Results 1 to 7 of 7
    Reputation: Dgtlbliss's Avatar
    Atomlab suprelite wheels
    I just saw that Atomlab is making a 29er wheelset. Has anyone tried them out? I know the make super tough wheels, having run pimps on my DJ bike.
    The 29er is narrower at 18mm internal width, but they could be a nice option for an unbreakable wheelset. Not light at ~2kg.
    Atomic Laboratories 2012
    HTFU and Ride
    Reputation: coachjon's Avatar
    I think you can get a lighter and stronger wheel with a wider rim with Blunt SLs or even flows. With the right setup you can build a 1900g P35 wheelset.
    Depending on the price I don't see how these would be better with such a narrow rim, IMO.
    Winter is coming.
    meow meow
    Reputation: b-kul's Avatar
    ^+1. you can build wider and lighter wheelsets for cheaper. probably just as strong too. for less money you could get a lighter and wider set of pre built bontragers if you really wanted to go the stock route.
    Quote Originally Posted by b-kul View Post
    Do you know who sells bontrager stuff kind of cheap?
    roccowt.
    rocnbikemeld
    meow meow
    i think trek will only go through a lbs. maybe one could hock up up with a deal on last years stuff.
    Reputation: eurospek's Avatar
    They look cool, but as other have said, better options out there.
    konahonzo
    Reputation: BokorSolo's Avatar
    Dec 2009
    They look pretty cool. I gotta say... Atomlab used to make a triple wall rim. it was narrow, but wayyy diesel.
    No compromise.
