Results 1 to 31 of 31
    Reputation: pulser's Avatar
    Dec 2004
    Can't find a seat bag I like
    I am posting this in the 29r section because I feel like the larger tubes make it harder to find a good seat bag. I was using an awesome strap last season and I thought I found the solution. But I got back from my ride yesterday and I lost my tube multi tool and leavers. So I guess its back to a set bag. My problem is I hate all the bags I find. The ones that take a 29r tube well are all too wide. Trek use to make an really nice long narrow bag. I would really like something longer but not wider and with some other way to attach to the seatpost other then a Velcro strap.
    Reputation: Gasp4Air's Avatar
    26' tubes work fine on 29" wheels. And if necessary, you can assist a rider with a flat regardless of what wheels they're running.
    Use it, use it, use it while you still have it.
    i leave the tools in the seat bag, tube in my camelbak. Gives more flexibility with seat bags.
    Dec 2004
    Quote Originally Posted by goodmojo View Post
    I don't ride with a camelbak vary much. I only use one for longer endurance races and really long rides when I know I can't stop any place to get water. I just don't like having any thing on my back.
    Quote Originally Posted by pulser View Post
    I would tape the tube to the seatpost then and put tools in the bag.
    Binned
    Nov 2008
    Switch to tubeless. No more flats, and only take a tube with you in a Camelbak for long rides.
    I use a Specialized saddle bag for short rides. Just a chain tool, a few quick links, a small multi-tool, and a CO2 inflator along with 2 cartridges inside. If I have major break down, I can walk it out or home or call for help.
    My Camelbak is loaded with stuff and I only use that for long, remote rides.
    I recently got one of these straps and like it a lot.
    Backcountry Research - Makers of the AWESOME STRAPS
    I have a Bontrager one that I've been really happy with. It's the Pro Seat Pack. I think mine is the 50 cu.in. It's just big enough to fit a 29er tube, multitool, co2, and tire lever. It keeps everything nice and tight so it doesn't bounce around
    They make a version that uses their "interchange quick clip" system you could check out since you are looking for something that doesn't attach by velcro
    Bontrager: Pro Seat Pack (Model #11040)
    I hate packs and seat bags. I rubber band my tube to my Blackburn Mountain Pump, and put it in my middle jersey pocket. Never lose either.
    Whining is not a strategy.
    Binned
    Nov 2008
    Quote Originally Posted by kosmo View Post
    I hate the feeling of anything in the jersey back pocket. I also hate the feeling of a Camelbak on me but ya gotta do what ya gotta do.
    Seat bag quality kind of sucks, in general. They all seem to fail on me, but some last longer than others.
    Jannd are good. They aren't perfect, but they are better than most. Just get one that doesn't have velcro straps around the seat rails, those don't hold up ime.
    The mini mountain wedge and mountain wedge II are the ones I have used. They have straps around the seatpost, so I can't help you there. Maybe their tubular bag is long and narrow like you want, never seen one.
    Kitty! Kitty! Kitty!
    Reputation: GelatiCruiser's Avatar
    Oct 2012
    Re: Can't find a seat bag I like
    They're not high capacity, but the timbuk2 (large) bags are really durable and I've yet to have a problem with it coming off my seat. It has 3 velcro straps... Two for the seat and one for the seat post. You can fit a tube, tool, levers, co2 cartridge/pump and keys.
    Reputation: SlowPokePete's Avatar
    Mar 2006
    I'm in the same boat.
    Ditched the Camelback a few years ago.
    Don't like a seat bag ... stuff rattles, gets wet then rusty if exposed to moisture, and I hate how it looks on my rigid ss.
    Been carrying my kit in a small pouch in my jersey pocket for the last couple of years. Tube, multi-tool, 2 CO2's with nozzle, piece of chain, quick-link, spare key, and a band-aid. Not in love with that set-up, either.
    SPP
    Rigid.
    Always Learning
    Reputation: BruceBrown's Avatar
    You could always get a frame pack instead of a seat bag. They come in several sizes (depending on how much gear you want to carry) and that will eliminate your legs hitting a seat bag that is too wide.
    What BB said. I got tired of a back pack in the summer heat, esp when I don't need space for extra just-in-case clothing. The medium Revelate Tangle fits my Bandersnatch nicely and holds a fair amount of gear. The Revelates cost more, but are extremely well made. There are other options out there, such as Jandd.
    Attachment 820167
    Plays with tools
    Reputation: customfab's Avatar
    I put my tube, co2 and multi tool in a quart sized freezer bag and stick it in my jersey pocket. It packs pretty flat and doesn't move around. I swore off saddle bags years ago.
    Reputation: ttusomeone's Avatar
    Quote Originally Posted by hammy56 View Post
    I have the Mutherload strap from Backcountry Research and use it to hold my tube and big air CO2. I keep it under the front of the frame triangle on my Epic. Then I have one of their bags that I carry my tire tool, multitool, etc in my jersey pocket. My legs always rub on seatbags so I found the best solution was no seatbag.
    I ride with a small wedge bag under my saddle and fit everything in I need. I use a Topeak Aero Wedge Small strap mount. I have a 29 tube, multi-tool and a CO2 inflator and extra CO2 cartridge.
    It doesn't rattle and I hit plenty of jumps and it's stayed secured.
    I don't wear jerseys with pockets, but there are enough things on the trail to hit in a crash, I don't need to add any in a Jersey.
    TopeakŪ Cycling Accessories ? Products - Aero Wedge Pack, small (Strap Mount)
    Can't find a seat bag I like-img_4921.jpgCan't find a seat bag I like-img_4922.jpg
    OG Ripley v2
    Carver 420 TI
    Jul 2013
    i use a timbuk2 seat bag that is about the same size as the one above, it actually came with my first bike that i bought used , it fits my work cell, my car keys, and a multi tool and some cash however im looking for a bigger bag.....not much into the camel baks for my daily riding and those straps wont hold my work cell....
    What's "social pace?"
    I've been using these for years. All I need unless it's a super-long race.
    I like turtles
    Reputation: TiGeo's Avatar
    Another Awesome Strap user here. I used the Race II strap for a 29" tube, tire lever, and 16 gram CO2+inflator. I can't see how it would ever fall out. I use their Tul Bag for my other stuff and toss in my jersey pocket. Love this set up. I use a hydration pack only for longer more remote rides. Sounds like you just need to get the tools out of the strap and into your jersey pocket.
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
    Quote Originally Posted by bixby View Post
    You can get the same bag I posted above in a medium size.
    OG Ripley v2
    Carver 420 TI
    Dec 2004
    Quote Originally Posted by TiGeo View Post
    Maybe I am thinking about giving it another try.
    I like turtles
    Good move.
    Dec 2004
    I'm trying to keep as much as I can out of my pockets. I'm on a full suspension with only one water bottle mount. I usually have a second water bottle in my center pocket. I don't want too much crap back there.
    Reputation: seat_boy's Avatar
    There's always the Carradice option!
    That'll carry as many 29er tubes as you would ever want (and a few gallons of milk, a loaf of bread...)
    Dec 2004
    Temperary fix. Awesome strap with tube Crankbrothers 19 multi tool and 2 tire levers in a Thompson stem bag.
    Can't find a seat bag I like-seatbag.jpgCan't find a seat bag I like-seatbag1.jpg
    I've got a similar bag to TwoTone's Topeak that is bolted to the seat rails with quick click mount. Never rattles and it's been through a lot for a few years.
    TopeakŪ Cycling Accessories ? Products - Bags > Wedge Packs QuickClick?
    Reputation: ianick's Avatar
    Lezyne has tall skinny seat bags. I can fit a fat bike tube in the Large. Might be what you're looking for.
    +1 on the Lyzene bags. I am using the M-Caddy. It has built in slots for cash, 2 tire levers and seperate storage underneath for a multitool which allows you to use without pulling everything out. It fits a 29er tube and 1 CO2. It is a snug fit so no rattling. It does use Velcro to attach but the straps are thick. No issues so far. It is also narrow enough that you won't rub your legs on it.
    Dec 2004
    Quote Originally Posted by jhardeman View Post
    One of my local shops has them. I passed on it because it looked like it would be too small. I will give it a second look.
  1. Replies: 5
    Last Post: 06-25-2013, 08:55 PM
  2. help me find a dj
    By Dan GSR in forum Urban/DJ/Park
    Last Post: 12-21-2012, 07:00 PM
  3. HELP ME (and others) find a job!
    By socalMX in forum Off Camber (off topic)
    Last Post: 03-16-2012, 04:11 PM
  4. Where to find 303 RDH
    By stunzeed in forum Yeti
    Last Post: 04-30-2011, 11:35 AM
  5. find
    By playu72 in forum General Discussion
    Last Post: 01-16-2011, 10:04 AM
