Results 1 to 5 of 5
    Feb 2013
    Chain keeps slipping off.
    Time for new chain? I had my gears adjusted couple weeks ago with tune up but my bike just keeps messing up. Wrecked really bad about a year ago and i've had nothing but problems with her ever since. LBS said the frame was ok but i've never had mechanical problems like this with any of my other bikes in the past. Guess i should take to another shop
    SWING YOUR LEG OVER IT AND PEDAL
    Need a better description.
    Front or rear? Inside or outside? What gear are you in? Has the derailleur hanger been checked?
    Feb 2013
    Just got back from bike shop and they're going to check it out...they said it could be number of things. Crossing fingers nothing major!
    Feb 2013
    So LBS says i need new drivetrain overhaul....Gotta love cheap parts! Going to install Shimano Deore crank and new bottom bracket...getting cables replaced as well. Bike was rockin Alivo Crankset so will be slight upgrade. $243 dollars later..ahhhh i seriously need to start working on my own bike.
    turtles make me hot
    Reputation: NYrr496's Avatar
    Wow! Yes you do.
    I like turtles
  1. Chain slipping... Help!
    By Kevin_K in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-01-2012, 01:29 PM
  2. Another chain slipping problem
    By Matfam in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-07-2012, 11:53 PM
  3. Chain slipping on middle chain ring
    By Eric C. in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-28-2012, 07:03 AM
  4. Chain slipping
    By infested in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-11-2012, 05:52 PM
  5. Chain keeps slipping
    By 08hardrockmiami in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-19-2011, 07:37 PM
