the purpose of being a "tester."
  23. #123
    I live to bike
    If you can manage to get some details out of your "tester," we'd appreciate it! What tires, what pressures? Sounds like you had it initially sealed? problem was when riding?
    I'm hoping to just be able to use just some of Stan's 25mm yellow tape rather than having to use a strip.
    Get Out! Have Fun!
  24. #124
    May 2010
    I volunteer to be a tester. I will talk till you tell me to shut up. email, fax, text messages. Feedback I will give you feedback....
    Here's to sweat in your eye.
  25. #125
    I will post pictures once they are built. I got the matte finish. She sent them out on a Friday, and i recieved them the following Wednesday. Full replacement warranty is good for a year.
    Sent from my GT-P7510 using Tapatalk
  26. #126
    I live to bike
    I've heard of the practice, supposedly softer tension on the wheels makes the ride more comfortable. Brandt explains in his book that soft tensioning the wheels doesn't affect their comfort, just makes them weaker. But as we know, misconceptions die hard, so I wouldn't be surprised if they're were a few mechanics or racers soft-spoking the wheels. ('course, maybe that helps explain some of the carnage?)
    Get Out! Have Fun!
  27. #127
    Anyone that ordered the "wider" version of the carbon rims from Light-Bicycle have the effective rim diameter dimensions handy?
  28. #128
    And He was Not
    Reputation: Enoch's Avatar
    this thread needs some pictures
    The Truth is out there. Here it isThe TRUTH
  29. #129
    I Agree! ^
  30. #130
    Yes please ^^^
  31. #131
    Had the Hans Damp PSC blow off the rear rim last night. Taped up and that was it. I installed this Nobby Nic two days ago without sealant with the Bontrager Rhythm symmetrical strip with a Stans valve. This morning I tried to get the tire to lose air. This is with less than 10psi in the tire. No air was lost when I did this.
    I understand the want for a simple tape up. I feel the strip is a bit better, easier, and more bombproof. It essentially turns the rim into a UST rim. I say essentially understanding that it is not a true UST. This test is encouraging. Snap the strip in, throw a tire on, inflate...good to go.
    Our tester "isn't the kind of rider that can tell the difference in ride quality." However, he does ride very heavy, plowing into things seemingly on purpose. Great for reliability testing, but not for ride impressions. We'll have a set soon that I can get out and ride and get back to you guys about spin up, tracking through rock gardens, vertical compliance, etc. By the way, that is old sealant from another setup.
    Attached Thumbnails Attached Thumbnails (Cheap) Chinese Carbon Rims?-p10005481.jpg
  32. #132
    Reputation: metrotuned's Avatar
    @Indyfab: LOL "However, he does ride very heavy, plowing into things seemingly on purpose." That describes my riding!
    Producer, Actor Will of the Sun, Author Platform Pedal Shootout 900K+ views
  33. #133
    Missouri sucks...
    I'm going to buy a set of the "AM" rims next paycheck. All this reading, 6 PAGES, and there's not really very much info I'm sick of waiting I'd really like a set of ENVEs since they're tied and trued but come on... $300 for a PAIR of carbon rims is cheap enough to give it a go.
  34. #134
    Reputation: Stugotz's Avatar
    Dec 2011
    Deleted
  35. #135
    I'm going to say what I was thinking (and probably everyone else!)
    I'm tempted to get some capital, buy a bunch. Lace them, put stickers on the them and re-sell them!
  36. #136
    I live to bike
    Quote Originally Posted by gcavy1 View Post
    It certainly crossed my mind! (They'll even put your logo on them for you!)
    Get Out! Have Fun!
  37. #137
    Missouri sucks...
    What I want to know is how close to say, a Roval are they? I know ENVE, Reynolds, Easton, etc. are made in house and tested like crazy but Specialized obviously outsources theirs. Are these as good as theirs and they just mark them up or are these junk? That's what makes me hesitate. When product "A" is $800 and product "B" is $300, product "B" CAN'T be as nice! Or can it???
  38. #138
    I live to bike
    Quote Originally Posted by DFYFZX View Post
    I guess that's what we're all wondering. I'm going ahead and taking the chance on them.
    I guess I'm looking at it this way: "When product 'A' is $800 and product 'B' is $300, is product 'A' really THAT much nicer than product 'B'"? I don't expect these to actually be as nice as Enves or even Rovals, but if they're close, and hold up under my riding (which I'm not that hard on wheels, so I expect them to), I'll be happy for the much lower price.
    Get Out! Have Fun!
  39. #139
    Missouri sucks...
    I just ordered a set Last years bonus randomly hit my account at 0200! I'll post pics when I get them.
  40. #140
    Reputation: ktm520's Avatar
    Did you order the wide or narrow rims? I'm right on the edge of ordering a set of the wide rims.
  41. #141
    What hubs you guys throwing on these?
  42. #142
    Reputation: freebiker's Avatar
    Mar 2006
    duh
    never mind
  43. #143
  44. #144
    Was this with the narrow or wide rim?
  45. #145
    Reputation: DeeZee's Avatar
    Jan 2005
    Caution;  Merge;  Workers Ahead! Matte finish
    If you order the matt finish most likley the inside of the rim will be unfinished.
    If you plan on running these tubeless with just the rim tape make sure any exposed carbon has been brushed / sprayed with epoxy. Stans etc....will cause the CF to fail.
    I just ordered another pair with matte on the outside and gloss (finished) on the inside
  46. #146
    I live to bike
    Quote Originally Posted by DeeZee View Post
    Never heard about Stan's hurting carbon. I'll send them an email, see if they can gloss the inside since I ordered matte. Thanks for the heads up
    Get Out! Have Fun!
  47. #147
    May 2005
    Thanks for the tip on the finish options.
    I'm ready to order same, but not sure about spoke count. I'm 210 and with normal wheel I would 32, but is it really important with carbon rim ?
  48. #148
    Missouri sucks...
    I bought the wide, matte, UD finish...
    Going to throw a DT 240s on the rear and American Classic 15mm thru axle front. If you buy light rims you have to go with light hubs Probably Sapim CX Ray spokes...
  49. #149
    Quote Originally Posted by Surfdog93 View Post
    I would still use 32 spokes.
  50. #150
    Reputation: dookiedoodle's Avatar
    Can anyone actually riding these Light-Bicycle Carbon rims comment on the durability? I have read posts from Haven Carbon owners of how bombproof their rims are, bike falls off a car at 70MPH, pinch flatted tubeless, etc. without any rim damage. Any similar stories?
  51. #151
    Jan 2005
    Tire mounted
    Tire when on just like on my old Stan's flow rims...........
    Attached Thumbnails Attached Thumbnails (Cheap) Chinese Carbon Rims?-gavin-007.jpg
  52. #152
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Looooong time ago 'soft spoking' was believed to give a more compliant ride.
    Not so much...
  53. #153
    I think I'm canceling my carbon Roval order and building up a set of the 28mm AM rim on some AC hubs. For the price difference it's worth the risk.
    Any pics of the UD finish other than the company pics?
  54. #154
    I live to bike
    Ok, now how did you you just order the rims 10 hours ago and now have them delivered, built, and tire mounted?
    Get Out! Have Fun!
  55. #155
    I live to bike
    Oops, hit return too quickly.
    Nice to see they played well with the Stan's tape!
    Get Out! Have Fun!
  56. #156
    Jan 2005
    I ordered additional rims
  57. #157
    Missouri sucks...
    DeeZee: how's the finish/quality hit you? Impressed? Not impressed? How's the confidence level? I already ordered a set so I guess I'll see for myself, just excited to know more about them
  58. #158
    And He was Not
    Did they cut a shipping break for additional rims?
    We are thinking of getting a couple of pairs.
  59. #159
    Jan 2005
    Per my buddy the same / better than his Rovals.
    Here is a zoomed in pic
    Attached Thumbnails Attached Thumbnails (Cheap) Chinese Carbon Rims?-gavin-005.jpg
  60. #160
    Missouri sucks...
    Sweet!
    By the way, I messaged Nancy and she said she's going to get my matte/UD rims clear coated in the rim bed
  61. #161
    Reputation: dancruz's Avatar
    Mar 2006
    Keep the pics and comments coming!!!...very close to pulling the trigger...
    Just ride and quit bit$hin.......Yeti SB5+..SIR9 SS...CD Synapse DA...
  62. #162
    I live to bike
    Sorry. I was trying to be funny. Guess I wasnt
    Get Out! Have Fun!
  63. #163
    Hmmm very tempting
  64. #164
    Couldn't resist, just ordered a set of wide 32h/matte/ud.
  65. #165
    Front Range Cyclist
    Reputation: juansevo's Avatar
    Ditto. There is absolutely no reason Stan's would hurt carbon. At all. Urban myth.
    In the immortal words of Socrates..."I drank what?"
    Facebook.com/monstercrosser
    Twitter: @monstercrosser
  66. #166
    Formerly of Kent
    DeeZee:
    Are those spokes straight gauge?
    I'll be going to Revo route; just trying to figure out how much these things will weigh with DT 240s 10mm hub, Revolutions, etc.
    (I'm planning on ~400g rim, 280g+/- for the hub, and 125g for the spokes/nips, 25g or so for tape and valve. 830g total.)
  67. #167
    Jan 2005
    DeeZee:
    DT straight gauge with alloy nipples
  68. #168
    Why in gods name would you use straight gauge spokes?
  69. #169
    Jan 2005
    Quote Originally Posted by anomaly View Post
    Just checked my invoice and the work order indicates DB spokes
    The shop has some explaining to do........I need to pay closer attention to these things.
  70. #170
    ang
    ang is offline
    Subscribed.
    Greetings from Hong Kong, looking for more info for 29er carbon rims.
  71. #171
    Not by any chance the same lbs of the previous build with the cracked rim was it?
  72. #172
    For the guys that have recieved rims in the states, how long did it take for them to arrive once they shipped?
    I don't see any reason why tire sealant would degrade the carbon/epoxy matrix, but I've got a few contacts that are M&P composites experts that will verify.
  73. #173
    Jan 2005
    Quote Originally Posted by figo View Post
    No another mental giant
    Coincidence or are most bicycle mechanics dopes?
  74. #174
    There must be many good places out there, but I started building my own wheels when I found out a highly recommended local wheelbuilder had used loctite on my wheelset 12 years ago
  75. #175
    Jan 2005
    I am almost there.........I do everything else except wheels. Rebuild hubs etc..
  76. #176
    Can these rims be built with I9 hubs and spokes?
    hispanic mechanic
    Reputation: sslos's Avatar
    I'm admittedly biased, but some of the smartest people I know I've worked with in the bike industry.
    That being said, since the majority of people I've met are not very smart, so by extension, most bike mechanics are probably not the top of the heap either.
    Back to the topic at hand, I'm almost curious enough about these to order a set and do some "destruction testing" on them under one of our, um, less graceful customers at the shop.
    Los
    Whiskey is my yoga.
    dongerparty.com
  78. #178
    I live to bike
    Btw, although they don't have anything listed on their website under carbon handlebars (it says site under construction), they apparently do have some available. I emailed about them, and Nancy sent me pics of 4 different models: a riser (about 1.5 - 2 inch), a flat bar, and two styles of stem/bar combos. I asked about the widths of the flat bar, but they don't make them as wide as I was looking for, so I passed on them (they only make the flat bar up to 660mm wide, not sure about the riser or other bars).
    Get Out! Have Fun!
  79. #179
    High Alpine Adventure
    Reputation: DaGoat's Avatar
    Quote Originally Posted by rocwandrer View Post
    "Tow" is a noun meaning a bundle of filaments. UD is a noun abbreviation meaning unidirectional. unidirectional fabric is made from tows, which are by definition unidirectionally oriented. The tow size is much less important with unidirectional fabric, but still a mfg parameter.
    I see you edited your reply, but if i understood correctly, the issue is that T800 is a high, not standard modulus product in Toray product nomenclature.
    Bump +1 to you Roc on da Rep and to subscrib! God I love this type of detailed Tech Discussion!
    Dug-Da-Goat
    Something changes at 12,000'
    ...so welcome to the Odyssey!
    Building your trails at FooMTB
  80. #180
    Jan 2005
    Quote Originally Posted by sslos View Post
    Los
    You are right and in this case I AM THE DOPE.
    After careful review the spokes are DB
    2.0 x 1.8 DT Swiss
    My mistake was the last DB wheelset I had were Wheel Smith and has a more noticeable step down. These are more gradual.....
    My apologies
  81. #181
    Reputation: mtbnozpikr's Avatar
    This is a very interesting thread I think worth following.
    2012 Intense M9
    2012 Pivot Mach 5.7 Carbon
    2008 Look 595
    2007 Custom Litespeed Sewanee
  82. #182
    the train keeps rollin
    Reputation: snowdrifter's Avatar
    so where is the best place to order wide rims in 32h?
    beaver hunt
  83. #183
    Dec 2010
    The ones I have come across are dopes. The thing is, they think they know everything, and seem to have a "holier than thou" attitude. I would love noting more than to support any LBS, if there was one adequate and competent.
    I'm in the same boat, building wheels is the only thing I don't do. I have the tools, have tried a couple times, but not quite there yet.
    Also, thanks for the info and pics of the rims
  84. #184
    I live to bike
    Quote Originally Posted by snowdrifter View Post
    just go straight to their website light bicycle-carbon frame,carbon rim,carbon wheel,carbon wheelset,carbon mountain bike,carbon road bike When I ordered a week or so ago, they were still working on the website ordering process, but you just send Nancy an email and she'll take care of you.
    Get Out! Have Fun!
  85. #185
    Trucking & Extortion
    Reputation: RFXR's Avatar
    Anyone know the ERD on the XC or AM rims? I tried emailing light-bicycle and never heard back. Also, will these work with I9 spokes?
  86. #186
    Reputation: 7HVN's Avatar
    Anybody get complete wheelset?
    Wide cabon hoops, Novatec hubs, and Pillar spokes?
    might be worth a try.
  87. #187
    Missouri sucks...
    Quote Originally Posted by RFXR View Post
    I was told the ERD on the AM version I ordered was 603. Don't know about the XC...
  88. #188
    Just ordered a pair. 3K, matte, 32 hole. Building them on AC hubs with DT Supercomps. Can't wait!
  89. #189
    I live to bike
    I was told 602 on am rims, but i imagine either number will work.
    Get Out! Have Fun!
  90. #190
    Confirmed. Just got an email from Nancy this morning.
    ERD AM - 602
    Max spoke tension - 180 kgf
    I also heard back from my M&P contact. There is no reason why tire sealant would degrade the carbon/epoxy of these rims.
    For those who have built up these rims, how much spoke tension did you use?
  91. #191
    Anyone order rims using their website? The shipping seems too low; like it did not calculate correctly.
  92. #192
    So has anyone taking the AM rims off 6' to flat yet?
    beaver hunt
  93. #193
    That is dumb on any bike.Well, trials aside.
  94. #194
    Ok, sorry.. 12" to a tranny.
    beaver hunt
  95. #195
    We have a guy here that has been beating on them. He is a strong rider that rides like a bull. So far, so good.
    Thanks for getting me excited by the way.
  96. #196
    Are these the matte finish?
    Are you a road biker that likes hills? Try this Michigan Mountain Mayhem.
  97. #197
    hispanic mechanic
    I think they're doing this on "RuPaul's Drag Race."
    Sorry, couldn't resist!
    Los
    Whiskey is my yoga.
    dongerparty.com
  98. #198
    Picked up a Highball today
    Hello
    Has anyone calculated the frame angles on this company's carbon fiber mtb 29er frame?
    Which namebrand frame is it similar to geometry wise?
    Carbon fiber hardtail 29er frame for $399! Crap, I just picked up a Highball frame today. For what I paid for the Highball frame, I could pick up this company's frame and be close to a XT level comple bike.
    Any thoughts/experiences on this company's carbon fiber frame?
  99. #199
    Dec 2010
    Quote Originally Posted by misooscar View Post
    Hello
    Wrong thread dude
  100. #200
    Quote Originally Posted by mucky View Post
    Wrong thread dude
    Indeed. I will say that I have about 12 hours on one and it is awesome. Highball quality? Probably not.
Members who have read this thread: 720
