Results 1 to 6 of 6
    Jun 2013
    Adjusting rebound on rockshox xc-28
    I have a rockshox xc28 on my new 2013 rockhopper. I was wondering how exactly I'm supposed to adjust the rebound? I know it's the little knob on the bottom, but since it pulls out, am I supposed to twist it multiple times, or is it only supposed to be done 90 degrees? Because if I accidentally pulled it out I could end up twisting it more than 90 degrees.
    Jun 2013
    Anybody?
    Never trust a fart
    Reputation: frdfandc's Avatar
    The knob pulls out only for fork disassembly.
    Push it back it till it's fully seated. Then the knob should only turn so far. It will stop turning once you reach the end of it's travel.
    Jun 2013
    But if I move it to full one way then take it out and put in middle position, what happens?
    Never trust a fart
    Don't pull it out. Leave it alone. Nothing happens though. It's a 3mm allen key with a knob attached to it.
    Jul 2013
    I basically have the same question, I also thought you could take the key out and keep adjusting more. How much more who knows..
    To reset the adjustment, do I keep turning it back in until it stops, then insert the Allen adjustment knob. Then you would be left with about 180 degrees of adjustment.
  1. Replies: 13
    Last Post: 06-09-2013, 05:55 AM
  2. Rockshox Reba Rebound Adjustment
    By airlocksniffer in forum Shocks and Suspension
    Last Post: 04-18-2013, 06:55 PM
  3. Adjusting Rockshox travel with negative air
    By Crockpot2001 in forum Shocks and Suspension
    Last Post: 03-12-2012, 03:48 AM
  4. Rockshox Lyrik rebound damper, need help
    By special k in forum Shocks and Suspension
    Last Post: 08-06-2011, 09:06 AM
  5. RockShox Dart 3 SL has no more rebound
    By tcapri87 in forum Shocks and Suspension
    Last Post: 01-09-2011, 06:30 PM
