Results 1 to 8 of 8
    Living the Dream
    Reputation: Alpenglow's Avatar
    any issues with stans crest rims and Racing ralphs tubeless in 2.25 & 2.35?
    looking to replace my ikons with racing ralphs. I have been running the RA RAs with tubes the past two weeks and I am looking to try them tubeless now. Thanks for any feedback.
    "And I shout that your all fakes and you should have seen the look on your face"
    My friend runs Ra Ra's tubeless (snakeskin) on his Niner with a DT240/Crest wheelset..No problems at all. I've run RaRa's, Rocket Ron's, and Nobby Nic's on my Arch Ex with no problems whatsoever.
    *Note* If you have non-snakeskin tires, sealing the sidewalls can be a week long process, took a while for my Rocket Ron's to seal up.
    Living the Dream
    I have the Stan's Crest rims with Racing Ralphs on my 650B Ventana El Bastardo and they work awesome together. Just make sure you over inflate the tubes to about 40 lbs when you first seat the tube and make sure you hear the pop that the tube has seated. That way you will get a great seal. I usually use a compressor to seat the tube and do it quickly so the tube seats quickly.
    Nov 2008
    The Stan's rims work extremely well with the schwalbes!
    Reputation: rob1035's Avatar
    Yup, no issues whatsoever with Racing Ralph Snakeskin and Crests
    Quote Originally Posted by Gabriel J View Post
    I just setup a pair of non-snakeskin Ra Ra's on a set of Arch EX's and it has been quite the process to get the sidewalls to stop weeping. 2 rides on them and they are getting better, but not completely sealed yet.
    Quote Originally Posted by rob1035 View Post
    +1 ... I am running that combo on my Scalpel and it works great...
    2011 C-Dale Flash 1 650b
    2013 Scott Genius 930
    2015 Charge Cooker Maxi
  1. Tubeless with Reynolds 29er carbons and racing ralphs
    By thechickencow in forum Cannondale
    Last Post: 07-21-2013, 07:22 AM
  2. Trouble setting up Racing Ralphs (tubeless on Crest)
    By jclyle in forum Wheels and Tires
    Last Post: 11-10-2012, 10:41 PM
  3. Stans Crest rims
    By anesthesia-matt in forum Wheels and Tires
    Last Post: 08-24-2012, 11:41 AM
  4. Replies: 38
    Last Post: 06-11-2012, 07:17 PM
  5. Running non-tubeless ready Racing Ralphs TUBELESS?
    By trumpus in forum Wheels and Tires
    Last Post: 02-07-2012, 11:28 AM
