Page 114 of 322 FirstFirst ... 14 64 104 110 111 112 113 114 115 116 117 118 124 164 214 ... LastLast
Results 2,826 to 2,850 of 8044
  1. #2826
    Oct 2012
    Quote Originally Posted by yourdaguy View Post
    I have broken/tacoed Stan's rims and I am old and not very heavy. These rims are rock solid as far as I am concerned. I have ridden them hard and put them up wet with no issues. I just ordered my 3rd set so I am putting my money where my mouth is. I have 4 sets of STans rims in all the models (ARCH, FLOW, CREST) and before these, Stan's were the best. Stan's are still great, but I am liking these better.
    If you read this. I am 200lbs, will almost only ride on a paved trail to work. I just bought a new set of 29er Crests, will I break them? I could not pass up the set, new for $349 at an LBS.
  2. #2827
    mtbr'er
    Reputation: NoCoMTB's Avatar
    Quote Originally Posted by Gabe63 View Post
    Riding paved paths on a commute? Not likely.
  3. #2828
    mtbr'er
    Or it might be better to say, EXTREMELY unlikely
  4. #2829
    4 Niners
    Dec 2008
    I weigh 170 and am 58 and have tacoed a Crest and blew a tire completely off a Crest. That said, I was in the dirt. You can probably ride 100 years and unless you hit a curb hard, you will have no issues.
    Full rigid SS, Hardtail SS, Hardtail Geared, Full Suspension Geared.
  5. #2830
    lamer
    Reputation: llamma's Avatar
    I'm at least 205 geared up--ride roots, rocks, and some small jumps--and haven't broken my Crests yet. That said, I've got a pair of wider LB rims ordered already.
  6. #2831
    4 Niners
    Dec 2008
    PS You will love these assuming descent hubs. They actually accelerate faster than the LB wheels since they are lighter. As long as you are not bombing curbs they will be fine and actually ride better. Where the Crests fall down is in steering precision and overall durability/strength. I actually have Flows on my commuter since I do bomb curbs.
  7. #2832
    4 Niners
    Dec 2008
    OOXJCO How fast were you going in your avatar picture?
  8. #2833
    Jun 2005
    Quote Originally Posted by simpy16 View Post
    My Light Bicycles 29er UD matte finish rims arrived today and from what I can tell (which isnt much) they seem well constructed.
    I plan to get these built up in the next few weeks and then can compare them to my Enve wheels.
    My question is what is the best tubeless setup to use on these rims? they are the AM tubeless version (BTW)
    Evne tape- I think I would need to get the wider version of the gorilla tape. Is this best for these rims?
    Stans yellow- Light, do they hold well or are the rims too wide for this light tape to work?
    bontrager strips- I believe I would need the Rhythm model of strips. Seem to work well on my RXL rims do they make mounting tires easier or more difficult with the rim profile?
    Any feedback or correction would be helpful.
    I'm using Stan's yellow tape. No problems at all.
    Edit: Eh...sorry for dropping this response in here kind of late...didn't realize the discussion had kind of moved on....duh...
  9. #2834
    mtbr'er
    Haha - Ariel Atom fast! Seen the video?
  10. #2835
    Mar 2011
    Quote Originally Posted by goodmojo View Post
    Weight wise I only dropped about a pound from the i23s.
    This was just what i was looking for. I'm also riding a tallboy LTC with i23's.
  11. #2836
    4 Niners
    Dec 2008
    I haven't seen the video but I have been up to 165 (180 indicated) on a ZX11.
  12. #2837
    mtbr'er
    Awesome! I had a GSXR-1000 I got up to 186, which is also the speed Suzuki claimed it was governed at. I don't know what the 'actual' speed was, seems like they all read high, especially at high speed.
  13. #2838
    mtbr'er
    delete
  14. #2839
    Reputation: reamer41's Avatar
    I'm ready to lace up my Wider 29r (reinforced) rims. Need spokes.
    I'm using Chris King ISO hubs. SD15 front and 142 thru axel rear.
    I'm coming up with spoke lengths of 292/293 front and 293/292 rear. Anyone else lace up the same rim/hub combo? What spoke lengths worked out for you?
    User error
  16. #2841
    Delete
  17. #2842
    Oct 2007
    Same setup I used 292 all around
    Mad lacing super easy.
    Quote Originally Posted by reamer41 View Post
    Quote Originally Posted by nbwallace View Post
    Cool!
    I was thinking that would likely work.
    12mm nips?
  19. #2844
    Oct 2007
    Yep 12mm brass nipples
    I used Sapim double butted spokes and sapim polyax nipples. I usually get my stuff from bikehubstore.com. Brandon is super nice and the parts get here quickly. His prices are much better than anywhere else.
    Cool!
    12mm nips?
  20. #2845
    Ballstein Models
    Reputation: hogprint's Avatar
    That's what I used for the same setup.
    ________________
    The source for mountain biking information in the Madison Wisconsin Area:
    Capital Off Road Pathfinders
  21. #2846
    Reputation: krispy@go-ride.com's Avatar
    You may want to consider going 2 cross, it makes for a better nipple angle towards the hub. The rim is so thick, and the hole is not drilled at an angle so the nipple can't angle toward the hub very well.
    As for spoke triangulation, you can just about throw previous wheel building practices out the window with carbon rims. They are so much stiffer that lighter, fewer spokes and fewer crosses works great and may actually build some flex back into the wheel.
    I went 2 cross and used 282 mm spokes all around on Kings.
    Santa Cruz Bronson 2 27.5/Rockshox Pike/Sram XX1
    Salsa Mukluk/Rockshox Bluto/Sram X1
  22. #2847
    One more Q: When lacing aluminum rims I have always lubed the nipple seats. Have you all been doing so with carbon rims, and if so, what lube?
  23. #2848
    Trail Ninja
    Reputation: Varaxis's Avatar
    Be prepared for dozens of different answers for that. Just use what you've been always using. Being carbon shouldn't make a diff, assuming other things are equal. If you're planning on going high tension go for something more oily and slicker, espec if using a 3x lacing pattern. Anything works really. Hell, I have a 5 QT jug of motor oil with a little oil left that I'd use--can't wait to hear what the bike purists say about that.
    I personally think the locking stuff is for the builds where there isn't very much resistance to nipple turning to tighten it, and therefore less resistance to loosen it. Maybe a "low" tension builds where the spoke enters the nipple in a straight manner, such as in a radial/2x build and/or with rims with angled spoke drilling. Or low spoke count wheels, where each loose spoke would be felt more and you would get more peace of mind with the extra security. With spokes tensioned up to 120kgf, I'd imagine the tension and how the nipples aren't perfectly aligned with the spoke would be more than enough and you'd only need the lubrication for easier build-up as it might get hard to turn once without winding up the spokes at higher tension.
  24. #2849
    No. Run the nipples dry.
    I imagine someone, somewhere would have some good advice on a grease that would be good to use on carbon, but the consensus is, there's no squeeking, digging in, or corrosion between the materials so no lubrication is necessary. Some greases could actually be harmful on the carbon. I haven't seen any wheelsets from other mfg's using any lube on rims or any other carbon part for that matter including headsets, seatposts etc.
    I have experienced the nipple getting really tight giving me a false hand tension reading, but i think it has just been the nipple getting side loaded in the deep hole of the rim as i explained in my previous posts.
    I've taken a carbon Enve spoke out that was broken and the nipple had some rounding at the base where it contacts the rim, but no significant wear on the rim bed. I'd say less rounding than a typical alloy rim/nipple interface has.
  25. #2850
    Quote Originally Posted by Varaxis View Post
    Ha! I bet. I'll just go with a dab of synth motor oil then. Thanks.
