Results 1 to 44 of 44
    29er Stumpy Comp: How To Convert To 2Bliss?
    Hi Guys,
    Running 2bliss ready tires (Sworks Renegade/ Fast Trak LK) on DT Swiss rims (450SL). Thinking of converting to save weight and reduce annoying thorn flats.
    What are the Pros & Cons of 2bliss and what do I need to buy to convert?
    thanks,
    bob
    Reputation: VanillaEps's Avatar
    Aug 2010
    I went tubeless on S-Works Renegades. I needed rim tape, Stan's sealant, and tubeless valves (I think). It should be pretty simple.
    Does the tape just seal the spoke holes?
    bob
    Reputation: wetpaint's Avatar
    With the 450SLs there is a plastic rim strip that goes in the rim, it covers the spoke holes & has valves.
    Quote Originally Posted by wetpaint View Post
    Do you mean that it is already there or that is something I can buy?
    bob
    I see the red strip. So, all I need are the valves and Stans?
    Reputation: RS VR6's Avatar
    Not sure about the Stumpjumper...but my Carve had red rim strips and they are just normal strips.
    I used the Stan's tape (wrapped twice), Stan's valve stems, and three cups of Stan's fluid.
    Quote Originally Posted by RS VR6 View Post
    Are they the same DT Swiss 450SL rims? The red strips look like they would seal but I want to be sure? Did your carve come with 2bliss tires?
    thx
    Try putting just the tire on without any Stans and see if you can get it to seal.
    It sounds like they may have changed the rim design a bit. Mine have plastic rim strips instead of tape.
    My Stumpy came from the factory with yellow tape on the rims (520SL 29er), 2Bliss tires, and the tubeless valves in the bag with the manual. I installed the valves and added some Stan's the day I brought it home and never looked back. I have since switched to fiberglass reenforced packing tape on the rims (single wrap crossed over at the stem hole), I find it lasts very well, is cheap, and readily available. Only flats over the last three years were unavoidables like torn sidewalls.
    A couple of things I wish someone would have told me... don't tighten up the stems to much, you can pull them through the rim. High tire pressures can pop the tape through the spoke holes. And deburring any sharp edges on the the stem and spoke holes with help the tape and stems last longer.
    Gary
    Kool-Aid, Kool-Aid, Taste Great... Oh Yeaahh!
    Quote Originally Posted by steelgtr View Post
    thx
    My wheels are the stock "Carve" wheels.
    I have the Ground Control 2bliss tires. They sealed up on the first try. No issues.
    Did your wheels come with tubless valves?
    Reputation: timmaayyy's Avatar
    May 2010
    My 2013 Stumpy Comp came already taped for tubeless. Tape was brown-ish and said 2bliss all over it I think. Pull out the tubes, install the included valve stems, pour in Stan's, and pump up. No issues using just a floor pump.
    Happy Trails
    Reputation: Scott In MD's Avatar
    Use sealant. Otherwise you'll still get thorn flats.
    Quote Originally Posted by Scott In MD View Post
    Sealant for sure! I'm trying to find out if the red strip over the spoke holes is tape or just a protector? It doesn't say "2bliss" or any markings on it and it looks thicker than tape but appears to be adhered to the rim; I can't peel or lift it.
    If I get the Stan's tape:
    Stan's NoTubes Rim Tape : Amazon.com : Sports & Outdoors
    What size for this wheel and do I remove the existing red strip?
    thx
    Same for my 2011 model, no need to replace the tape...
    Quote Originally Posted by timmaayyy View Post
    No, it was an employee purchase blem.
    Quote Originally Posted by Shibby View Post
    Called Spesh this AM and they said the 450sl's are 2bliss ready, no tape needed. valves and Stans on the way!
    bob
    Update: Bought 2 new S-works Renegade tires, installed the Stan's valves and had a ***** of a time inflating even with a compressor; the renegades are so thin that they don't have enough shape to meet the rim. I finally get them to seal only to have a bunch of spoke holes blowing by! So much for Spesh tech support .
    So I remember reading about Gorilla duct tape and have a brand new roll, cut a nice strip pull it tight over the holes work it in, fight to get air and it's still leaking from the same spoke holes !! So I guess I have to order some Stan's rim tape. Why didn't the Gorilla tape seal? I even sanded the rim before applying.
    thx
    bob
    Did you remove the other rim strip and run the Gorilla all the way around? Did you clean the rim after you sanded? Use denatured alcohol or 90% rubbing alcohol. Denatured is better though. Make sure your valve stem is in snug as well. If air is getting past it, it will also come out of spoke holes. I am running S-works Renegades on both me and my wifes bikes and I seat them with a floor pump. Double check everything.
    Quote Originally Posted by jochribs View Post
    Yes, removed the plastic factory red strip and yes all the way around, tight and pressed.
    I only wiped the rim with a clean towel. The stem was loose at first but passed the soap bubble test after tightening. The same spokes that were leaking with the factory red plastic tape were also leaking w/ the gorilla tape (I marked the leakers w/ painter tape)
    I don't see how those Renegades could seat with a floor pump (I believe you) seeing how floppy they are!
    Did you do 1 layer of G tape? Should I just get a roll of stans tape?
    thx!
    Hey Steelgtr,
    I've never used gorilla tape to seal a rim. Actually have used it to patch tire cuts though. Anyway, it should work. Many people have use it with success.
    The stick of gorilla tape is tenacious, but you still want to wipe the surface you are going to adhere to with a non-residual cleaner (denatured alcohol, 90% alcohol) to get ride any thing that may affect the bond. This is with what ever tape you decide to use. Make sure your strip is wide enough. The other thing that you should look for is whether the tape has been cut by any of the spoke holes. Probably should file or sand those to remove the sharp edge. Also look at how the valve is seating in the tape. What kind of valve are you using? One cut from a tube or a purposed one from Stans/other kit?
    I'm not familiar with the rim that you are using (DT?) and so I don't know if there are any other spots that could be letting air past, maybe someone with the same rims can chime in. Check over the entire rim.
    Either way, I'd remove the gorilla tape, prep the rim (sand, file, clean), and then make sure that the tape is fully covering the holes next time you put it on. Make sure the tape is cut straight, not wavy or sloppy. And really PRESS the tape with your fingers/thumb along its entire perimeter. You may have had a small void/wrinkle in the tape before and once it had sealant getting under it, it will not stick...but I'm taking shots in the dark here, hard to say without seeing your situation.
    **Also, pulling super tight with the gorilla tape is probably not as necessary as it is with the Stans tape. It is more necessary to rub both edges down along the entire perimeter as I said above.
    I removed the gorilla tape and tried high quality USA black electrical tape and it sealed. Not sure if it's a good long term solution? I have some Stans yellow tape on the way. Probably should wait?
    bob
    The problem might be the Gorilla tape. I've read a number of people saying that it has micro holes in it. It might be good to do two passes with it, but then again, at that point, I'd just use Stans or an equivalent.
    Not sure about electrical tape, because it is so soft and stretchy, and I've noted that stuff generally 'creeping' on its gooey adhesive in other applications on a regular basis. Not sure about it's tensile strength. I assume it is really low though. You can easily snap electrical tape.
    Some people use reinforced packing tape with good luck too.
    If you have the Stans tape coming, I would just go ahead and use that. Clean up the rim well, and follow Stans instructions and you should have no problems. Remember you have to put some tension on that stuff while you are putting it on, but that should be covered in the directions.
    Rep'n the 905
    Jun 2012
    I say to all ditch those stock renegade tires!!
    Although light and uber fast rollers, those things are so thing and have 0 grip on another other then hard pack straights. I'd be hesitant to run em tubeless incase of a sidewall tare, could be dangerous. But then again so could walking down the street.
    Quote Originally Posted by BigGK View Post
    I recently just started running mine with sealant. S-Works. 1.5 scoops. Simple to set up.
    renegade 2.3" in the real world
    I've had my wifes setup this way for quite some time, and she is without complaints. Our local trails aren't straight and they aren't all hardpack.
    Sometimes it's the loosenut behind the bars that needs tightening.
    Oct 2012
    But, the sealant should seal up any micro holes that might exist in the tape. I've used gorilla tape and had no problems, so it might just not be stuck to rim well enough. It's pretty hard to say for sure.
    Quote Originally Posted by ehwik View Post
    It was stuck real well. I didn't want to add sealant and count on it sealing the spoke leaks. Is it OK to do the initial Sealant fill through the presta valve with the core removed? It;s such a ***** to fill the Renegades but once they are filled and the air leaks out, they will fill easily with a hand pump as long as I don't break the seal.
    And how much initial sealant for the 1.95 29er Renegades?
    The issue is not the Renegades. It's your rim/tire interface. I have set up multiple sets with absolute ease. No more than 1.5 scoops worth of Stans sealant in each tire. This is with S-works sidewalls on both the 1.95 and 2.3 29er tires.
    Yes, it is absolutely ok to fill through the valves.
    Electrical tape lasted 2 days! Hope the Stan's tape saves the day!
    bob
    Stan's didn't seal the spoke hole either . I'm about to give up on the project or invest another $50 in rim strips.
    bob
    Bob,
    there has got to be something that you are overlooking. Be it in the initial prep of the rim, the application of the tape, the possible buggering of the tape while you are putting the tire on (however this is probably not happening, as I assume that the rim you are using isn't a super tight fit between rim and tire and you're probably not using a lever to get the tire on).
    Without seeing your rims I can't comment on what's definitely happening, but you should be able to get these things to hold air. Something is being done wrong somewhere in your process.
    Check the bead of the tire closely, look for any irregularities that are going to cause a void in the interface of rim and tire bead. Check the rim bead as well for the same sort of thing.
    Where is the air seeming to escape from? Did the tape infact fail and let sealant/air under it?
    It's only leaking from certain spoke holes and the same ones. I didn't seat the stans tape with a tube like he says too. Could that be the problem?
    thx
    bob
    Tape look perfectly sealed. Trying a tube at 50psi.
    bob
    The same spoke holes don't necessarily point to the leak emanating from right below them. The inside of a rim is a hollow cavity. Most likely, air is getting through in a different (or multiple different) areas with each different rendition you do with different tapes, and it is those spoke holes that have the air coming from them have the least perfect/tight fit of the spoke nipple/hole. It is showing up with those holes every time because they are presenting the least amount of air resistance.
    Look super closely for anywhere that air can get past that inner rim surface. Either the tape is being not sealing or you are missing something else. Make sure the valve is sealing too. Check the rim opposite of the valve for small holes from pinning and welding.
    Aside from this, I'd say bring it in to a shop and have them look at it, set it up, and tell you what's been going wrong.
    Progress!!
    Listened to Stan and put a tube in a left @ 50psi overnight. removed the tube, mounted the renegade and no leaks !! Added Stans sealant watched a few sidewall pinholes seal and went for a ride. Got a flat..... On the back tire that I haven't done yet, LOL
    How high can I run the pressure? I usually run 57 PSI on the paved paths that I do a lot. Today was Alum Rock Park fire trails.
    bob
    Thats pretty high.
    I run 25 front and about 27 rear on my tubeless.
    Reputation: millertm's Avatar
    I run 60psi on my 2.1 GC's for street commuting and never had an issue. I have the blue rim tape and stans. I have the stock 2012 Carve Alex rims. I just needed tape and valve stems and stans. I was 2Bliss ready from the start. No issues and I just redid my stans on my fromt tire today. It will only last a few months before it drys out. I am in NM and it is hot and dry here. I used 2.3 cups (the red cup that came with the 16oz Stans bottle) ~ 5.3oz, 2oz per cup. I had no issues on the air up, but my side walls are a bit stiffer then the S-works. Floor pump sealed it.
    2012 XXL Carve Expert
    Quote Originally Posted by millertm View Post
    I run 60psi on my 2.1 GC's for street commuting and never had an issue. I have the blue rim tape and stans. I have the stock 2012 Carve Alex rims. I just needed tape and valve stems and stans. I was 2Bliss ready from the start. No issues and I just redid my stans on my fromt tire today. It will only last a few months before it drys out. I am in NM and it is hot and dry here. I used 2.3 cups (the red cup that came with the 16oz Stans bottle) ~ 7.3oz, 3oz per cup. I had no issues on the air up, but my side walls are a bit stiffer then the S-works. Floor pump sealed it.
    How do you know when you need to add more sealant? I added 1.5 cups for the 29x1.95 Renegades. SF Bay area. Bike lives in the house!
    bob
    Reputation: Bailey44's Avatar
    Dec 2010
    Shake the tires and when you no longer here the fluid splashing around, add more.
    I live in Texas and bike stays in the 100+ degree garage and I have to add about every 4 months.
    bob
    For me it is about 3-4 months as well. I notice when it starts to have issues keeping air pressure. It will drop about 10psi overnight.
    Mark
    Round 2: Worse
    I thought I learned from the front tire and proceeded to the rear:
    Sanded inner rim, cleaned with alcohol, applied Stans tape with tension and put a tube in right away at 50 psi overnight to seal the tape like the front sealed. No go this time. Still lots of spoke hole leaks. I have checked the tape, pressed firmly with my hand and a Pedro tire tool and it's still leaking. I'm going for a ride tomorrow with a tube but not hopeful.
    Would you put on a second layer of tape or start over with new tape?
    thx
    bob
    This does not sound right. My Carve was 2Bliss ready and you have the better rims then my Alex built rims. I did not need to tube it overnight to set the tape, nor did I have any issues at all with going tubeless. You need to go back to your lbs and have them do something about this issue. You should not have any issues with your bike for what you paid for it.
    Mark
    Mark
    Good advise. I've got way too many hours invested in this project!
    thx
    bob
    Could it be the valve? I mean, could it pass the bubble test on the outside of the rim but let air under the rim tape somehow? I know that tape is really tight but.....
    bob
  1. Stumpy comp 29er vs camber comp 29er
    By Mitch1171 in forum Specialized
    Last Post: 01-01-2013, 11:34 PM
  2. A new 29er Convert (Stumpy Expert)
    By DemonKiwi in forum 29er Bikes
    Last Post: 09-24-2011, 09:08 PM
  3. Replies: 0
    Last Post: 07-04-2011, 02:12 PM
  4. '11 Epic comp 29er or '11 Stumpy fsr comp 29er
    By DECKMAN in forum Specialized
    Last Post: 03-16-2011, 11:45 AM
  5. '11 Epic comp 29er or '11 Stumpy comp 29er
    By DECKMAN in forum 29er Bikes
    Last Post: 02-10-2011, 04:19 AM
