Results 1 to 10 of 10
    29er studded tires
    Looking for some recommendations. Nokian 294 2.1 vs schwalbe ice spiker pro vs 45 north nicotine? I have had good luck with the nokians in 26er.
    Nicotines seem like the latest and greatest, lots of studs, big and fat, new technology, from a winter company like the nokians. I would have gotten them for my big dummy, but they don't come in 26 so I got nokians.
    Given the number of views in this thread .. this response will probably be lost .. but since I don't see many people talking about the nicotine .. I'll give my preliminary non-report (lots of words to say not much)
    I bought these as a birthday present to myself for those commute days in Edmonton after a snowfall. Normally, the ride is on hard-pack snow (either on the walking trails in the park or on road) or polished-ice (on the road). The usual bike is a Surly 1x1 using Nokian Mount and Ground. This works A-OK except when the snow is deeper.
    So .. figured I'd buy a pair of these which looked more snow-with-some-ice tires to throw on the summer-bike - an On One Inbred set up as a 1x9.
    We had a big dump, but the tires didn't arrive until after the plows came through.... so riding so far has only been on hardpack/ice. I was worried that the center-line of studs were pretty far apart, but grip on ice seemed fine .. did some gentle test brakes with no slippage (I had them a 30psi... would go lower if it was softer riding surface). This was all on the flats, though, have not ridden up/down any icy hills.
    Did a little toodle into softer snow and while better than the skinnier 26-inch M&G I can't say I was overwhelmed .. but way too early to say much. Also steamrollered over some of the plowed hard blocks of snow by the side of the road .. that was fun, but probably more a function of 26 vs 29 than the tires.
    So early indications are ... good on hardpack .. but what isn't. Better on ice than I was thinking they might be, but no serious conditions yet. And better on looser snow than the M&G but how much better remains to be seen.
    Other little notes - man .. these are much louder than the M&G .. not sure why since there are probably less studs along the center .. might be the M&G are worn as they are > 5 years old. Also, while they make a big-deal about "concave studs" ... both tires had a few regular studs in them .. what .. somebody grabbed some normal ones out of the wrong parts bin? Unexpected for the price .. but functionally, I'm sure not a big deal.
    Reputation: tartosuc's Avatar
    I use ice spiker pro on my 29er. 29x2.25 since last year,
    I ride with them everyday on the streets and on the lake by my place...incredible tire
    All the studs are still there
    expensive cars are a waste of money. Expensive bikes...not so much!
    Aug 2015
    I ordered Ice Spiker Pro and now I am concerned that they drop studs more than Nokian. I asked a dealer who sells both and he said they were identical in stud loss and either will do it the same amount if you torque too much on rocks.
    On the other hand, the Spiker has 402 studs vs 294, so it can drop 108 of them and still be no worse off than new Nokians.
    Aug 2014
    I had Nokians for a while. My biggest issue was how flat the tread pattern is. You can't really lean bike over at all if you are on hard pack terrain.
    Reputation: mike180's Avatar
    I live in nh lots of ice to ride on,snowmobile trails and lots of waterfall singletrack.when we all road 26 inch wheels the nokian was awesome,in 2008 or so I switched to 29ers.ordered up a set of nokians as did 3 of my riding buddies.on the first few rides alone I thought there was a difference lots of slipping and tire wash out.kept my opinion to myself and started riding my 26 inch bike again big difference much more grip .it was not long before we all had the opinion the 29 er nokian was not as good.i switched to the schwalbe 29 tire and immediately could tell there was a big difference.the 3 of us own ice spikers now.for the 29ers anyway. a bit disappointed as I sell the nokian automotive tire line all winter with fantastic results.
    fog
    fog is offline
    Jan 2005
    The old Extreme 296's were/are great tires. I used them on road, off road and commuting.
    They lasted for ever and never threw a stud.
    I went to 29" and the Extreme 294's are narrower, seem to wear faster and I do not want to lean them over as much as I did the 296's.
    Most of my winter riding now is snow packed/icy roads or bike paths. I have not tired them off road. Maybe this winter; but I am older and less fit too.
    Wayne
    Jan 2014
    Its going to be a 3rd season on Nokians for me this winter. I bike with them like 2 months per season and they still look great. I think the tire is good but a little limiting with the smaller footprint/width and how hard they feel together with larger size knobs. I use them for daily commuting when streets get icy. The tire works great on black ice and packed snow but when you hit some softer snow/slush they tend to drift. If you are lucky it can cut thru the snow and grip on ice/road underneath. If you take it off road you have to be careful on slippery rocks and roots under the snow since the tire tends to slip and studs dont help as much.
    I think if you can get them in good price they are good to have but when mine go i will be looking at wider options with smaller knobs.
    Gotta run the studs in on hard ground for like 25 miles to minimize loss of studs. They're easily replaced though. You can find cheap Chinese ones on eBay that work fine.
  1. turning your tires into snow/ice studded tires.
    By Clozedeyez20 in forum Wheels and Tires
    Last Post: 02-23-2013, 11:38 AM
  2. Reccomendation On 29er studded tires?
    By Munkyak in forum Wheels and Tires
    Last Post: 11-24-2012, 02:41 PM
  3. 29er Studded Tires
    By Teton29er in forum 29er Components
    Last Post: 03-03-2012, 06:17 PM
  4. Studded Tires....
    By jreinan01 in forum Wheels and Tires
    Last Post: 01-15-2012, 05:14 PM
  5. Studded Tires
    By electrik in forum Eastern Canada
    Last Post: 01-02-2011, 03:24 PM
Members who have read this thread: 8
