Results 1 to 2 of 2
    May 2013
    29er Wheel Build
    Hey guys, first post!
    I'm building up a wheel set with some NoTubes Arch EX 29 rims and DT Swiss 350 hubs. I have all of my parts except spokes, BUT, when i ordered my rear hub they sent me a thru axle hub, and I need a quick release. When i ordered it, it said it was a 135mm hub and COMPATIBLE with a thru axle. Anybody know of a way i could run the thru axle on my C-dale SL2 29er frame? or conversion kits for the hub?
    Thanks for reading!
    You need a RWS thru-bolt skewer. This gives you a stiffer rear than a standard QR.
    DT Swiss RWS thru Bolt 10x135mm Aluminum Alloy thru Bolt Rear Skewer 10mm Black | eBay
    I've been using this on my ArchEx/Dt build for the last year with excellent results. Just check it for tightness periodically.
    You can also change the endcaps. Call Dt for the part number.
    I used Supercomp spokes and would use brass nipples because of corrosion after a year with aluminum.
    I used stainless washers from ZTR on the DS to give the rim some protection with 125kgf tension.
  1. All mountain / Trail 29er wheel build
    By BigwheelsRbest in forum 29er Components
    Last Post: 09-15-2012, 11:23 AM
  2. 29er Rim Selection For New Wheel Build
    By SenorSerioso in forum 29er Bikes
    Last Post: 04-05-2012, 04:56 AM
  3. 29er wheel build advice
    By kozmos in forum Wheels and Tires
    Last Post: 01-09-2012, 11:41 AM
  4. SS 29er Wheel Build
    By Fun in forum 29er Bikes
    Last Post: 06-25-2011, 09:15 PM
  5. 29er wheel build on Speccy 142+
    By bkrantz in forum 29er Bikes
    Last Post: 06-11-2011, 11:16 AM
