Results 1 to 9 of 9
    Jul 2013
    Best tires for...
    Just bought a brand new TBLTc with frequency i23 Teams. Came tubeless ready, but has Ardent 2.25 on front and rear. I am used to Maxxis Minion DH's 2.35 on my 26 inch hard tail but I think they are too much tire for where I ride. My daily riding is hard pack combined with loose shale and baby head sized rocks along with a lot of roots. Yup. Central Pennsylvania has some pretty diverse trails. So I need a jack of all trades tubeless tire.
    Hit me!
    the 2.25 ardent are good on the rear, although something like an ikon will be much faster. I did not like the ardent in the front and am using a hans dampf. We have a lot of hardpack and rock, not a ton of roots.
    I run around 20psi @165 lbs
    Jul 2013
    Anyone else have an opinion?
    Rod
    Rod is offline
    Reputation: Rod's Avatar
    Oct 2007
    I don't ride in those conditions and I don't use tires that big so I have nothing to offer you except for this free bump to your thread.
    There is not much choice between rotten apples.
    Jul 2013
    Thanks for the bump. Can't believe there are no more opinions.
    Reputation: Chuch's Avatar
    Jan 2013
    I'm riding a ton in central Virginia and am doing quite well with the Specialized Purgatory 2.3. The new version rolls pretty well and seems to like everything but deep sand. I'm really digging it.
    May 2013
    The 29" High Roller II's just came out for 29ers. That would be a perfect tire for your needs; the tire would fall right in between the Ardent and the Minion.
    Mar 2011
    I have the TBLTc and tried several tires . The stock Ardent 2.25 doesn't do it, try the Ardent 2.4 run at low pressure, I like the Spec. Ground Controlls both front and back, I now run the Spec. Purgatory front and the Ground Control rear, this gives me good grip but fast rolling. If you want max. grip on the front you could try the Spec. Butcher.
    Feb 2013
    Best tires for...
    I heard conflicting reviews of the 2.2 ardent so I went with a 2.4 rear ardent and left my 2.4 mountain king up front. The ardent is amazing, I can rail some turns and berms now without scrubbing brakes anymore.
  1. Switching from off road tires to street tires...suggestions?
    By bpreachers in forum 29er Components
    Last Post: 04-13-2013, 10:35 PM
  2. turning your tires into snow/ice studded tires.
    By Clozedeyez20 in forum Wheels and Tires
    Last Post: 02-23-2013, 11:38 AM
  3. Question about Schwalbe tires to replace stock tires
    By bosco0633 in forum 29er Components
    Last Post: 03-06-2012, 08:40 AM
  4. Replies: 4
    Last Post: 10-07-2011, 05:04 PM
  5. Wider tires, less rolling resistance, what about taller tires
    By HighLife420 in forum Wheels and Tires
    Last Post: 06-01-2011, 06:23 PM
