Results 1 to 11 of 11
    Nov 2013
    broken xx1 x dome cassette
    Has some one encounter this problem the locking system on my xx1 cassette just break, who knows if it is covered by warranty???
    Reputation: SlowPokePete's Avatar
    Mar 2006
    How did it break?
    SPP
    Rigid.
    Nov 2013
    I was re tightening it to my hope xd driver body,
    this cassette is pretty new it only has about 3 weeks of use and about 13 rides, i remove it to replace a faulty bearing in the hope xd driver and half od the teeth broken when i was re tightening it, i have not even reach the 40n/m required not even 25n/m.
    SRAM...Shimano who cares?
    Dec 2011
    Did you pick it up at your LBS?
    If so take it by and let them look at it...They can get ahold of SRAM and see it is covered.
    I'm certain that they (SRAM) can still help you through the problem (either way) promptly and fairly.
    Nov 2013
    What is LBS???
    Bicycle Addict
    Reputation: J3SSEB's Avatar
    Local Bike Shop
    The unexamined life is not worth living - Socrates
    Bearded Women Racing
    Wrench
    Reputation: FNFAL's Avatar
    Sram has an incredible warranty department. This will be replaced free of charge.
    I've sent numerous Sram products back. No worries.
    Reputation: Jamie_MTB's Avatar
    Yes, I lost a few teeth on mine when I was switching between wheels :-(
    Nov 2013
    Are you still able to remove the cassette??
    have you try warranty on them???
    I'm not able to remove them from the driver body should send them back with the driver body too.
    I lost two teeth and can still removed it.
    I don't swap wheels anymore :-( and I didn't send it back.
    Reputation: global's Avatar
    Same thing happened to mine just left it on my old wheel.
  1. Broken chain so should I replace rear cassette also?
    By peter19ue in forum 29er Components
    Last Post: 10-27-2013, 02:44 PM
  2. Broken Cassette - Fix It Myself?
    By jdawg5600 in forum Beginner's Corner
    Last Post: 04-11-2013, 02:39 PM
  3. My rear cassette is broken i think
    By thredbo in forum All Mountain
    Last Post: 01-17-2013, 10:53 AM
  4. Broken Cassette?
    By robin_hood in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-19-2012, 02:05 PM
  5. Ever broken a Cassette like this?
    By Klurejr in forum California - Socal
    Last Post: 06-17-2012, 08:23 PM
