Results 1 to 13 of 13
    ColoradoCoolBreeze
    Reputation: SingleTrackLovr's Avatar
    700, 700c, 29" ???
    Will a 700x35 fit a 29" wheel? I've read 700c will fit the 29" wheel.
    I am looking for a winter studded tire to ride concrete bike paths this winter. Patchy ice can pop up at anytime.
    I found these,
    Schwalbe Marathon Winter HS 396 Studded Mountain Bicycle Tire - Wire Bead 700x35
    What do you think?
    04 Azonic Saber
    08 Yeti AS-x
    12 Rocky Mtn 29er Alt 970
    700 and 29 are the same but what is your rim width? You may have issues if you have wide rims.
    ColoradoCoolBreeze
    Quote Originally Posted by jlmuncie View Post
    Thank you for the help. My 29" wheels are,
    DT Swiss R520 - Rims - PROFILE WIDTH 20.1 mm PROFILE HEIGHT 29.5 mm
    What do you think? Will the 700x35 fit this rim?
    04 Azonic Saber
    08 Yeti AS-x
    A 35mm tire on a 20mm rim should be fine.
    I don't live where I need to ride on snow and ice but wouldn't a wider tire give better traction? It seems like there has to be somewhere to get a 2" wide studded tire. Or is narrower better.
    Custom Wheelbuilder
    Reputation: Zen Cyclery's Avatar
    It should work just fine. The 700c and 29er diameters are exactly the same, and those widths should work together just fine.
    Check out www.zencyclery.com for fully customizable, handbuilt wheels.
    www.facebook.com/zencyclerywheels
    ColoradoCoolBreeze
    Thank you both for the help.
    This is just for riding concrete bike paths to stay in shape over the winter.
    These paths are usually scraped by the city parks service.
    That said ice patches can be anywhere along the trail.
    I'm retired and try to ride everyday as long as the temp is above 20F
    04 Azonic Saber
    08 Yeti AS-x
    May 2012
    700c fit the 29" wheel, actually they are same.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by SingleTrackLovr View Post
    The R520 is a road rim. Not an issue using 35mm tires
    mtbtires.com
    Reputation: millertm's Avatar
    Sorry for the dumb question; however, 700c or 70cm is 27.56" and not 29", or am I not reading this right. Moreover, where I park my bike there are other road bikes and their 700c wheels are smaller then my 29" ones.
    Mark
    2012 XXL Carve Expert
    Measure you're 29" wheels. They're the same diameter as 700C road bike wheels. The 29" (along with 26") comes from the approximate diameter when you have a tire mounted.
    Dec 1998
    Quote Originally Posted by millertm View Post
    Mark
    700C and the like size designations are archaic. Read this: Tire Sizing Systems
    mtbtires.com
    wyrd bi ful rd
    Reputation: chinaman's Avatar
    We should all use the BSD or Bead Seat Diameter under the ISO system, formerly called the ETRTO
    622mm for 700c or 29" tyres or rims
    559mm for 26"
    Everything else is confusing and you can end up with the wrong tyre for your rim.
    eg:
    26 x 1 3/8 tyre will not fit a 26" rim ...
    Quote Originally Posted by shiggy View Post
    Thanks, I knew that I was looking at it wrong.
    Mark
