Page 2 of 2 FirstFirst 12
Results 101 to 170 of 170
  1. #101
    My 3 friends have Tmars dropper, cheap chinese one from amazon or ebay. Not that smooth, but still works after more than 6 months, and they took off the boot too. Once awhile get sticky.
    Brand new is like $80, comes with shim.
    Other friend has reverb, no problem, he is light though,about 130 lbs. Another friend has KS lev, mucho problemo, he is 200 lbs.
    I am on my 2nd GD for 4 months now, no boot, with shim. First one for 5 years, sold it with the bike.
    So reliable, never warranty it, very simple and just work.
    So I believe GD is the most reliable dropper right now. What is the second most reliable dropper?
    For future build i wanna try something else.
  2. #102
    Aug 2015
    I don't believe how many drama's people have with droppers... at the price of a dropper post you'd assume they would be pretty reliable and last forever.
  3. #103
    Quote Originally Posted by LinkyPinky87 View Post
    Gravity Dropper's does
  4. #104
    Quote Originally Posted by Christopher Robin View Post
    How's the GD for rebuilding?
    Sent from my D6653 using Tapatalk
    For my main bike that I ride a lot, I have to take it apart and regrease one time per year, which takes 10-15 minutes and requires only hex wrenches, and they give you the really small one for the switch plate and grub screw.
    I suppose that the internal surfaces may wear out after a while, but that probably takes years and negelct, no grease, and GD would likey rebuild for you. Since it is canle activated you may need to replace the cable over time, too. I have done it once although it probably wasn't necessary. I found replacing the cable to be similar but easier than replacing a shufter cable, just thread through the switch requires a little patience.
    Overall, it is an amazingly easy DIY serviceable component.
  5. #105
    Nov 2006
    After 6 years of ownership and abuse, 5 of which with no boot, I have finally had to rebuild mine. I opted for just buying a complete rebuild kit from GD (basically just the inside tube with bushings installed), $40 and 15 minutes later it is literally brand new again.
    My only gripe is I wish the cable came out of the post vertically instead of horizontally, ala KS Lev.
  6. #106
    climber
    Dec 2008
    Fox DOSS
    Quote Originally Posted by inter View Post
    Fox DOSS? I too have used GD classic for years - but needed a better looking post for my nice bike etc. Under $300 and I was surprised to find out that I like the 2-lever remote - very intuitive, especially if you come from GD.
  7. #107
    Sep 2012
    OK, this is stupid!
    I have a 2016 Rockshox Reverb Stealth 150 dropper that has failed 3 times in 14 months-2 of these times it was within 12 months of purchasing it new. Twice it was warranty repaired by Sram. Unless they give me a new 2017 dropper I will not be bolting this back onto my bike! F#ck!!!!
  8. #108
    Sep 2012
    Quote Originally Posted by beastmaster View Post
    OK, this is stupid!
    UPDATE! Sram is sending a new 2017 B1 replacement post. They recognized the old A1 post had design problems. Amazing!
  9. #109
    I wonder what design problems SRAM will recognize a couple years from now?
  10. #110
    Reputation: CrozCountry's Avatar
    Mar 2011
    I hope they will send you a C1 when they find the design problems in B1
  11. #111
    Sep 2012
    Quote Originally Posted by CrozCountry View Post
    I am giving serious consideration to selling the new unit and replacing it with the new FOX dropper. Problem is that ALL dropper posts have issues of one sort or another. It is just that oiling my seat tube repeatedly is getting old; each time it has happened I had to replace the BB to get it cleaned up. Not good.
  12. #112
    Reputation: Fairbanks007's Avatar
    SRAM really p*ssed me off when they figured out they were going to be replacing pretty much every Reverb ever sold under warranty and decided that an almost entirely new set of internals every year was expected maintenance and therefore not covered under warranty.
    I get it, you designed a flawed product that had a much higher warranty rate than was expected or sustainable. Fine, mistakes happen. The right thing to do would have been to honor those original warranties and change the warranty on newer models.
    Oh, and beastmaster is 100% right, ALL droppers have their issues. The PNW Ranier and 9point8 Fall Line both have features that look promising. I especially like that the Fall Line can lock into any position even if it loses pressure. Better than riding miles back to the car with a f@cked up Reverb.
  13. #113
    Mar 2016
    Quote Originally Posted by racebum View Post
    i'm in the same boat. have a 31.6 ks lev dx and like it. but. the 27.2 has worse reviews and i'm still trying to figure out what was changed and if it's a good buy. i have a carbon superfly that needs a 27.2 and the lev or thomson seem like the way to go. i like the collar cable method of the lev MUCH more.
    you ever look into this?
    I have a new KS LEV 272 on a Salsa Beargrease. Solidly built and really attractive for an external cable dropper. It's super smooth. Plus, you can pick the bike up by the saddle when the dropper is down and not introduce an air bubble into the cartridge (primary cause of failure in the LEV Integra that has a different, older mechanism). Only complaint is that the 272 isn't pressure adjustable and its return speed is a little slower than I prefer. I'm hoping with use it'll break in and elevate a little quicker. The wider LEVs are adjustable with a shock pump.
  14. #114
    Oct 2015
    Quote Originally Posted by bikercr View Post
    Nope, not gonna happen. I have been using this thing for almost a year (love it) but it's still slow as heck :|
  15. #115
    Aug 2017
    I have had good luck with PNW components. I put their externally routed Cascade on my Focus XC bike and their internally routed Bachelor on my Evil Following. No issues so far, or hydraulic fluid.
  16. #116
    Anytime. Anywhere.
    Reputation: Travis Bickle's Avatar
    The best is, oh never mind, it's not 29er compatible, sorry.
    I got some bad ideas in my head.
  17. #117
    Giant Reign 27.5 2 LTD
    Reputation: ka81ua's Avatar
    Oct 2014
    Is the new 2018 fox transfer with kashima and internal routing the best today?
    OK
  18. #118
    +1 on what Beastmaster said:
    "..Problem is that ALL dropper posts have issues of one sort or another."
    I've owned different brands but eventually it's the switch feel and placement that bothered me the most.
    The Crankbrothers highline remote switch, which you can buy separately, is the best I've used so far w/ its adjustability. No issues w/ the highline dropper post after a year of use.
    That said, my Gravity Dropper is still going strong after 10 years. It's easy to fix and maintain if your the DIY type.
    d butt u kicked today, could b d same butt you'll kiss tomorrow.....
  19. #119
    Reputation: Stalkerfiveo's Avatar
    Feb 2015
    Giant Contact SL is what I settled on after TWO 400$ posts (9.8 Fall Line and RF Turbine) took dumps in less than 2 years. The Giant is only 180$, has a 2 year warranty, and if it fails outside of warranty the replacement cartridge is only 60$ and replaces with simple tools. Iím done with expensive droppers.
    In serving the wicked, expect no reward, and be thankful if you escape injury for your pains.
  20. #120
    Oct 2014
    Where to get cartridge for newest giant contact dropper?
    395
    OK
  21. #121
    Jun 2016
    Quote Originally Posted by ka81ua View Post
    395
    Any local shop that's an authorized Giant dealer. If the post is under warranty, you may have to send it in.
    I'm also fond of the Giant dropper. My first cartridge suffered infant death after a handful of rides, but the warranty replacement has been dead-consistent for months.
    It's a little heavier than I'd like (570g w/o remote for the 30.9/150 model) and the remote is pretty bad, but it's cable-actuated, so that's an easy fix.
  22. #122
    Reputation: racebum's Avatar
    Mar 2013
    It's a good one. If I had to vote for best it would be Thompson. It's one of the lightest and the most reliable
  23. #123
    Oct 2014
    Quote Originally Posted by alexdi View Post
    Any local shop that's an authorized Giant dealer. If the post is under warranty, you may have to send it in..
    Uhmm.. It's obvious that i was asking about buying it by myself somewhere at online-store.. ))
    OK
  24. #124
    Feb 2015
    Mine came with the Giant 1x style lever and not that goofy toggle switch looking style. Iíve been pleased with it.
  25. #125
    Oct 2014
    Maybe someone alreade tried to find out:
    what is the smallest (shortest overall length) dropper seatpost with 150mm hub and internal routing?
    OK
  26. #126
    Reputation: Sid Duffman's Avatar
    Oct 2015
    The shortest I've come across are the KS Lev Ci and 9point8 at 440mm. BikeYoke Revive is 435mm from the bottom of tube to the rails, but 466mm from the rails to the tip of the thingy at the bottom to the tube.
    It's worth noting that there are 2 measurements on the dropper to consider. 1) the distance from the collar to the seat rails, and 2) the insert length (from the collar to the bottom of the tube. Some bikes have a bend in the seat tube, which can prevent you from being able to fully insert the post all the way to the collar.
  27. #127
    Mar 2011
    Maybe someone alreade tried to find out:what is the smallest (shortest overall length) dropper seatpost with 150mm hub and internal routing?
    Raceface Aeffect 425mm
  28. #128
    Reputation: @Ride@'s Avatar
    Aug 2017
    I love my Bontrager. I made a boot out of an inner tube to keep the silicon grease all on it and ensure reliable operation.
  29. #129
    Jan 2016
    Does anyone has some feedback about TMARS dropper seatpost, i am interested in the model 419L because my legs are real long and it could fit my mountain and fat bikes, the total lenght is 445 mm, 27.2 or 30.9 mm with the included shim.
    You can also suggest other brands or models on the affordable range.
    Jan 2017
    I like my LEV 272 when itís working but it went bad within 5 months. Sent it in for warranty through my LBS and after 2 months the shop just gave me a new one saying KS was unresponsive and they had no idea what was going on. They said KS hadnít responded to ď35 messagesĒ. Weirdly the receipt they gave me said it was a UPS shipping claim so maybe it never made it to KS. My LBSí service has been pretty terrible anyhow so Iíll try out a new shop and only go back if I have to warranty this KS post again.
    What is different in the LEV 272 vs Integra that allows you to lift up on the seat in down position w/o creating a bubble? I wondered if this was a factor in my first one going bad and have been careful not to lift by the seat with the new one so far.
  31. #131
    I just bought Brand X, external version from CRC, $120 shipped. Very good review and good price. I replaced the remote with wolftooth.
    So far so good , been on few ride.
    This dropper replaced my old trusty GD, Brand X is so smooth.
    my GD still works, just not smooth anymore, and i wanted to try hydraulic.
    Will see how durable brand x is.
  32. #132
    May 2010
    Geeze for $120 even if it explodes after 2 years you'll be ahead of the game with a $350+ dropper
  33. #133
    Reputation: manwithnoname's Avatar
    Apr 2005
    BikeYoke Revive. I've been running 2 160mm 31.6 posts on 2 different bikes for the past year and have had zero issues, absolutely flawless. And the modulation and Triggy remote is much better than other posts I've had in the past - KS LEV (had to send to KS for warranty repair), KS i-950 (had to send to KS for warranty repair), Thomson Elite (great post, but not on the same level as the Revive).
  34. #134
    May 2013
    Current Inventory:
    2- Thompsons
    1- Crank Brothers Highline
    1- Fox Transfer
    2- Bike Yoke Revive
    The only post that hasn't gone back yet is the Bike Yoke. It is still early days but looks solid. I have had KS, X-fusion.... in the past as well. The Fox Transfer lasted 13 months, a world record for me.
  35. #135
    Reputation: Specypippo's Avatar
    Dec 2017
    what i don't like from reverb, and i always use and used it, is the hydraulic pumping instead of a cable, but i think that it's very reliable!!!!
  36. #136
    Feb 2015
    I have the Brand X internal on my Trek hardtail and really like it so far. I will say I don't think they greased it very well from the factory. It was coming up a bit slow. I unscrewed the seal head, added some Rock N Roll grease, now it's nice and smooth and considerably faster. Has a nice top out "clunk" so you always know when it is all the way up.
    Hard to beat this post for 110$ shipped.
  37. #137
    Aug 2017
    In this 2-page discussion we have one post (excuse the pun) on Raceface, the Raceface Aeffect. I'm about to install the Raceface Turbine this weekend and let folks know after so many rides.
  38. #138
    Reputation: The Boz's Avatar
    +1 for the Bike Yoke Revive. Sweet post.
  39. #139
    Feb 2015
    Quote Originally Posted by ZillaG View Post
    Itís garbage. Killed it in 3 months then took 6 weeks to warranty.
  40. #140
    Aug 2017
    Quote Originally Posted by Stalkerfiveo View Post
    That's not good.
  41. #141
    Feb 2015
    That's not good.
    I killed a 9.8 Fall Line Iím about the same amount of time. The Turbine uses the same guts.
  42. #142
    Reputation: mtbboy1993's Avatar
    Apr 2015
    I returned 4 Turbine dropper posts so far, firtpair were leaking second brake failed, I had other issues too scratched stantions on the same spot on two dropper posts.
    ehre is my review: https://wp.me/p60aTF-2sW
  43. #143
    My Santa Cruz dealer told us while demo'ing bikes one weekend that their worst product of 2017 was RF droppers. Constantly warrantying and rebuilding.
  44. #144
    Feb 2015
    Quote Originally Posted by mtbboy1993 View Post
    The Giant Contact Switch and Brand-X droppers are both less than 200$ and I havenít been able to kill either one of them so far.
  45. #145
    Jul 2017
    Getting ready to send my turbine in which i should have done a good bit ago. Itís a year old with normal usage. Def not recommended and why Iím here researching a new dropper.
  46. #146
    B.Ike
    Reputation: ElwoodT's Avatar
    Mar 2011
    Quote Originally Posted by cjsb View Post
    I have two GD...one of them is 8 years old, and aside from one cable replacement and a yearly overhaul (EZ) it has been solid and reliable...It's ben on at least six different bikes.
  47. #147
    Quote Originally Posted by ElwoodT View Post
    I had 4 of them until recently. I sold my two oldest ones because no longer needed, got two new bikes over past 6 months and went with new GDs that match the seat post size instead of using 27.2 with shims.
    I sold my 2 GD 27.2 posts on Pinkbike and Craigslist for $130-150 each. They worked just as well as when they were brand new out of the box. A used GD post can be a real bargain.
  48. #148
    Reputation: Rngspnr's Avatar
    Feb 2016
    I have two BrandX droppers. Using one for a year now and no issues. So far very reliable especially for the price.
    2016 Evil Following V1
    2016 Dartmoor Primal+
  49. #149
    Aug 2017
    Is the GD external routing only?
  50. #150
    Jun 2016
    That's not good.
    Same here. Replaced with a Giant.
  51. #151
    Jul 2016
    I am digging my BikeYoke Revive 185mm. Can get a lot of drop for available insertion. Theyíve minimized collar height and seat mount height compared to the Fox (my other fav) and the Reverb (have had two fail practically new in the last year. Took them off all my bikes. Three failures in total and a bunch of hassles along the way POS IMO).
  52. #152
    Jul 2017
    Bikeyoke is the best. User serviceable. You can change the lower section to a different diameter without buying a whole new dropper. Comes with a very nice remote with the whole package. The Reset lever makes it so that you never ever have a saggy post again. Itís drops and extends smoother than any other post Iíve used.
    Itís perfect. Why would anyone use anything else?
    I no longer like to party. But I like the idea of it.
  53. #153
    May contain nuts
    Reputation: Haggis's Avatar
    Bought 5 Reverbs and havenít had one failure in 5 years. User serviceable to anyone with half a cliue.
  54. #154
    Happy Trails
    Reputation: Scott In MD's Avatar
    My 31.6 Reverb failed and now drops 1-2 inches at random times. I talked to LBS about servicing it versus replacing and service manager strongly recommended selling the Reverb as is (i.e. TFU >> cheap) , then replacing with a KS Lev. We also talked about Thomson (pricey) and Fox (must send in for service) so I am going with the KS Lev. I'll update after I ride it.
  55. #155
    Reputation: Gravityaholic's Avatar
    Aug 2014
    I now have two of them so I always have one that works ! My first was a Ks Dropzone that failed after one season, then I got an X-fusion HILO that now drops a inch when I sit on it after a season of use. As soon as my KS comes back from service I'll send the hilo for warranty work.
    So for me it's not "if" but more "when" will it fail.
    High on dopamine
  56. #156
    May contain nuts
    Quote Originally Posted by Scott In MD View Post
    Sounds like a good salesman.
  57. #157
    Reputation: targnik's Avatar
    Jan 2014
    The one I'm using ;-P
    'Born to ride!'
    "Mountain biking: the under-rated and drug-free antidepressant"
  58. #158
    Aug 2005
    Here's my personal dropper experiences.
    Crap dropper posts I've owned and cursed:
    Rock Shox Reverb - frequent sag, doesn't work in cold temps, annual rebuild is expensive and a hassle.
    Race Face Turbine - violently fast return, huge pain to set up, constantly leaked air, only way to access the air valve is to remove the seat, also constant sagging.
    Awesome dropper posts I'm currently using:
    KS Lev Si and Fox Transfer - both are reliable, easy to set up, work in all temps and just work every time I use them.
    2016 Santa Cruz Hightower 29er
    2016 Chromag Surface 27.5+
    2013 Transition TransAM 29er
    2017 Motobecane Lurch FS 26 fat
  59. #159
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by almazing View Post
    Just got back from the Whiskey Off-Road and a ton of other riding. It's hard to explain to other riders how effortless the Revive lowers and how smooth the action is. You think a transfer works until you ride one of these and see how smooth it is. This one is my original (I have two) that has seen a couple seasons now. I have a transfer too and have used a few others. No contest.
  60. #160
    I only have 100 miles on my new Bike Yoke Revive but man is it a sweet dropper. I was recommended by a friend to go with the Bike Yoke, and he had tried them all, Fox, Rockshox, etc. So far I'm not disappointed, it is works great.
  61. #161
    Reputation: unrealityshow's Avatar
    Oct 2017
    If anyone thinks there is a better drop post than the Bike Yoke Revive after riding one, they may be mentally ill. It is amazing. It is incredibly smooth at all temperatures.
    I have read about or personally experienced every other post failing in one fashion or another. Not so with the revive.
    At this point I donít think I could ride a bike with out one.
  62. #162
    Reputation: beer_coffee_water's Avatar
    Mar 2011
    OneUp dropper is legit. Super smooth through all of its travel and positively locks anywhere in its range. All without any sag or wobble. I am not running their remote, but the ergos of it are the best also. I have not had any time on a Revive, but saving $130 or more there is no reason for me to chase after a Revive.
  63. #163
    On my bikes I had two Thompson Elites and one Reverb. The Thompson's were much better, working consistently and super reliable. The Reverb was ok initially then developed problems. Ultimately I replaced it with another Thompson.
    I'm now going to put a dropper on my RKT 9 RDO. I'm thinking of trying a BikeYoke Revive on it based on all the positive reviews. Seems like it is the dropper to beat these days.
  64. #164
    Reputation: inonjoey's Avatar
    Quote Originally Posted by beer_coffee_water View Post
    How long have you been running it?
    "So you think it's the hat?... A lot of people hate this hat. It angers a lot of people, just the sight of it." - Uncle Buck
  65. #165
    Well, you've had it for what, a few weeks? Being able to stand up to several seasons of use and still function perfect is the real trick with a dropper.
  66. #166
    Im a bit surprised the xfusion post doesn't get more love.
    Its been fantastic. After a couple years, it sagged a little, so I "serviced" it in about 15 minutes and its back in action and working like brand new. If it ever actually needed a full tear down and rebuild, thats silly simple too. To top it all off, its dirt cheap.
  67. #167
    Reputation: kitejumping's Avatar
    9point8, cause it comes in 200mm travel for tall people.
  68. #168
    Mar 2011
    Quote Originally Posted by inonjoey View Post
    I have had it almost two weeks now, right after I got back from Sea Otter. I know it's not long at all. It is working great, however. It did squeak a little bit while lightly pressing the remote for a slow return at first, but that was only in the stand. It hasn't made the noise since riding it. Assuming it holds up, which it should, OneUp has made a great product yet again.
  69. #169
    Mar 2011
    Yes, I have had mine for about couple of weeks now. OneUp has been testers running them for over a year.
    Before the OneUp, I wanted a Revive. $400 is pretty steep after watching my Reverb go to crap even with proper maintenance. I had a Transfer on order as a bro deal, but looking at the Transfer thread and the launching of the OneUp changed my mind.
    The OneUp is robust post. I feel like it will be one of the best posts with its construction and design. If it does as well as the Revive since its 18-month release, I think grabbing something that is $130 cheaper will make a lot of sense to folks.
  70. #170
    Well I hope so. 1.5-2 seasons later, my Revives are still like butter. Just how smoothly they drop is a paradigm shift beyond the fox and other posts I've owned/tried.
  1. 27.2 Dropper post ?
    By Saucyjack in forum 29er Components
    Last Post: 09-16-2016, 04:06 PM
  2. When do you use your Dropper Post?
    By Licketysplit in forum All Mountain
    Last Post: 01-16-2015, 11:48 PM
  3. Dropper Post for XC
    By Loll in forum XC Racing and Training
    Last Post: 06-17-2014, 05:32 PM
  4. Dropper Post or...
    By MtnJammer in forum All Mountain
    Last Post: 06-03-2014, 06:33 PM
  5. Help me finish my Mach 6 (Dropper Post Post)
    By trickbooter in forum Pivot Cycles
    Last Post: 05-28-2014, 11:34 AM
Members who have read this thread: 260
