Results 1 to 9 of 9
    Reputation: Stumpjumper61's Avatar
    34 T Chainring question
    Does anyone make a 34T chainring that has shift ramps so it could be used in a 34/22 2 X 10 set up? Seems like all I can find are rings for 1 X 10 appications
    beater
    Reputation: evasive's Avatar
    Feb 2005
    Blackspire does.
    I ran a Middleburn 34 tooth with no problem. I was running a 24 tooth granny though. I think the Blackspire might even be better though. Seems like it has better ramps. I'm now running one(Blackspire) in 36 tooth. Race Face is good too.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Stumpjumper61 View Post
    You do not need shift ramps. Straight cut teeth (not the wide/narrow versions) shift fine and reduce chain drop.
    None of my bikes have ramped rings:
    36/24
    34/24 (2 bikes)
    32/22
    44/30
    54/40/32
    All shift fine.
    mtbtires.com
    Reputation: Flip D's Avatar
    Shiggy, do you use friction shifters with these setups?
    Dec 1998
    Quote Originally Posted by Flip D View Post
    Only on one of them.
    mtbtires.com
    Feb 2006
    I have straight cut teeth on several vintage triples with rapidfire, they shift just fine if the front derailleur is set up right. That said , the Shimano sets with ramps are faster.
    Dec 1998
    Quote Originally Posted by Fred Smedley View Post
    IME ramped rings shift faster once the shift has started. But they shift only at the ramps.
    Shifts with straight cut rings can start at any point and complete almost as quickly.
    mtbtires.com
    Not sure about the shift ramps but my E13 crank is 34/24.
    A bicycle will take you to fantastic places....if you let it.
    Ibis fan since '08 now rolling on the big wheeled Ripley.
  1. SJ FSR ... Chainring question
    By 1996Marin in forum Specialized
    Last Post: 07-20-2013, 06:26 AM
  2. Chainring question
    By wellcraft in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-08-2013, 10:42 PM
  3. chainring question
    By aintnothang in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-06-2012, 01:28 AM
  4. Cog & Chainring Question
    By Harleytoo in forum Singlespeed
    Last Post: 05-23-2011, 06:24 PM
  5. chainring question $?
    By client_9 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-12-2011, 01:23 PM
