Results 1 to 18 of 18
Thread: Bars for 29ers
    Norđwegr
    Reputation: Vegard's Avatar
    Bars for 29ers
    I've read that some bars can be inverted for use with 29ers, can anyone recommend a brand that does this?
    Reputation: fat_tires_are_fun's Avatar
    May 2013
    Sorry, I dont understand this question. Are we talking flat mtb handlebars? Why would you invert them?
    - MOOTS Mooto X
    - Salsa Fargo
    - Niner RLT9
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Niner, Syntace.
    They make negative rise handlebars that allow you to lower, or raise, the bars 5 or 10mm.
    Death from Below.
    May 2013
    I thought that was the question. In that case, why would you invert flat bars? They would still be...well... Flat. You would invert riser bars., unless I am missing something
    - MOOTS Mooto X
    - Salsa Fargo
    - Niner RLT9
    Reputation: Bike Whisperer's Avatar
    Quote Originally Posted by Vegard View Post
    On One Mary Bars
    Reputation: TwoNin9r's Avatar
    Jan 2011
    You'd likely have better luck in the general discussion as this isn't really that 29er specific (I'm saying this to be helpful, not a d*ck)
    Reputation: DethWshBkr's Avatar
    Serious inquiry here - would it not be better to flip a stem (if it has a rise) or lower the stem on the steerer?
    If you invert a handlebar, does not your rise and sweep also invert? You're bars would push away from you (sweep) and angle down (rise).
    I need to look this up now, I am curious!
    Norđwegr
    Quote Originally Posted by Le Duke View Post
    Niner, Syntace.
    Quote Originally Posted by fat_tires_are_fun View Post
    If you invert bars like this you get a difference in height.
    Formerly of Kent
    These bars have no angle or up sweep. Just rearward sweep.
    And my stem isn't "inverted"; it's being run as it should be, which is effectively a -30 degree stem.
    Death from Below.
    unrooted
    Reputation: unrooted's Avatar
    195 lbs-6'4" Banshee Prime XL
    Ride Mammoth, Tahoe & Vegas
    PLEASE GIVE ME NEGATIVE REP!
    Reputation: Stopbreakindown's Avatar
    Jan 2011
    I assume you are having the same problem I have with 29ers. I can not easily get the bars as low as I would like. I run a Syntace F109 stem at -17 degrees with 1mm headset spacer below and Niner RDO Flat bars. With that set up I am able to get the cockpit in a proper XC height for my riding style. I will say that this set up was sketchy during seriously steep riding I did in CO. Went with a shorter 0 degree rise stem for that and felt much better.
    Feb 2012
    Quote Originally Posted by TwoNin9r View Post
    Actually, it sort of is 29er specific, as 26ers don't have this "problem" of a high cockpit. I don't know that bars are orientation specific. If you want to install it upside down then just do it, there's no reason why you can't. Same for stems, flip it around if you like to. But as was previously mentioned, flipping the bars could change the direction of the sweep and rise, which may work out to your liking.
    A lot of bars are available in the same geometry, different materials. IMHO I'd buy cheap aluminum bars to find a configuration you like inverted, then get the lighter carbon fiber version (assuming that's what you're after).
    I'd say very 29er specific. Especially for us guys with shortish legs.
    I use a specific +/- 5 mm Ritchey flat bar and a specific Syntace stem (Flat Force) to lower my cockpit.
    my bike with it. don't have a decent close shot of my cockpit
    unrooted
    That's crazy, my AM bike has more drop from saddle to bar than yours, I'm also 6'4" tall with ape arms. . .
    Quote Originally Posted by quax View Post
    This is really crazy! People come in different shapes and sizes! Who would have thought that? And they may even have different preferences regarding saddle height. Really crazy!
    unrooted
    Calm down Napolean. Lil guys have lil fuses.
    Crash Dummy In Training
    Reputation: PauLCa916's Avatar
    Jun 2013
    Can the OP post a pick of his cock pit ?
    I'm not 100% sure what he is trying to achieve.
    in·vert
    verb
    inˈvərt/
    1.
    put upside down or in the opposite position
    2015 Flyxii / ENVE /Chris King Carbon 29'er H.T.
    SRAM XX1
    2012 Stump Jumper Comp 29'er H.T. SRAM XX1
    1997 Rock Hopper / Rock Shox Recon Silver / 1 x 10 SRAM X9 XO Mix XT V Brake system
  1. XPost from 29ers: How have 29ers changed trail design?
    By GrantB in forum Trail Building and Advocacy
    Last Post: 04-08-2013, 11:17 AM
  2. Thule load bars: rapid aero bars worth it?
    By Ilikemtb999 in forum Cars and Bike Racks
    Last Post: 09-07-2012, 12:43 PM
  3. Do all 29ers have REALLY wide bars?
    By Damitletsride! in forum 29er Components
    Last Post: 06-25-2012, 05:40 AM
  4. S 29ers with WIDE riser bars
    By robtre in forum 29er Bikes
    Last Post: 01-05-2012, 08:06 AM
  5. Why so many smaller 29ers with riser bars?
    By edouble in forum 29er Bikes
    Last Post: 12-15-2011, 09:18 AM
