Results 1 to 6 of 6
    Acs3 coil conversion or Luftkappe on 36 - 160mm
    Just ordered an acs3 coil conversion for my 36 and saw today that vorsprung came out with a Luftkappe v2 that is compatible with the 36. At 160mm travel should I keep the acs3 and run the Luftkappe to save some grams? Or go coil? I have a Lyrik with a Luftkappe and an acs3 on my Slayer. Both are awesome. Trying to decide which would be better for my all day ride/ more pedaly bike Hightower LT. Any input would be awesome. Thanks
    Feb 2005
    Quote Originally Posted by mts595 View Post
    I'd personally send the fork to Vorsprung and get the full V tune with the included Luftkappe... custom tuned for you, lighter and less expensive.
    Sep 2014
    how can you have the ACS and the Luftkappe on the same fork or am i misunderstanding?
    as for me i want to try the luftkappe before spending the 4oo for the ACS. if it works as they say it should do the trick cuz i am close to having the lyric dialed i think what the luftkappe changes will make the fork awesome and i wont need the full coil system.
    You will really like the luftkappe in the Lyrik. I went from having three tokens in mine to 0. It really transformer the fork from okay to great. The small bump is almost as good as the acs3. The way it works with the pneumatic bump stop and larger negative spring really help this. The mid support is also so much better, it doesn’t dive near as much and I run my compression almost full open. Only reason I got another acs3 is because I got a really good deal on it through I wish I had waited. If anyone is interested pm me, it is for a 160 fox 36 and has the 50 in lb green spring
    I've only been out twice with the ACS3, (Santa brought it), but I would find it difficult to believe any air fork improvements would match the ride quality of this. It installed pretty easily (Pike fork on a Santa Cruze LT-C), the video on Push's site is excellent. I had previously installed the RWC low friction seals and was very happy but the first time on the Pike with the ACS3 blew my mind. I had put the Push ElevenSix on last year (also love it) but now in combo with the ACS3, it feels like the wash board surface at the start of my ride is 3 degrees less steep, it feels like I'm going 10 miles an hour slower when I'm actually going faster. Grip is better and the brakes work better.
    The Riddler
    Reputation: Kaparzo's Avatar
    Also debating these two options for a Fox 36, but with a GRIP damper. Pinkbike seems to think it's indiscernible from the Fit4 and HSC tuning is not a priority for me.
    I have the Luftkappe on a Pike and love it. As of now, Vorsprung isn't offering it for GRIP models, but hope they will in the future and with a modification that also improves the damper as they currently do for the Fit4.
    The ASC-3 seems like a great mod for a lower end fork but is a bit more expensive/heavier and doesn't do anything about the damper.
    Just wondering if not upgrading the damper will be a durability or performance issue down the road, even with the ASC coil upgrade.
  1. Replies: 613
    Last Post: 1 Day Ago, 12:08 AM
  2. Avalanche cartridge vs. Vorsprung Luftkappe and custom tune?
    By Sid Duffman in forum Shocks and Suspension
    Last Post: 2 Weeks Ago, 03:35 AM
  3. Fox 36 with Push ACS3 or PUSH Tune
    By barefootdan in forum Shocks and Suspension
    Last Post: 11-14-2017, 06:52 PM
  4. Vorsprung Luftkappe
    By rave81 in forum Shocks and Suspension
    Last Post: 04-12-2017, 06:48 AM
  5. fox float 36 RLC 160mm 2011 coil conversion?
    By NIMRODXV in forum Shocks and Suspension
    Last Post: 04-02-2013, 12:35 PM
Members who have read this thread: 95
