• 11-28-2014
    eb1888
    Originally Posted by BartP View Post
    Im not sure to go with the 27/22 or 30/24mm rims for my rigid HT. I prefer the 2.2 Ikons and the 2.1 RR and Thunder Burt tires. Weight is not an issue just curious how my rather narrow tires wil handle the 30/24 rim.
    Thunder Burt will be a little wider in one 2015 model. 2.2 XR1 Team Bontragers work very well on my 35/30mm.
    Attachment 942551
    Not that wide.
  • 11-29-2014
    TheKaiser
    Yeah, I would say go for the wider ones too, the reasons being:
    1. I wouldn't call 2.2 Ikons narrow by any stretch of the imagination. If you said you were running 1.9 or 2.0 then that would be a bit different.
    2. Both the Ikon, the RR, and the TB have a fairly round profile with evenly distributed small knobs. This will prevent the "edgy" feeling that an already square is profile tire can generate when you make it even more square with a wide rim.
    3. Evenly distributed small knob tires seem to benefit even more from low pressures than more aggressive, big knobbed tires, IMHO, so assuming wider rims allow you to run lower pressure, then you have even more to gain.
    4. Based on the specs, the 30/24 LB rims have an extra .5mm sidewall thickness above what their other models offer which should make them more durable on rock strikes, all else being equal.
    I hope that helps!:)
  • 11-29-2014
    TheKaiser
    Originally Posted by jlian View Post
    LB is starting to make 38mm outer 29er rims in a few weeks. Here is the profile for anyone interested:
    Attachment 942032
    Thanks for posting this, I hadn't heard about these yet! They look like they could be a sweet option for those "wider is better" folks, particularly those who ride in rocky areas. Stating the obvious, when compared to the 35-30 rim they only gain 1.6mm of ID, with most of the additional width coming not from the ID but from increased sidewall thickness. These things have around .8mm of additional material in the most vulnerable rock strike zone, which seems like it could be good.
    Also, from the profile, they appear to have a bead "hump" on the inner bead seat area, which should help with burping, although I would want to see this in person as other LB rims have shown variations on this in the blueprint but it doesn't seem to make it through to production on some.
    A lot of these characteristics are reminiscent of Derby's rims, although they don't look like direct knockoffs, which is good, and the dimensions slot in right in the middle of Derby's offerings.
    Did they give you any weight figures???
  • 11-29-2014
    jlian
    The weight info from LB is "around 430g+/-15 standard version, and 480g+/-15 for dh riding version". The 430g number looks to be not quite right as its 35/30 rim is spec'ed at 420g+/-15. As it is still pre-production, I don't count them as the final numbers.
    There is also the following reply to a recent question on LB's 29er rim page:
    35mm wide 29er rims beadless for bicycle trail or mountain bike enduro with tubeless compatibility Light-Bicycle
    Currently, we have started the rim mold of new hookless 38mm wide 29er rims. It is ok to work with 3.0’’ tyres. Do you like? Attached is the rim cross-section drawing.
    RM29C14 (38mm wide 29er AM rim) hookless: USD185/pcs
    RM29C14 (38mm wide 29er DH rim) hookless: USD193/pcs
    I would have gone with LB 35/30 rims for my 29er wheels (I built my first set for 27.5 using the same 35/30 width rims). This new rims would seem to be stronger with thicker side walls.
  • 11-30-2014
    BartP
    Thanks for the advice guys! Only hardpack here. Decided to get 2 pcs of the 27/22mm rim and 1x 30/24. Wil start to build the 27/22 set and use the other rim for a spare or extra front wheel later on. My first rigid build so not sure what to expect :)
  • 11-30-2014
    TheKaiser
    Yeah, that does look a little light considering that they are both wider and have greater sidewall thickness.
    Hopefully they didn't try to remove any weight from the spoke bed to compensate!
  • 12-04-2014
    In2falling
    They are 32mm deep also, which is 12mm over their original and 7mm over their current wide 29 wide. Which means shorter spokes and stiffer wheel.
    Damnit :), now want to replace my originals with these :). Pair these up with Novatec D541/D542 or Factor hubs which have tall flanges you will have some stiff wheels. Won't be light though :).
  • 12-04-2014
    RojoRacing53
    Just ordered a pair of hookless 24mm inner 30mm outer rims and a pair of 30mm inner and 35mm outer rims from light bike. The 35mm are going to be matte 3k weave with orange decals like my original set from last year so with the little extra work they estimate a 9 day lead time.
    I'll be using Orange Industry Nine Torch Hubs, half orange and half black Sapim Cx-Ray spokes and Half orange half black Alloy nipples.
  • 12-04-2014
    rusty904
    I have the 35/30's now from carbonbicycle.cc (seem to be exactly the same as the LB ones) I really don't think I need anymore width but some sidewall thickness and a "bead hump" would be some nice extra security.
  • 12-04-2014
    eb1888
    Sound good...and...colorful. I'd like to see the pics, but I will not build carbon with aluminum nips because of galvanic corrosion.
  • 12-04-2014
    RojoRacing53
    Well here's my original wider hooked rims from last year and the new ones will basically look the same except for the wider rims and giant pinecone of an 11speed cassette.
    Attachment 943959
    Attachment 943958
  • 12-04-2014
    Ratt
    Attachment 943959
    Attachment 943958
    Sweet
  • 12-04-2014
    Alias530
    When I select the XC rim you can choose "cross country" or "all mountain", which gives you a different price than selecting "all mountain" rim to begin with. What's the difference? An extra layer of carbon? Why does it cost more than the all mountain rim that probably has more carbon than the XC rim to begin with?
  • 12-05-2014
    usn.mustanger
    Re: (Cheap) Chinese Carbon Rims?
    E-mail them and ask. LB is actually quite responsive and helpful via e-mail.
  • 12-05-2014
    Alias530
    They were not helpful. They didn't seem to understand the question, even with screenshots.
  • 12-05-2014
    TedS123
    The XC rim is the 27 mm outside width/ 22 mm inside width rim. They offer that rim in "cross country" weight (~360g) and "all mountain" weight (~390g) with some added carbon for extra strength. The All Mountain rim is a wider rim.
    Sent from my VS980 4G using Tapatalk
  • 12-06-2014
    usn.mustanger
    That's unfortunate. I had the exact opposite experience with them. They quickly replied to all of my questions (as a mechanical engineer, I had a few...) with solid information. Who from LB replied to your inquiries?
  • 12-06-2014
    J273
    Without reading the whole thread. Has anyone had a set of LB and nextie rims side by side? are they pretty much the same and would you say they are from the same factory?
    Is one rim better quality than the other?
  • 12-07-2014
    Lore
    Hi,
    Going to get a pair of LB 27 mm carbon rims for my new Lynskey Pro29...
    How good is their standard build with Hope hubs? Would I need to send them to my wheelbuilder to tension or can I just use them as they arrive?
    Or is it definitely better to just take the rims and have them laced here?
    I'm 150 lbs and will run 2.2 Race Kings tubeless...
  • 12-07-2014
    TwoTone
    Originally Posted by Lore View Post
    Hi,
    I would personally have them laced with a local builder, but that's me.
  • 12-07-2014
    In2falling
    Hi,
    They are not very good at building wheels :). Spokes on my set of 29ers from them where 5mm too long and had to buy new spokes and get them rebuilt. Also had issues with aluminum nipples and massive corrosion after 6 months. I would just buy the rims then go find a good wheel builder and get them built using brass nipples.
  • 12-07-2014
    SDMTB'er
    3 Attachment(s)
    Here is my Pivot M6 with new LB wheels. I purchased the hubs separately and had my LBS set them up tubeless.
    Attachment 944907
    Attachment 944908
    Attachment 944909
  • 12-07-2014
    Lenny7
    Attachment 944907
    Attachment 944908
    Attachment 944909
    What weave are those?
  • 12-07-2014
    SDMTB'er
    The 12k
  • 12-09-2014
    Lore
    Thanks for the suggestion...
  • 12-11-2014
    abelfonseca
    Are there many of you guys running these rims with alloy niples, or is everybody using brass. I laced mine with alloy. Should I expect them to fail from corrosion soon?
    I wasnt aware of this galvanic corrosion issue until someone recently pointed it out to me.
  • 12-11-2014
    dgw7000
    Anyone know if there making 35/30 29er rims with the new profile U shaped like 38mm wide, I really like that deeper U shape profile. The older shape looks like a alloy rim to me. Also anyone looking for great tires for there rims the Bontrager XR4, XR3, XR2 Team Ussue 29x2.30 some of the best time I now use. Light,durable, great predictable traction. Fast rolling. Only drawback is getting them!!
  • 12-11-2014
    yourdaguy
    Depends on your environment and how often you wash your bike. I started having failures around 2 years. Just rebuilt 6 wheels in the last 2 weeks as a winter project. I had already rebuilt 2 previously.
    Sent from my G3 using Tapatalk.
  • 12-11-2014
    TwoTone
    I have a deep creak crossing so at this point the weight savings or color wasn't worth it to me. The last wheelset I had built and the one that's coming up both use brass.
  • 12-11-2014
    eb1888
    I built mine with brass nipples and stainless washers. And Permatex Anti-Seize.
  • 12-11-2014
    freebiker
    rims are great but stop there. support/invest/trust your local wheelbuilder
    Not surprised on lb build issues w incorrect spoke lengths. Like it is that hard to order the rims and hand carry them to a local wheel builder to assemble. Does everything need to come ready to use at your doorstep. The amazon era. Its gonna do us in!
  • 12-11-2014
    Andy13
    I have 2 full seasons of hard riding on mine w/ aluminum sapim polyax nipples. I used a grey automotive anti-seize on the nipple seats. I live in dry Colorado. I will build again w/ alloy, unless I have a failure in the near future. My "understanding" is that if the nipples have a good anodization then failure should not occur. The use of anti-seize was at the suggestion of someone on this group. I know that I will get many anti aluminum comments, but my experience has been good, albeit "so far". I have heard from someone who built and rebuilt many Enve wheels that the original Enve nipples that so many people had issues with were not anodized at all. YMMV.
  • 12-11-2014
    TwoTone
    It's not that, it's the price, people think they are saving $150 ignoring all the advice against their builds. There are a few people posting they are happy with them, but I wonder if they even know what to look for to know if its a good build to begin with.
  • 12-11-2014
    PauLCa916
    That's what I wonder about.
    I had mine done by a wheel builder with King Hubs I'm very happy.
  • 12-11-2014
    yourdaguy
    All my wheels were built with DT nipples. Red, black, clear; anodized. They all showed significant corrosion after 2 years. I do wash my bikes after every 3 rd ride on average.
  • 12-12-2014
    mtndude23
    I used alloy with my build-I do on most of my builds. But I live in the dry deserts of colorado. So my wheels really don't see much water or salt. If your bike sees lots of salty water then go for the brass.
    On a side note-I haven't heard of anyone having corrosion issues with carbon seatposts/handlebars and the AL frames and stems.
  • 12-12-2014
    ozzybmx
    The weather doesn't make any difference, I'm from South Australia, the driest state on the driest continent on earth... I started this thread a while back - http://forums.mtbr.com/wheels-tires/...on-835853.html
    Carbon is a non metallic conductor of electricity, so between galvanic corrosion, a reaction with stans liquid or whatever caused the failure of many ENVE wheelsets, just go brass.
    I now don't own a set of metal wheels, embarrassingly I have 7 sets of carbon wheels, only 1 expensive set though, the rest are Nextie and LB rims. I build my own wheels and will never build another set of wheels with alloy nipples, ever.
  • 12-12-2014
    abelfonseca
    Will relative humidity have something to do with the corrosion issue? Ie. The drier the worse? Static electricity will thrive in drier weather. Has anybody seen a correlation with this?
  • 12-12-2014
    yourdaguy
    Washing the bike seems to have the most affect on how fast corrosion occurs. Water gets between the nipple and rim. Moisture speeds up corrosion.
  • 12-12-2014
    eb1888
    I am now only riding wide and then I see what this guy can do...
    Chris Akrigg - Chriscross 2 - BIKE Magazine
  • 12-12-2014
    yzedf
    My local wheel builder says that aluminum nipples are for show and brass are for go.
  • 12-12-2014
    elsinore
    I am more than happy with my LB build. I think its pretty safe to say that their builds are inconsistent at best judging by whats been posted, but saying that folks don't even know what to look for who happen to be pleased with their build is pretty arrogant.
    Ive seen 3 LB builds locally that have all been fine. Mine has held up remarkably well. Good enough in fact that this wheelset has been better than most builds I have had and Im pretty hard on wheels. Id not hesitate to get another build from LB. If you don't want to take a chance with them then go the local builder route, its that simple.
  • 12-12-2014
    TwoTone
    It wasn't arrogance,it was just a statement. You and both know there are a lot of posters that don't know what the hell they're talking about on here. So I just wondered. Just because someone gets the wheels and they ride them, doesn't mean it's a good build.
    So with your build and those others, you've checked tension? How were the spoke lengths? Any prep on the nipples?
    Also, you kind of make our point with this "I think its pretty safe to say that their builds are inconsistent" So to save $150 it's worth rolling the dice and hoping you get one of the 'good' builds?
    No thanks- I'm on my 4th wheelset from Mike- no need to save a $150 and take a chance. I'm sure plenty of other can say the same for the builders they use.
  • 12-12-2014
    rockman
    This online calculator is pretty handy for checking build quality. Park Tool Co. » TM-1 Tension Meter Bladed Spoke Calculator
    Borrow a TM-1 from a friend, the LBS, or buy one for $70.
  • 12-13-2014
    rfxc
    The corrosion you're discussing: is it just the nipple that disintegrates? Or does the carbon disintegrate around the nipple as well?
    I can live with replacing spoke and nipples every few years, but don't want to damage rim.
  • 12-13-2014
    reamer41
    I've got 2 years on mine. Black aluminum nipples, LB rims, CX-ray spokes. Last week I had to replace 2 spokes due to an unfortunate incident involving a lot of wet clay, a wrecked rear dérailleur, and a couple broken/bent spokes.
    No corrosion at all on the spokes/nipples I removed, and no signs of it on the remaining.
    Not to say it won't happen, just that, so far, I've got no signs of corrosion.
  • 12-13-2014
    meltingfeather
    It's not necessarily galvanic corrosion. In fact, nothing really points to that. The misuse of technical terms is just something that happens when a bunch of people start reading snippets of Wikipedia and acting like they know what they are talking about. It plagues Internet forums.
  • 12-13-2014
    pharmaboy
    Lol, some truth to this. BUT, alloy nipples are more prone to poor manufacture are weaker and more prone to rounding on high tension wheel sets.
    All in all, alloy nipples have no real world benefit at all, and plenty of real world potential downsides, such that using brass is a no brainer. People who are so affected that they value an anodised colour higher than use-ability and dependability have to take a good hard look at themselves in the mirror or go buy a white wheeled fixie, get a manicured beard, and become a barista.
  • 12-13-2014
    meltingfeather
    Funny stuff! :thumbsup:
    One benefit is rotating weight reduction and for all the probably billions of aluminum nipples out there there are relatively few problems like this.
  • 12-14-2014
    yourdaguy
    Well I knew about galvanic corrosion decades before the 2001 start of Wikipedia. I had 2 wheels with broken nipples this Summer and rebuilt them with brass and I just rebuilt the other 6 in the last 2 weeks using brass. Here is a sampling of the damage I found.
    https://www.dropbox.com/sc/apd0zahc3...pWyY9elieN7bma
    Sure looks like galvanic corrosion to me. These nipples have been in there around 2 years. I wash my bikes about every 3rd ride and I ride a lot-like 5 times a week.
    https://www.dropbox.com/sc/2w5zzgwvj...4sri3mNYJYKLja
    I have 3 sets of Stans wheels some of them 5 years old and so far no nipple problems. So my theory is that it is galvanic corrosion caused by the carbon (which is drilled no molded-that should make it worse) and the more you wash/get them wet, the worse the problem.
    Tell us MF, what is your theory on what is happening?
