Results 1 to 28 of 28
    Aug 2013
    Carbon seatpost in Aluminium frame - To grease, or not to grease? Carbon paste etc?
    Hi Everyone,
    Just after a bit of advice as to the installation of a carbon seat post in an aluminium frame... I have seen so many conflicting bits of advice, I am a bit lost.
    To precis:
    - I have a WCS Ritchey carbon post to fit to my Trek Fuel Ex 5 29er
    - I have cleaned out the tube as much as possible after removing the stock seatpost, although some grease remains
    Options:
    1. Install 'as is'
    2. Clean out ALL grease and install dry
    3. Install with a new application of grease
    4. Install with a new application of Carbon Paste
    All have been recommended in various places online and in my LBS, so I really don't know which track to follow!
    Any advice from people who have actually done this kind of installation would be much appreciated!
    Many thanks,
    Marc
    2016 Cannondale SuperX
    2016 Cube Cross Race SL
    2016 Scott Voltage FR 730
    2016 Radon Slide 130 10.0 HD
    2014 Scott Aspect 740
    Reputation: eluv's Avatar
    Apr 2005
    I used paste:
    Carbon frame aluminum post
    carbon bars aluminum stem.
    I have tried all 4 of those options and never had a problem with any of them. Right now I'm using some white grease on my post, mostly because it is a tight fit and I don't want it scratching.
    Epic rider
    Reputation: rapsac's Avatar
    Sep 2004
    Silicone spray. I think Syntace advices that for aforementioned use. I do this and it works ok. Carbon paste is more "scratching".
    12 Anthem X29
    13 XTC 29
    07 Epic Marathon carbon
    04 Stumpjumper FSR Anniversary
    03 Stumpjumper FSR Pro
    00 Rockhopper Pro
    I like turtles
    Reputation: TiGeo's Avatar
    Carbon post in aluminum frame here. Just cleaned the old grease out of the seat tube as best I could and installed. Hasn't moved in over a year. Carbon paste is only if moving is an issue; it adds some abrasion. I did use that on my carbon handlebar with my Syntace stem as it was recommended but the bar had a rough section on it and I probably didn't need it. I don't think you will screw anything up. Carbon certainly won't seize up in the metal frame so I vote for dry (like I did) and only use paste if slipping is an issue. Follow the recommended torque on the seatpost bolt!!!
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    I use grease for steel frame / alu post, so it won't seize.
    I use grease for steel frame / carbon post, so the frame won't rust. (Make sure the grease is chemically suitable for plastics!)
    For an aluminum or titanium frame and carbon post, neither of the above applies: go bare or add paste if it slips.
    Some people will recommend friction paste with the logic that it allows you to tighten your seatpost clamp less, and therefore reduce the risk of overtightening/crushing. But I'm with TiGeo, I haven't had slipping problems running bare or with grease.
    dbl post
    You are so wrong, carbon aluminum do seize, You should check it... Maybe I am wrong but I have heard plenty of people with stuck posts in carbon frames. There have also been posts about Enve rims and aluminum nipples.
    1*14*29*2.1 & 1*1*29*2.4
    Quote Originally Posted by MTBMILES View Post
    yes I have heard that too, mainly with alloy nipples and carbon rims, but I haven't seen it yet. I made some fibreglass paste from silicon grease and glass dust (epoxy thickener) which seems to have worked but it's a bit of an experiment. Just made a putty like mixture and smeared it on. I figure it's just about having some fine grit in a friendly medium.
    Aug 2013
    Thanks for the advice everyone, I very much appreciate the input!
    Going to finish cleaning the seat post tube tonight to get the rest of the old grease (and mud) out, and install the new post 'dry' for now. I'll move it every week or so initially just to check that it is not seizing, and then see how it goes. If it does slip, I'll look again at the carbon paste option.
    Thanks again!
    I like turtles
    I did some looking..yes..some folks reporting frozen carbon posts in Al frames...yikes! May need to take mine out this weekend to move it..its been over a year!
    Reputation: time229er's Avatar
    Oct 2013
    why gamble?...
    after a $100+ investment in a carbon post, why not just do it right? The seat post picture shows the original aluminum post that slipped...new SLK carbon installed with Finish Line and hasn't moved in 100+ miles...it's a perfect world
    Attached Thumbnails Attached Thumbnails Carbon seatpost in Aluminium frame - To grease, or not to grease? Carbon paste etc?-616shv%252bikel._sl1500_.jpg
    Carbon seatpost in Aluminium frame - To grease, or not to grease? Carbon paste etc?-dsc01482.jpg
    2014 Nail Trail 29...
    I like turtles
    From Niner's manual for my RDO post:
    The seat tube MUST be free of all lubricants, use rubbing
    alcohol to carefully clean the inside of the tube and remove all traces of
    grease, dust or other compounds.
    Apply a thin film of Carbon Assembly Compound (Tacx, FSA or other) to
    the post and inside the seat tube to ease installation, adjustment and
    removal.
    Guess I know what I am doing this weekend!!
    Aug 2013
    Ah great info - the search for Carbon Assembly Compound begins!
    AOK
    AOK is offline
    Reputation: AOK's Avatar
    Carbon seatpost in Aluminium frame - To grease, or not to grease? Carbon past...
    Quote Originally Posted by Marc2211 View Post
    I used a little smudge of Colgate toothpaste as "carbon assembly compound" to fix a slipping carbon post in Al frame. Worked like a champ and left my bike minty fresh.
    I believe I picked up the tip on a (gasp!) road bike forum.
    I like turtles
    I have some Finish Line and some some stuff I got from Syntax with my stem for carbon bars..will use that.
    Sent from my SCH-I545 using Tapatalk
    I've found that carbon paste makes my post more prone to creaking. I run mine bare.
    Feb 2005
    I have a Easton Haven post in I my Epic Comp. I noticed after 6 months of not moving it; it has become very difficult to remove.
    After getting it out the post looks like its starting to breakdown. It hasn't been moving inside the seat tube but looks like it has been.
    Sent from my DROID RAZR using Tapatalk
    Quote Originally Posted by AOK View Post
    I like that. Of course if you ride in wet conditions its not going to last long.
    Leonard Zinn and Craig Calfee, both custom bike builders, discuss how grease on carbon posts is ok, even a good thing:
    Calfee:
    I donít know where the myth started, but carbon composites are not affected by grease. Our advice is simple: If the seatpost fits tight,grease it. If it slips, de-grease it. As has been known formany years, when aluminum and carbon fiber contact each other, galvanic corrosion can start.
    Technical Q&A with Lennard Zinn - More greased carbon - VeloNews.com
    Aug 2013
    Got some carbon assembly paste form my LBS this afternoon - initial installation complete!
    Damn scared tightening it up as my torque wrench is at work, was really fearful of cracking it. I'll be riding in standing up for my whole commute tomorrow morning until I can tighten it properly!
    Carbon seatpost in Aluminium frame - To grease, or not to grease? Carbon paste etc?-photo-1.jpgCarbon seatpost in Aluminium frame - To grease, or not to grease? Carbon paste etc?-photo-2.jpg
    Jeez man its not made of egg shell! I've been tightening my seatpost clamp with no torque wrench for years.
    Yeah so I cracked one :/
    But that was when I thought those things were indestructible. I was on a muddy ride and adjusting my seat height. The post was dirty so it was a really tight fit. I tried closing the quick release and it was was really tight but I forced it closed. As I mentioned before, I didn't even know it cracked until I got home, and it still held my weight.
    I think you can use common sense to tighten it enough to keep it from slipping so you don't have to stand up on your whole commute tomorrow!
    Oct 2013
    Quote Originally Posted by smilinsteve View Post
    and if your shit don't fly ???
    I like turtles
    Pulled mine out tonight. No issues at all..its been a year and I installed it dry and cleaned the seat tube with rubbing alcohol etc. to fully degrease it prior to installation. I used some Syntace carbon paste I had left over from my stem and re-installed it.
    Jan 2015
    What about an aluminum post in a carbon frame - fiber grip?
    Moderator Moderator
    Reputation: driver bob's Avatar
    Quote Originally Posted by borgey007 View Post
    I would.
    Digging up old tread but hopefully will help others. I have a 1 yr old niner jet 9 carbon RDO frame with a race face seat post that siezed in it. It came stock with paste on it but I hadn't maintained it in months. It locked in. While twisting the frame with seat post in vice the seat post snapped. Spent next 3 days hand sawing with a hacksaw blade length of seat tube. Just got it out few mins ago with lots of cussing and immediately searched how to prevent that which led me here. Moral of story, ALUMINUM POSTS CAN SIEZE IN CARBON FRAME!!! The same thing happened to my buddies carbon anthem frame with aluminum post. We both live in fla so maybe that has something to it but take it from me, grease your post!! And check it reguraly
  1. Anti-seize or Carbon Paste for Pressfit BB30 Installation on Carbon Frame
    By jminus in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-11-2013, 02:42 AM
  2. GREASE to press a HS in Carbon Frame?
    By Ricko in forum General Discussion
    Last Post: 07-27-2013, 07:49 AM
  3. Carbon frame build, grease or paste?
    By RTM in forum Bike and Frame discussion
    Last Post: 10-31-2012, 04:14 PM
  4. Carbon Paste or Grease?
    By Major Clanger in forum General Discussion
    Last Post: 03-31-2012, 05:44 PM
  5. Replies: 6
    Last Post: 10-12-2011, 08:50 AM
Members who have read this thread: 16
