Page 124 of 166 FirstFirst ... 2474114120121122123124125126127128134 ... LastLast
Results 6,151 to 6,200 of 8258
  1. #6151
    Salt Lake City, UT
    I have no idea - good question; just assumed they always kept stock full and the shipping caused the wait. Thanks for pointing that out - I'll contact them and see.
  2. #6152
    Certifiably Crazy
    Reputation: Carloswithac's Avatar
    Feb 2012
    Quote Originally Posted by KGAmoto View Post
    How quickly are people getting their LB orders? I'm pulling the trigger shortly after weighing a bunch of options, but of course not pumped about waiting 4+ weeks to get them.
    I put in my order and was told:
    "The lead time is around 15 business days and it usually takes 4~7 days for delivery."
    So figure three weeks if I'm lucky.
    2013 Felt Edict Nine
  3. #6153
    Reputation: vikb's Avatar
    Took 4 weeks from order to delivery. That seems pretty reasonable for a custom built product getting shipped from China.
    Safe riding,
    Vik
    www.vikapproved.com
  4. #6154
    mdc
    mdc is offline
    Reputation: mdc's Avatar
    I put an order in the last week of June (35mm hookless, Novatec hubs, blue nipples)- and they took about 3 weeks to arrive.
    All I can say about my experience with LB, is that they provided great customer service, and the finished product is pretty damn nice. No regrets whatsoever....
  5. #6155
    Certifiably Crazy
    Feb 2012
    Is anyone using the stans rubber rim straps, or should I stick to the yellow tape?
  6. #6156
    mdc
    mdc is offline
    I used Guerilla tape cut wide enough to cover the spoke holes ( cheap and bombproof), but yellow tape would work fine as well. The tires inflated easy and the bead snapped into place no problem..
  7. #6157
    Reputation: s0ul_chicken's Avatar
    Aug 2013
    Can someone give me the link to LB?
  8. #6158
  9. #6159
    Aug 2013
    Thank you hillharman!
  10. #6160
    Reputation: ms6073's Avatar
    Quote Originally Posted by Carloswithac View Post
    Not a definitive answer, but I tried the Stan's rubber strips. Was trying to setup a set of Schwalbe Sammy Slicks (700x35c) tubeless on Enve Twenty9 XC wheels but despite use of an air compressor, was unable to get a sufficient bead seat and the tires would leak down very quickly. ALternatley, 3 layers of the Orange Seal tubeless tape and some Cafe Latex and the combination has been pretty solid.
  11. #6161
    Stans tape one layer on my 30mm external wide 29er rims works perfect. I don't know why anyone would use anything else. It's light and last very long, it's perfect for all rims!!
  12. #6162
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    Quote Originally Posted by dgw7000 View Post
    I use 3M 8898 tensilized polypropylene tape because it is the same tape at a fraction of the cost.
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
  13. #6163
    Finished building up my set of 35/30 rims. DT Swiss Comp Spokes, Alu nips, 350 hubs, 15mm 6 bolt and 12x142 6 bolt. Setup with one wrap of 24mm Stans tape, was able to seat easily with a floor pump. Weighed in at 1780grams with tape and valves.
    First ride on them on my Santa Cruz TBLTc and noticed a couple things vs my Stans Arch EXs. They feel like they spin up a little faster on the uphill since they are a tad lighter. Most noticeable thing is how stiff they are, holy ****. They like to track straight over whatever you point them towards. Weigh in at 180, running 20 psi front 22 rear, grip was better with the wider footprint. Felt like I might need to decrease the pressure in my fork by a bit to smoothen things out up front since they are so stiff. Overall pretty impressed.
  14. #6164
    Quote Originally Posted by meltingfeather View Post
    Nice. So something like Scotch Film Strapping Tape 8896 Blue, 24 mm x 55 m
  15. #6165
    (Cheap) Chinese Carbon Rims?
    Quote Originally Posted by ms6073 View Post
    The description and picture look right, but the 8896 doesn't match. According to Scotch's website 8896 is a different tape that may or may not work well.
  16. #6166
    I've used the 8898 3M tape on 27mm hookless without issue. It's not the same thing as Stan's tape, though. It's noticeably thinner, easier to stretch, and it can turn into a stringy mess when removing. For the price difference it's probably worth it, but I've seen a lot of posts indicating it's the same as Stan's, and that's not been my experience.
    Sent from my XT1032 using Tapatalk
  17. #6167
    Quote Originally Posted by GoldenDragoon View Post
    Same specs and weight as LB rims.... Hmmmmmmm......
    Are Iplay and LB the same rims?
    2012 Cannondale Supersix Evo 2 /// 2012 Specialized Carbon 29 HT/Rigid /// 2000 Ritchey Swiss Cross
  18. #6168
    Possibly a dumb question, but I haven't paid as much attention to the carbon rim offerings since I bought some LB hoops.....is there a "lower" cost 40mm 29er carbon rim available from LB or similar company?
    I'm thinking of an upgrade for my Krampus and want something wider than 35mm for my 3" tires.
    Safe riding,
    Vik
    www.vikapproved.com
  19. #6169
    Rocks belong
    Quote Originally Posted by agentsmith View Post
    LB tells you no. Sure seems like there is 1-2 plants making all of these and everyone (iplay, LB, Nextie... etc) are all just selling them.
    Hell, the Roval Control Carbon 29 and Roval Fattie's sure look like all of the others!
    I like 'em long, low, slack and playful
  20. #6170
    Crash Dummy In Training
    Reputation: PauLCa916's Avatar
    Jun 2013
    Quote Originally Posted by hokiebrett View Post
    When I took my LB bead less hook less 27 mm rims to be built at the LBS..
    I put them next to the Roval's me or the builder couldn't tell the difference.
    2015 Flyxii / ENVE /Chris King Carbon 29'er H.T.
    SRAM XX1
    2012 Stump Jumper Comp 29'er H.T. SRAM XX1
    1997 Rock Hopper / Rock Shox Recon Silver / 1 x 10 SRAM X9 XO Mix XT V Brake system
  21. #6171
    Quote Originally Posted by JTrue View Post
    I have had the same experience! And cornering the difference is really noticeable. I am really enjoying my LB rims.. I built them up with I9 hubs dt spokes and brass nipples. I am on a TBLTc also!
  22. #6172
    Quote Originally Posted by Andy17 View Post
    Nice, yeah haven't gotten to rail any berms yet, but they feel like I'll be able to ride through with more speed and confidence. It's pretty loose right now in Utah... Btw, running 2.4 Ardent Exo front, 2.2 Ikon Exo TR rear.
  23. #6173
    Rocks belong
    No pics yet, as it's not letting me upload from my phone...
    Decided to learn something tonight... How to lace wheels, that is.
    Got my 12x142 BHS MTB270 and American Classic 15thru laced up to my Light Bicycle hookless 27mm XC 29er wheels. Went with the standard (read: boring) 32h/3x lacing to keep it simple and classy. Silver spokes and silver brass nipples for a little shine, with matte/UD rims.
    669g front, 830g rear... Not bad for a 22mm (internal rim width) wheelset! That's 3mm wider and 300g/0.66lb lighter than my existing "lightweight" Easton EA70XCT wheelset!!
    The BHS (Bitex) MTB270 hub sounds wicked! Deeper in tone than a Chris King. It literally sounds angry. No Hope clack... Just a deep, mechanical, pissed off buzzzzz.
    Can't ride em yet (still gotta build a DIY wheel truing stand), but not bad for about 3 beers worth of work (with plenty of hiccups... Don't drop a nipple in a rim. Let alone three of them).
    I've got a set of BHS MTB 180/270 hubs that are awaiting LB hookless 35mm AM 650b rims. Apparently they're shipping this week!
  24. #6174
    Rocks belong
    Anybody tried Velocity VeloPlugs on LB hookless wheels? They look similar to the Specialized spoke plugs that are coming on the Spesh carbon Fatties. Another (cheap) way to save 35-40g of rotating wheel weight (plugs are lighter than tubeless tape). And you can replace a spoke by pulling one plug, instead of the entire strip of rim tape.
    Velocity Rim Plugs > Components > Tires and Tubes > Rim Strips | Jenson USA
    Veloplugs
    Velocity Wheels
  25. #6175
    Veloplugs
    Velocity Wheels
    The Velocity website says "~15g over cloth tape on a 700c wheel." They're talking about Velox, which is heavy compared to tubeless tape, which is 5-10g per wheel.
    I'd be surprised if there were any weight savings at all. I'd also be very surprised if they were air tight.
  26. #6176
    Veloplugs
    Velocity Wheels
    Velo plugs don't seal the spoke hole for a tubeless setup. They work with tubes to replace the rim tape you previously used to protect the tube from damage from the spoke hole and spoke.
    In a tubeless setup they serve no purpose and you are going to need to seal the rim with Stan's tape or something else.
    I've used them in the past on tubed wheels and they work fine. On the whole I generally wouldn't bother with them as they don't offer anything revolutionary and I always have tape on hand so that's what I normally use.
    Safe riding,
    Vik
    www.vikapproved.com
  27. #6177
    Rocks belong
    I was thinking something like what Specialized is using on their Fatties:
    Wheels will be shipped with traditional rim strips, but the carbon model will also include these Roval plugs. Lighter than a traditional tape setup, these Delrin plugs seal the spoke holes and can be run either with a tube or tubeless.
    New Specialized Roval Traverse Fattie All Mountain Wheels Show Fat?s Where It?s At
    (Cheap) Chinese Carbon Rims?-specialized-roval-traverse-sl-fattie-wheel-2-600x400.jpg
    EDIT: OOooooooh, the Roval plugs are special. They have O-rings to seal:
    INSTALLING THE TUBELESS PLUGS
    1. Inspect all plugs to ensure the o-ring goes around all four tabs.
    http://service.specialized.com/colla...0000045737.pdf
    Guess I'll have to convince a Big S dealer to sell me 128 Roval Tubeless plugs
  28. #6178
    "These new wheels are also compatible with our Roval tubeless plug system, an easy and super lightweight solution for tubeless setups."
    The Velocity plugs don't seal and the Specialized ones would need to be the exact size of the spoke holes in a LB rim to work.
    Personally the whole idea seems like a solution in search of a problem. 1 wrap of Stan's tape in a LB rim and you are done. Cheap/fast/light/readily available in any LBS there isn't much to complain about.
    Safe riding,
    Vik
    www.vikapproved.com
  29. #6179
    Rocks belong
    Quote Originally Posted by vikb View Post
    One Specialized LBS near me has built up many sets of LB hookless rims. They've also sold the Roval Control Carbon and Carbon SL wheelsets. They believe they are the same rim, as they cannot tell a difference between the LB and the Roval rim when held next to each other.
    I've got tubeless tape, but these sound like a cool option.
  30. #6180
    May 2012
    If I broke a spoke in tubeless wheel, I would cut a hole in the tape, replace the spoke and put another short, 10", section of tape over the hole. First you would have to clean the area real well.
    Those hole caps have too many points of possible failure. They might work fine but I would be more comfortable with tape. I like Tesa strapping tape because it is thin, light and it stretches.
  31. #6181
    Quote Originally Posted by dugt View Post
    Or you can carefully unthread the spoke from the nipple, orient the wheel to keep the nipple protruding (painters tape is handy to temporarily hold the nipple), lace in the new spoke, and thread it to the original nipple. No need to even remove the tire, let alone the tape.
    If you've broken a nipple, well, that's another story.
  32. #6182
    Others have pointed out several reasons this isn't a good idea, but its also worth noting that Velocity themselves specifically highlight that you should NOT use the Veloplugs on their tubeless ready rims (such as the A23) because they sit too high in the rim bed, which consumes a precious millimeter or so of bead diameter when mounting tires, making it difficult/impossible to get the tire on the rim.
  33. #6183
    Rocks belong
    Ok ok ok... Sorry I asked!
    lol
  34. #6184
    lol
    You should be happy you asked. We all saved you from a bad experiment!
  35. #6185
    Jul 2013
    Just built up some 35mm wide wheels. Rims were from carbonbicycle. Using Hope 2 Evo hubs and sipam race spokes and brass nipples. Rear came out around 944 grams and front 847 grams. 1791 grams not to bad i guess. Wheels are real nice and stiff. Pics up soon.
  36. #6186
    Quote Originally Posted by McGG View Post
    I think it was damaged after manufacturing. The carbonbicycle.cc guys seem to be responsive about replacing it so far. If everything isn't to my satisfaction, then I will certainly report back here.
    I'm considering a 2 rim (35mm 29") purchase soon, can you share how this was resolved with carbonbicycle.cc?
    May 2013
    Got my set from Light Bicycle last weekend and have been riding everyday since. Got the 30mm hookless with 32/32 QR Hope hubs and have been amazed!!! Weight came in just a pinch under 1600grams. Only problem I've had was seating the Racing Ralph in the rear. My air compressor wasn't doing it. Had to finess the bead out by hand and keep trying to pump air into it until it would hold. Took me about an hour. Front tire is Rocket Ron and had no problems even with a floor pump. Was odd though as I'm used to hearing the popping sound but with the hookless there's no sound. LOL
  38. #6188
    May 2013
    BTW I really wish I got the 35's now. But 30 is still a nice improvement over what I had. Can tell the tires look fatter...
  39. #6189
    Certifiably Crazy
    Feb 2012
    Quote Originally Posted by Ramborage View Post
    Pictures!? I am not the most patient person. kartrin just told me my rims are currently being manufactured. I can't wait!
  40. #6190
    I've had a bit of a failure on my "wider" 29er rims. I've been using them since late December. I did a long ride in the mountains with no issues, then a couple days later I took the bike out for a ride again and noticed this....
    The evidence suggests rock impact but I don't recall any significant thumps on my previous ride. I obviously finished out the ride without noticing anything. The tire held air and the wheel is still in true. I was running about 28psi in moderately rocky terrain on a Kona Process 111. I weigh about 190lbs and am a fairly aggressive rider. Don't really blame the rim but this is the first time I've made any rim unusable.
    I've sent an email to LB to see if they would help me out a bit with a replacement. If they don't, I think I may order for carbonbicycle.cc
    As far as I can tell, it's the same product for $75less.
    Anyone have any similar experiences they want to share?
    Attached Thumbnails Attached Thumbnails (Cheap) Chinese Carbon Rims?-photo-5-2-.jpg
  41. #6191
    4 Niners
    Dec 2008
    Does not look like failure to me. Looks like a rock strike.
    Full rigid SS, Hardtail SS, Hardtail Geared, Full Suspension Geared.
  42. #6192
    May 2012
    Quote Originally Posted by rusty904 View Post
    It is hard to tell the extent of the damage because the photo of the damaged area is not in focus. The opposite side of the rim got the best focus. It would also be interesting to see a photo of the inside of the rim at the damaged area.
  43. #6193
    74 & 29 pilot
    Reputation: MTB Pilot's Avatar
    Oct 2010
    Hard to tell, but that bubbling and the wrinkling looks as though there might be some material failure. I had one that did that when the tire was compressed by a rock and the side of the rim gave out. The top of the bead wall was compressed in and damaged, but no sign of rock damage or dust on it. Mine also held 30+ PSI while I rode and until I took the tire off.
    Must of been one hell of an impact...
    MTBP
    "GIVE ME LIBERTY OR GIVE ME DEATH!"
    Turn on the truth: http://www.ronpaulchannel.com/
  44. #6194
    Quote Originally Posted by MTB Pilot View Post
    Yeah, I need a camera, I could not get my phone to focus on the rim. This is the best I could do but still crappy. There is some de-lam on the wall of the rim and a little more a few inches down from the impact.
    That's kind of what's a bit perplexing. When I feel a nasty "hit" I always stop to check the wheel out. I have no such memory from the ride where the damage occured. The trail was rocky but not ridiculously so. I have no doubt a rock hit was involved but I don't think it was that severe. I rode out never knowing the damage was there.
    Attached Thumbnails Attached Thumbnails (Cheap) Chinese Carbon Rims?-image.jpg
  45. #6195
    Well it's been a couple days after contacting them with no response. Wasn't expecting much obviously but I was hoping they'd at least get in touch with me. Oh well, just a casualty of MTB'ing. The performance and price are worth the risk.
    I'm going to upgrade my rims to the 35mm hookless variety. A set from light-bicycle is $424.35 shipped and has the option of "all mountain" or "downhill" models with the downhill model increasing the total to $440.91.
    Carbonbicycle.cc seems to have a very similar (the same?) rims for $353.90 shipped. Anyone have a good reason why I shouldn't go with the cheaper option?
  46. #6196
    Reputation: Ottoreni's Avatar
    You might want to also check out Nextie rims.
    Nextie Bike | Carbon Bicycle Devotion | Made in China
    I have no relation to them other than being a customer. I recently had a rim develop holes around the a nipple hole. They replaced the rim, I only had to pay shipping.
    There is a lot of talk about them in the fat bike forum as they make a "wild Dragon" fat bike carbon rim.
    Just something to look at.
    You cannot go against nature, because when you do, its part of nature too.
  47. #6197
    Quote Originally Posted by Ottoreni View Post
    Thanks for the tip, never heard of that one. They seem to fall between light-bicycle and carbonbicycle price wise. Also they claim a 2 year warranty. About 40g heavier weight for their "am" rims. Might not be a bad thing for me.
    Did you get the 35mm rims? How was the delivery time?
  48. #6198
    I have the original "wide rims", I think those are 30mm? Original rims were ordered back in early fall of 2013. The only reason I got the Nextie rims over the LB rims back then was because Nextie was a new company and was offering a 10 or 15% coupon back then. The rims arrived within 3 weeks.
    The warranty rim should arrive in just under 3 weeks.
    When I do buy my next set of rims, I plan to buy from them again. I will go with the wider and hookless rims when that time comes since I have had an overall good experience with them.
    I can give you the guy's name I have been dealing with. He gets back to me within 24 hours.
  49. #6199
    Sep 2013
    Hi guys,
    What has been the smallest tire anyone has installed on the 35mm wheels? Would a 2.0 tire work ok?
  50. #6200
    I received two rims from them. Quality seems fine. Build was easy. I'd save the money.
