Results 1 to 3 of 3
    bikerbert
    Reputation: bikerbert's Avatar
    Came Creek Ergo Control II clamp too big for my bar
    Richie WCS carbon bar is what I was trying to put them on but the clamp wouldn't go tight enough. Is there any way around this?
    jms
    jms is offline
    Reputation: jms's Avatar
    Feb 2006
    Red LocTite
    Try red LocTite if the bar end is just slipping a bit. If the bar end still isn't stable, the old stand by, an aluminum can shim wrapped @ the bar w/red LocTite under the bar end. Beyond that, replace the bar with a Syntace or 3T bar.
    If it's any consolation, I haven't had the best of luck w/Ritchey components over the years either.
    My Favorite Peeps:
    bikerbert
    Right on! I will try that, thanks!!!
