Results 1 to 16 of 16
    Mar 2013
    Best 29er tire for wet and muddy trail
    Can you please recommend a 29er tire that has good grip in wet/muddy trail and in the same time low rolling resistance.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by rave81 View Post
    So, what do you want? Grip in the mud or low rolling resistance?
    mtbtires.com
    Reputation: Shalom's Avatar
    Nov 2008
    Can't have both, sadly. For a decent mud tyre, I have been having some good luck with the Specialized Ground Control. It is working better for me than the Maxxis Beaver did.
    Missouri sucks...
    Yea, The Ground Control has been excellent. NobbyNics are pretty fast for their intended use as well.
    Mar 2013
    I currently use Maxxis Ardent, this tire has excellent mud/ traction, however it doesn't roll as fast as Nic Nobby.
    Nic Nobby grippy and it rolls fast, however this tire doesn't last. it only lasted 3 months of use, while the ardent I've been using it for almost 5 months and threads are not worn out.
    What other tires has equivalent to fast, grippy and durable?
    What do you think about the Bronson, High rollers or Rubber queen?
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    And I'd like a hot, low maintenance woman who puts out too.
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    Quote Originally Posted by Miker J View Post
    She would also have to have a lot of money.
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
    Reputation: cecald's Avatar
    Feb 2010
    We're still in monsoon season locally (Nepal) and I've tested 2 tires by Schwalbe. The first was a 2.4 Racing Ralph which I had also run in the dry season. The tires had very low rolling resistance, and traction on dirt/sand/rock was what you would expect - decent, but not the best to murder a downhill section - solidly a XC tire in my opinion. In the mud, wet sand, and on wet mixed terrain, it actually performed very well. I found that traction was reasonable for the short tread, and one aspect I really enjoyed was that I seemed to stay buoyant rolling through deep mud pits instead of getting mired in them. Definitely a tire where you accept lower traction limits for the tradeoff of good rolling abilities and decent performance in the wet/mud.
    The 2nd set of tires I've tried were the 2.35 Hans Dampfs. In dry conditions, great traction through rough stone fields, grass, dirt, sand, etc. Rolling resistance was obviously much greater than the RRs though (and noticeable in the dry). Once things turned wet & muddy though, the tires became really hard to push. I found that the rolling resistance increased so much, that I was fatigued much earlier in rides, and was getting left behind on climbs. Fortunately, the downhill capability inspires confidence and risk taking. After 3 solid months of riding with the HDs in muddy conditions however, I decided to change back to the RRs - and wish I had done so sooner.
    I will change back to the HDs, but not until conditions are solidly dry again. Until then I think the RRs are a good balance of traction and ease of spinning.
    Sep 2012
    Cecald-Why not a HD front, NN rear? Or NN front and RR rear.
    The NN is the quick rolling decent weight/traction solution. As mentioned they don't last (rear)
    The Spec Ground Controls are cheaper than the Evo Schwalbes and have very similar tread/performance but with better life.
    Dab-O-Matic
    Reputation: Simplemind's Avatar
    Quote Originally Posted by _Alberto_ View Post
    My comment is the HD front/ NN rear is a great combo for all around use, especially for Colo, which is where I ride them. Yes, there are faster, lighter combos, and there are better mud combos, but unless you are riding in total mud, or your riding total slickrock, which I doubt, you need something that has versatility, and without drama, which they do well.
    I also have tried the Spesh S-Works Fast-trax on the rear, and they work quite well, even through mud puddles, but of course would not use them as a "mud tire" per se.
    Crash Dummy In Training
    Reputation: PauLCa916's Avatar
    Jun 2013
    Specialized Purgatory Control hooks up nicely
    2015 Flyxii / ENVE /Chris King Carbon 29'er H.T.
    SRAM XX1
    2012 Stump Jumper Comp 29'er H.T. SRAM XX1
    1997 Rock Hopper / Rock Shox Recon Silver / 1 x 10 SRAM X9 XO Mix XT V Brake system
    Feb 2010
    Hey Alberto, unfortunately I just haven't ordered any NN tires to try yet. After reading more reviews on them, I think I'd be pretty happy on them though.
    Nov 2007
    Used to like Geax Gato in a 2.1 width particularly in the TNT,particularly in the TNT version. Never tried the narrow 1.9 width.
    Now run Schwable NN in really muddy conditions or new RR are awesome for grip in pretty sloppy muddy conditions also.
    Mar 2013
    NN tires are great, but doesn't last so, you'll be changing 2 to 3 times per year, that depends on the type you riding you do.
    its winter season here in Western Australia, almost every day its raining continuously, so the trails is mainly for all mountain/enduro type, lots of steep climb and lots of long aggressive downhill (30 to 40 mins). Most downhill section are slippery, lots of sharp rocks and muddy at the moment.
    Quote Originally Posted by PauLCa916 View Post
    I suppose they might do well in just mud, but I've absolutely hated mine on wet roots/rocks. Worse than my Ikons which are worn down to the hard compound.
    I Ride Bikes
    Reputation: Mazukea's Avatar
    Specialized Ground Control for me.
    I like to hug trees at FULL SPEED!
    INSTAGRAM -> hawaii808MTB
    FACEBOOK -> Big Island Mountain Biking
  1. Tire to Replace a Muddy Mary?
    By blown240 in forum Wheels and Tires
    Last Post: 05-21-2013, 10:48 PM
  2. A Good Muddy Trail???
    By redd4573 in forum Trail Building and Advocacy
    Last Post: 03-06-2013, 11:30 AM
  3. Replies: 1
    Last Post: 08-08-2012, 12:17 PM
  4. Tire clearance in muddy conditions?
    By Johnny K in forum Cyclocross
    Last Post: 11-29-2011, 08:18 AM
  5. Best XC racing tire for muddy conditions?
    By bagz007 in forum XC Racing and Training
    Last Post: 03-15-2011, 07:01 AM
