Results 1 to 5 of 5
    Changing Sram 1250 chain rings
    I have a '12 Specialized Camber Comp 29er with SRAM S-1250, 10 x 2 speed XC Trail, PF30 spindle crankset. I rarely use the small 22t chain ring and would like to upgrade to a 26t ring. Would this work?
    New Truvativ Trushift Alloy 8 10sp Ring 64BCD x 26T Black | eBay
    2012 Specialized Camber Comp 29er
    Trek 9800 OLCV, XT upgrade 26er
    KHS Fleetwood
    Schwinn 20" Fastback 5 speed stick shift
    57 hits no, input?
    How about this question what does "armxBCD: 4x64mm" mean? Is it 64mm between crank bolts?
    KHS Fleetwood
    Reputation: ss29er's Avatar
    Aug 2005
    BCD = bolt circle diameter
    Which means if you could draw a circle through all 4 bolts it would be 64mm in diameter.
    I'm pretty sure that SRAM 2x10 rings are 120mm BCD on the big ring and 80mm for the small ring. You'll need an 80mm small chain ring.
    I have two bikes, one set up as a 39/26 with a 12/36 cassette and one set up as a 38/24 with a 11/36. I personally prefer the 38/24, but I occasionally wander into some places with steep climbs.
    There's only one bigger sheep than manufacturer's - consumers! - AndrewTO
    Thanks for the info
    KHS Fleetwood
