Results 1 to 5 of 5
    Oct 2012
    Adapter for 180mm Rear Rotor on Trek Superfly 100
    Is it possible to install a 180mm rear rotor on a trek superly 100?
    The frame may not be built to except a rear rotor larger than 160mm.
    I removed the 160mm rotor and caliper mount. I then installed a 180mm rear rotor and caliper mount adapter for a rear 180mm rotor.
    The wheel still did not fit. It seems the 180mm caliper adapter was not big enough for the larger rotor.
    Any suggestions. Thanks.
    What type of brake mount - post mount?
    Make and model of rotor, caliper and adapter?
    I assume you had interference between the caliper and rotor?
    Oct 2012
    Adapter: Shimano Mount Adaptor Rear Post to IS 180mm
    Shimano adaptor to mount a 74mm post mount caliper to a 51mm international standard frame mount to accomodate a 180mm disc.
    Brakes: Shimano SLX Model Number BR-M675
    New Rotor: Shimano ICE Tech 180mm Model: SM-RT86
    Old Rotor: Shimano ICE Tech 160mm
    Bike: '13 Trek Superfly 100 Elite Al
    So the adapter is a SM-MA-R180P/S?
    You have it facing the correct direction?
    Oct 2012
    Yes, the adapter is a SM-MA-R180-P/S.
    I will re-install it and make sure it is facing the right direction.
  1. Nomad C 180MM Rear Brake Adapter
    By chris.george in forum Santa Cruz
    Last Post: 04-27-2013, 09:50 PM
  2. Replies: 8
    Last Post: 02-15-2013, 07:00 AM
  3. Blur LT2: which adapter for rear 180mm rotor?
    By happyriding in forum Santa Cruz
    Last Post: 03-30-2012, 11:30 PM
  4. Post Mount Adapter for 180mm Rear Rotor?
    By myitch in forum Turner
    Last Post: 02-28-2012, 12:43 PM
  5. Replies: 2
    Last Post: 08-17-2011, 03:22 PM
