Results 1 to 10 of 10
    Dec 2010
    Smile After market avid juicy pads? Are there any??
    My pads are shot in my Avid Juicy 3 breaks. Are there any other options then the stander avid stuff??? Anything you know would be great!
    Also Hope floating rotors with Avid juicy 3? Do they work well?
    Check ebay and LBS for pads. Better yet get new pads with an upgrade to SLX and be amazed. The Avid HS1 rotor is 94 g and can be sourced from Asian sellers for $24 or so.
    Reputation: ms6073's Avatar
    I have bought replacement pads for Avid BB7's from Discobrakes but might also check Scrub:
    Discobrakes.com/
    Scrub Components Brake Pads
    Reputation: Bike Whisperer's Avatar
    I've used these on my Juicy 5's with great success. Quieter than sintered metallic pads, more durable than organic resin pads.
    Alligator Avid Semi Metallic Disc Pads w/ Springs at Price Point
    Give it a crank
    Reputation: Mtn-Rider's Avatar
    May 2010
    I really like these, been using the sintered metal pads on several different brakes for over 2 years with great results.
    bikefridge | eBay
    Reputation: Mojo Troll's Avatar
    Hope Floating rotors generally run $50 a piece, on the cheap side. Why not just upgrade to a complete set of new brakes?
    Picked up some Trucker Co. Juicy pads at auction, $16 for two pair. Work good so far.
    Reputation: Ronnie's Avatar
    Both Jagwire and Kool-Stop make pretty descent pads that fit Avid.
    The trouble with having an open mind is that people will insist on trying to put things in it.
    Basement Dweller
    Reputation: JosefFritzl's Avatar
    I'm a fan of EBC Gold, but not sure if they're 29-er specific.
    Dec 2010
    Wow. Thanks guys I didn't know there was this manny options.
    Reputation: Shalom's Avatar
    Nov 2008
    Also check out Brake Authority pads. I rate them very highly.
    As for Hope rotors. They are excellent, but as stated above, it might be more worthwhile to replace your brakes than to upgrade your rotors.
