Results 1 to 39 of 39
    Big Hands Big Grips
    I need a new set of grips for my big hands on my big bike. I have run Ergon GP1 but have faded away from that and back on an older set of Ritcheys on my FS bike and I now feel I have a little better control. The new HT has very thin grips that have to go. I want lock on's but need large diameter grip. Can you big handed guys offer some input?
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    Lizard Skins North Shore. Great grips and considerably fatter than anything else I've tried.
    Reputation: rodgerdodger's Avatar
    I like the ODI Rogue, they are pretty fat.
    Out spokin'
    Dec 1999
    Ourys are the fattest I've used. They're available in lock-on version.
    --sParty
    disciplesofdirt.org
    Race Face Strafe
    Reputation: jerry68's Avatar
    <3
    Quote Originally Posted by Sparticus View Post
    --sParty
    OURY FTMFW!!!. I have them on all four mountain bikes, on my Triumph 675 SE and Sprint ST, as well as both of my KTMs.
    Pisgah Area SORBA
    Quote Originally Posted by kjlued View Post
    ... your idea of technical may be much different than other peoples idea of technical.
    Bigger is better!
    May 2005
    Big Hands Big Grips
    Quote Originally Posted by rodgerdodger View Post
    Agree. And soft.
    Out spokin'
    Dec 1999
    Quote Originally Posted by jerry68 View Post
    I've got a '06 Triumph Sprint ST as well. Awesome machine. Sadly, it's for sale. Gonna try to keep my lil' '96 Honda XR4, tho. Best bike EVAR.
    --sParty
    disciplesofdirt.org
    Oury.
    +1 on the Rogues
    It's worth noting that, if I recall correctly, ODI makes the Ourys, or vice versa, they're basically the same, just different pattern, so Ourys are smoother or something. So both will work for the same reasons
    Rod
    Rod is offline
    Reputation: Rod's Avatar
    Oct 2007
    Quote Originally Posted by XJaredX View Post
    Oury.
    Can't beat Oury.
    There is not much choice between rotten apples.
    I measured the diameter of my Oury's...32mm.
    I read from an ebay seller the latest version of ESI Chunky's are 32mm also.
    ...Anybody use "Shoe Goo" (big tube available at Wal Mart sports dept.and housewares etc, dept. among other locations) to install them on alloy bars? not sure if the chemicals in it work well with the sensitive nature of carbon bars though.
    Shoe Goo - Wikipedia, the free encyclopedia
    roccowt.
    rocnbikemeld
    Always Learning
    Reputation: BruceBrown's Avatar
    Quote Originally Posted by vcyclist View Post
    This subject comes up every now and then. You can build up any grip you want with tape underneath on the bars to easily accommodate larger hands. It's the same premise that is used in the golf club gripping industry where you build up the tape underneath, slip the grip over the tape (using a solvent) to add thickness to any grip to take care of your big mitts.
    Masking tape would be the cheapest and easiest to use to build up the bar underneath the grip.
    Another vote for the North Shores.
    Reputation: Bike Whisperer's Avatar
    ESI Extra Chunky
    34mm diameter
    Extreme Steering Inc.: Extra Chunky
    Nov 2012
    I'm an avid golfer. We put wraps of masking tape on the shaft, then apply double sided grip tape, spray with solvent and slide grip on. whent he solvent evaporates/dries, you have a slightly larger grip and stuck in place good. Seems to me like this could work with bike grips too or am I way off base here?
    Quote Originally Posted by langen View Post
    Agree. And soft.
    Quote Originally Posted by ronyc View Post
    +1 on the Rogues
    Pretty much this. I have large hands and used to get pain from smaller grips. I love my Rogues!
    OG Ripley v2
    Carver 420 TI
    NMBP
    Reputation: crashtestdummy's Avatar
    Jun 2005
    I realize that the OP quit using Ergons, but I believe they are one of the largest diameter grips available. I fought with mine for awhile, but once I got them set correctly, I never looked back. Mine measure 35 mm diameter at the part nearest the shifter, which has the smallest overall circumference. I ride without gloves because I can't find any gloves that don't cut off circulation.
    Always Learning
    Quote Originally Posted by cpfitness View Post
    Nope - see post #14. ;-)
    Nov 2012
    Quote Originally Posted by BruceBrown View Post
    LOL no idea how in the hell I missed that!!!!!!!
    Out spokin'
    Dec 1999
    How big do you want?
    Quote Originally Posted by zarr View Post
    I measured mine with a digital caliper as well:
    Rogues = 32.2mm
    Oury's = 33.5mm
    Both mine are the ODI Lock-on versions. The Rogues are pretty old, though... they might have lost a mm or two over the years. Oury's are brand new.
    --sParty
    disciplesofdirt.org
    Race Face Strafe
    Nov 2012
    Re: Big Hands Big Grips
    Sex toys are cool
    Sent from my DROID RAZR using Tapatalk 2
    Nov 2008
    I used to run the lizard skin northshore, but the rubber always started melting/dissolving onto my gloves after many miles of use, then switched to odi rouges. The rogues were nice but had the same problems. Ive had the same happen with motorcycle gel grips. I think it was caused by tons of use in hot weather and leather-ish gloves. Then switched to oury and really liked them until my weight wheenie addiction kicked in hard.
    Then switched to the ESI chunkies and fell in love. It's definitely a lot more work installing and removing..but well worth it in my book. I keep hearing about the super chunkies and can't wait to get my hands on them. They are thick, soft, and lightweight. They are also not affected by water or other elements. I'm completely converted to the non-locking grips.
    Grips are grips, and very inexpensive when compared to other components. I always felt they were one part that you could exchange out frequently without breaking the bank. There is nothing like a fresh pair of grips on an all day epic.
    Another +1 for the ODI Rogues. I like the look and feel of the Ourys, but I have never run across the lock-on version in person. I really like the lock-on feature of the Rogues, and they interface nicely with the Cane Creek bar ends (which I thought were ridiculously expensive until I tried them, now I don't want to ride without them).
    Reputation: The-Ox's Avatar
    Agree. And soft.
    If you can palm a basketball then Rogues are for you
    Feb 2005
    I wear XL gloves and love the Rogue lock ons. Ourys also good, but a bit too big for me. I tried the ESI chunky grips in a misguided fit of weight weenie-ness, and in addition to the installation/maintenance issues with non-locking grips, I found they were very slippery in the wet.
    Dab-O-Matic
    Reputation: Simplemind's Avatar
    +2 on the ESI Extra Chunky!
    Dec 2010
    Oury's are great, I have big hands and they are great for when your hands sweat through your gloves or if the grips get wet, they seem to always stay tacky.
    Oct 2012
    I wear XXL gloves and have ODI Rogue and Raceface Strafe grips on my bikes ATM. They are both about the same size (large) and offer good grip and trail chatter suppression.
    If you want something to match the rest of your bike then the Strafes come in a few different colours, they are also made by ODI for Raceface so no difference in quality when compared with the Rogue.
    Reputation: tartosuc's Avatar
    a few weeks back i bought a set of superstar component excell grip...huge grip, same feel/comfort as the rogue with few mm ticker and longer..cheap too...i'm switching my rogue for theses on all my bikes...
    expensive cars are a waste of money. Expensive bikes...not so much!
    Big Hands Big Grips
    Quote Originally Posted by tartosuc View Post
    Those look cool, I like the weigh - too bad their stuff is hard to get in the USA.
    Is the lock-on mechanism (i.e. the lock-ring/grip interface) the same as the ODI?
    Quote Originally Posted by SAWS View Post
    similar but not the same, the superstar clamp is deeper than the odi. i'll try to snag a pic tonite
    ESI Super Chunky again. Never thought I'd move on from Ourys, but these are (a bit) bigger and better.
    Tape, etc. under grips sounds like a recipe for disaster if things get wet.
    Whining is not a strategy.
    change is good
    Sep 2004
    Bontrager thick grips, bigger than Oury lock ons.
    Jan 2009
    Rode North Shore for years and liked them...Now use Specialized XL Enduro grips and like them better in every way.
    33mm wide and 5 colors
    heres a pics to compare locking mecanism of the superstar vs the odiBig Hands Big Grips-image.jpgBig Hands Big Grips-image.jpg
