Results 1 to 9 of 9
    Sep 2012
    Bottom Bracket Problem -- Question for Mechanics
    Hey, I have a 2011 carbon Trek Superfly 100 with about 3500 miles on it. Purchased in late April of 2012.
    Here is the problem; the bottom bracket makes a very squeaky (not creaky) sound when the crank is rotated. I have isolated it by removing the chain and petals, so it can't be the chain ring bolts either. I have yet to pull the crank (anXT 2x10 crankset with about 300 miles on it) to see if the seals are dirty or damaged. The BB95 is a stock ceramic set. It is possible that the BB is toast already? I don't ride often through much water and keep the bike clean. Suggestions?
    29er
    pull the crank, at best it needs grease
    B.Ike
    Reputation: ElwoodT's Avatar
    Mar 2011
    I have had good luck reassembling with teflon tape. (important to remember to wrap in the same direction its going to get threaded).
    at that mileage you might need a new one.
    Sep 2012
    Pulled the crank set to clean the seals, wavy washer and re-grease the spline. All is good now. Thanks for the suggestions. elwoodturner, remember that a BB95 is a press fit system, therefore teflon tape would not work as there are no threads. Friends who have threaded BB use teflon with good effect. I think it was water contamination all along. I went for an unusual (for me) ride through many stream crossings and the bike was really dirty afterwards. I washed it and either the stream water or wash caused the noises. Good to know. Thanks!
    B.Ike
    Mar 2011
    ^^my bad. My hats off to you btw with that kind of mileage since late April. I'm guessing I'm at about 1000+/-.
    I have put the blue locktite gel on the bearings when pressing them back in the frame and had good luck with no noise.
    Sep 2012
    Quote Originally Posted by dlennard View Post
    Good luck removing the BB95 you installed with blue locktite! When the bearing is pressed into the seat lip that locktite might bond it to the frame more or less permanently. You will have to be especially careful when pressing the BB out.
    Sep 2012
    Quote Originally Posted by elwoodturner View Post
    I do ride a fair bit of mileage every week. It is not only good for my physical health, but my mental state as well!
    Quote Originally Posted by beastmaster View Post
    I have removed them several times this year to clean and grease and had no problems. I had creeks after several rides when I did not use the locktite. I think I read to use it in a manual somewhere.
