    Nov 2013
    9mm to 15mm kit required?
    I have a pair of Easton EA90 XC wheels using the M1 hubs set up with the 9mm QR front axle.
    I'm purchasing a new upgraded Sid XX WC fork with the 15mm specs.
    When I look at the pictures of the fork, it appears to have a 15mm QR axle connected to it. Does this mean I don't have to get the Easton conversion kit or will the one that comes with fork not work requiring me to get the kit?
    if I have to get the kit does this mean that what I'm seeing on the fork picture (the QR and Axle) not be used at all?
    Mar 2013
    You will need to change the end caps on the hub to accept the 15mm axle that comes with the fork.
    Nov 2013
    Quote Originally Posted by Bcbert-4 View Post
    Thats great to hear! So I can use the axle and QR side of what comes with the fork but will simply only need the end cap (opposite side of the QR)that Easton provides.
    End Cap, M1-_13, 15x100 - Extras - Components
    Two of these. Lbs should be able to order them.
  1. Hey! and help required with fitting
    By macauinpt in forum Bike and Frame discussion
    Last Post: 11-07-2013, 01:38 PM
  2. Some assembley required
    By Moonstomper in forum General Discussion
    Last Post: 08-08-2013, 06:24 AM
  3. Sealant required?
    By Marauderzzz in forum Wheels and Tires
    Last Post: 05-17-2013, 12:25 AM
  4. *Help* RH Crank Required
    By Smurray1987 in forum 29er Components
    Last Post: 05-07-2013, 11:21 AM
  5. What is required, what is helpful?
    By SuperSlow35th in forum XC Racing and Training
    Last Post: 04-16-2012, 06:48 PM
