Results 1 to 2 of 2
    Reputation: Katie785's Avatar
    Cannot get my fork to feel right. Rockshox RL 2012
    Hey guys. I have a 2012 Rockshox RL 29er fork on my Niner emd. I'm 125lbs, but I had to set this fork with enough air to support a 190lb person. It kept bottoming out, which would send me flying over the bars if it caught me off guard. Anyone have any baseline suggestions? I cant get it right and I'm getting frustrated.
    Oct 2012
    You might want to post this over on Shocks and Suspension. Sounds like you either have way too much air in the negative [-] chamber at the bottom of the left forkleg or the seal inside between the positive [+] top and the bottom negative chamber could be leaking. Should be about 80 lbs in each by my reckoning. And it should stay even after a ride, although you'll lose about 10 lbs attaching the pump.
  1. Replies: 5
    Last Post: 03-07-2013, 08:57 AM
  2. 2012 Rockshox Revelation RCT3 Dual Air 140mm Fork
    By kevinboyer in forum 29er Components
    Last Post: 12-21-2012, 09:44 PM
  3. Replies: 8
    Last Post: 07-30-2012, 10:51 PM
  4. Replies: 5
    Last Post: 06-11-2012, 09:55 AM
  5. RockShox SID damper upgrades > 2012 parts in a 2009 fork?
    By cws196 in forum Shocks and Suspension
    Last Post: 02-03-2012, 12:48 AM
