Results 1 to 7 of 7
    Living the Dream
    anyone know if I can convert my m980 xtr 26/38 crankset to 24/38
    by using either the xt 785 AM chainrings or slx 675 am chainrings?
    thanks
    "And I shout that your all fakes and you should have seen the look on your face"
    Reputation: c-wal's Avatar
    Re: anyone know if I can convert my m980 xtr 26/38 crankset to 24/38
    I tried an XT granny (not AM) and it would not work due to the ring spacing.
    Reputation: SRtahoe's Avatar
    Should work fine. M980 has 64/104 BCD. Its the m985 race gear that has the 88mm BCD that you need to watch out for.
    Sent from my DROID RAZR using Tapatalk 2
    Ring thickness is different though. I ended up going with blackspire rings for the m980 cranks.
    I think the XTR has a 2mm offset. Assuming you get the ring with the correct offset, will a 24 tooth ring shift ok with the 38?
    May 2010
    did you just change the 26t to 24t or did you have to change both & how did that work for you...
    blackspire 24/38 on M980 works for me. Got the 24 specific version from backspire
  1. XTR FC-M980 crankset
    By ashas in forum Shimano
    Last Post: 11-15-2012, 12:52 PM
  2. Help with M980 crankset as SS setup
    By Mojo Man in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-03-2012, 12:59 PM
  3. Replies: 1
    Last Post: 01-30-2012, 08:44 PM
  4. M980 chainrings on M970 crankset
    By bikedrd in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-29-2011, 01:14 PM
  5. Replies: 2
    Last Post: 07-09-2011, 06:48 AM
