Results 1 to 10 of 10
    Sep 2017
    Cannot seem to find a fork
    1st post here so I'm sure it's been asked 1000 times. My bike is a 2018 Rockhopper Comp 29er. I'm looking to upgrade my fork. I've been looking at the Recon due to cost and adjustab. Tapered tube. I believe my axel is a 9mm quick release. I cannot find a Recon to fit this. What are my options.
    Reputation: Stopbreakindown's Avatar
    That is gonna be a tough one to find.
    Might want to check eBay/Pinkbike for a take-off
    Like this one
    https://www.ebay.com/itm/Rock-Shox-R...UAAOSwBjdZ8lIQ
    Edit:
    Important!
    When buying used/take-off make sure the steerer tube has enough length for your Rockhopper.
    You can measure yours to compare.
    BOOM goes the dynamite!
    Reputation: noapathy's Avatar
    Suntour upgrade program. Look into it. I'd probably go with a Raidon for that bike for budget reasons. $200 and done. (plus install if you're not comfy doing it yourself, but it's pretty easy honestly if you take your time and do it right)
    Sep 2017
    I'm not afraid of diving into anything like that, I'm relatively mechanically inclined. I like doing that kinda stuff myself so I'll look into that.
    Is there something I can do to my front hub asst to accept the bigger axel?
    Quote Originally Posted by my98hawk View Post
    The specs say it has Shimano hubs, so short of a new wheel, no. I wouldn't worry all that much about it at this point. If you keep going with the sport you'll likely want to get a different bike before the hubs on that one are the thing holding you back.
    Sep 2017
    Quote Originally Posted by noapathy View Post
    Yeah maybe. I'm a 40 yr old single tracker that just started riding with my son. I wasn't sure if he was really gonna get into it so I didn't wanna splurge. He's gonna end up getting a better bike before I do. They have a youth XC team here that he's gonna race with next season.
    Reputation: RajunCajun44's Avatar
    Recon is a good choice... here is a take off.. ebay item # 132232739186
    https://www.ebay.com/itm/2017-RockSh...AI132232739186
    Sep 2017
    That's exactly what I was looking for. Thanks a ton. Don't need remote lockout but not a big deal. I'll measure my tube to see if that one will fit.
    Going to an air fork is a huge upgrade in weight and performance.
    Might want to pick up a shock pump so you can correctly set sag you get it installed.
    Lots of walkthroughs on the youtubes if you need any help
    Sep 2017
    I've helped a buddy set his sag. Hind sight is 20/20. I do like my bike but wish I'd sprung for one with a better fork. I don't need the best around but my pogo stick does a little bouncing and it bottoms out quite a bit. Maybe I need to shed some weight. 😁
  1. Replies: 16
    Last Post: 07-09-2016, 01:48 AM
  2. Replies: 11
    Last Post: 08-16-2015, 08:30 AM
  3. Can't seem to find an aftermarket 34mm seatpost collar
    By chuckxiii in forum Specialized
    Last Post: 08-16-2013, 07:14 AM
  4. Replies: 24
    Last Post: 08-16-2012, 12:32 PM
  5. Replies: 10
    Last Post: 08-04-2012, 12:16 AM
