Results 1 to 37 of 37
Thread: 29er latex tube
    mnoutain bkie rdier
    Reputation: rydbyk's Avatar
    29er latex tube
    Running tubeless, but want one for backup during races. Any out there?
    Dec 2009
    Bit hard to fit, but 26" should work fine.
    Master of Disaster
    Reputation: Clones123's Avatar
    Forté MTB LunarLight Presta Tube 26 x 1.95-2.25" (99g)
    http://www.performancebike.com/bikes..._1034712_-1___
    I'm gonna miss me when I'm gone.
    IMBA member #234701
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by gvs_nz
    Not with latex tubes. They do not like to be over stretched.
    mtbtires.com
    Dec 1998
    Quote Originally Posted by rydbyk
    Latex tubes need to be pretty close to the tire size. Means they tend to be bulkier than a butyl tube. I would use the tube Clones suggested.
    mtbtires.com
    Quote Originally Posted by shiggy
    Have you tried to inflate one out of the tire until it bursts? Do it, it's fun and you will probably retract your statement.
    I have used 26" Michelin latex tubes in 29" tires for years. Works fine. It's not stretch you should worry about, but moisture (like sealant residue) or UV rays.
    Dec 1998
    Quote Originally Posted by JeroenK
    I have had many latex tubes burst inside my tires in ways butyl have never done.
    mtbtires.com
    Nov 2006
    For a spare in a race i'd (do) use something that is super thick. That way if there is a side wall cut or other sharp stuff in the tire it will be less likely to flat again. The extra weight of a beefy spare tube won't matter at all.
    I'd rather finish last then DNF because of some super thin tube.
    Dec 1998
    Quote Originally Posted by Vortechcoupe
    1. A cut casing needs a boot, no matter what kind of tube you use.
    2. You need to remove the foreign objects before putting the new tube in.
    mtbtires.com
    Well, we might have had different experiences due to different causes. What do you think caused the bursts? What makes you so sure stretch played a big part in this?
    And ehm... are we talking 1998 or 2008 here? I have seen some results of catastrophic latex tube failure after long descents on rim brake rims. Cause #2 would be mounting faillure (part of the tube trapped under the tire bead), but I would not dare to accuse a respected tire guru like yourself of that . Then there were the few weightweenies that tried road or CX latex tubes in 26" tires. I would strongly advise against that, but not the minimal stretch from 26" to 29".
    Dec 2009
    As long as latex tubes stretch evenly they are fine. You must have good solid bead tape over spoke holes. I plan to try them on a 29er but I can see them being more difficult than a 26 butyl tube to fit as they squirm so much.
    As a spare tube for a race I would use a race light 29er butyl tube. That last thing I would want is to be pi++ing around trying to stuff a 26" tube[ butyl or latex] into a 29er tire during a race. I can see frustration and tears. All to save about 50g.
    Reputation: masterofnone's Avatar
    About ten years ago I went through a phase using latex tubes. The only cool thing about them is how they pop really loud like a .22, you're not sure if you're being shot at or just flatted LOL. There's no such thing as a "pffffffffft" slow flat. They're unpatchable, a total waste of money unless you routinely throw away tubes after a flat. Never again...
    Nov 2006
    1 A thicker tube is still less likely to pop out of a cut then a thinner tube.
    2 Again, a thicker tube will be less likely to get cut by a small shard etc... then a super thin tube.
    You just like to argue don't you......
    Dec 2009
    Never really had a problem with them. I find them cheaper than replacing sealant lots.
    They are sensitive to UV and oil.
    mnoutain bkie rdier
    A bunch of roadies I train with use latex tubes. Typically lighter and improves ride. Why such an oddity for 29er mtb?
    Dec 2009
    They come from Europe , where a 29er is an oddity.
    Reputation: OmaHaq's Avatar
    Jun 2010
    I use latex on my psuedo-fat tire 26er. No way I'd run the same size on my 29er.
    Oct 2011
    Just got my new SJ HT Expert 29er. My LBS recommend michelin c4 latex due to better resistans against snakebites and sharp objects. The question is, are latex tubes really better than butyl tubes against sharp objects?
    KVW
    KVW is offline
    Law abiding citizen
    Reputation: KVW's Avatar
    Quote Originally Posted by masterofnone View Post
    Ha! It's not just latex that does that. JUST last night I was pumping up one of my wheels with this tube, at around 40 psi, BAM! tube exploded dismounting the tire from the wheel entirely.
    It litterally sounded like a gun went off right next to my ear. My right ear was muted for the rest of the night - still didn't feel right the next morning... man that sucked.
    "Single track is for pansies!
    I blast down a mountain once, and in my wake, lies a new single track for the rest of you."-sm
    Reputation: Zaratustra's Avatar
    Jan 2009
    Quote Originally Posted by Silwer View Post
    Yes they are definitely, + they roll better ....
    ... but with downsides :
    You will have to inflate before every ride,
    they can not be patched,
    a little tricky to install 26'' tubes in a 29'' application .. but doable ...
    I use to use them for ~two years and I'm not dissapointed .. but still I'm not sure if about the benefit related to the final cost ..
    You can apply some talcuum powder inside the rims and around the tube, for longevity.
    Always carry one or two spare tubes with you.Latex tubes are better than the simple tubes but they are not tubeless ...
    Reputation: CYCLEJCE's Avatar
    I ran the Panaracer greenlite latex tubes in my Breezer (yes, 10 years + ago...). They were awesome! Lite, and for me, easy to repair with a park peel and stick patch. I pulled the Breezer out of storage a few years ago and to my suprise the greenlites were still in it! I didn't try to air them up though.
    Also, a dollar bill makes an excellent make shift tire boot.
    Oct 2011
    ok, is latex better than butyl against sharp objects or is it a myth?
    Dec 2011
    I also use the C4 michelin latex tire in my 29er wheels, never had a problem.
    But i think i'm going to run latex only with a innertube as spare...
    All That is Man
    Reputation: Zero Signal's Avatar
    Seems to me that if you had a flat running tubeless, the course will almost certainly destroy a lightweight tube unless that flat was some kind of fluke. I carry around a True Goo tube. It's heavy, but it's better than removing redundancy by replacing a flatted tubeless with a race tube.
    John
    Sweep the leg!
    Reputation: Caffeine Powered's Avatar
    Mar 2005
    Complete Fail for the OP. Why would you care what a spare tube is made from when you're running tubeless to begin with? The tube will allow you to get back to the car or finish the event, but you'll be removing it once you get home. Don't be worried about the few grams a butyl tube has over a latex tube, you're carrying more unwanted grams of body fat and you can't blame the tube for that.
    Authorities speculate that speed may have been a factor. They are also holding gravity and inertia for questioning.
    Feb 2006
    Quote Originally Posted by Zaratustra View Post
    internet myth.
    Feb 2006
    Quote Originally Posted by rydbyk View Post
    Roadie tires weigh 200g, MTB 550-750 , kinda kills any feel/ suppleness a latex offers certainly not worth the added cost and fragile nature , especially if you compare performance/cost to a ultralight butyl.
    Oct 2010
    Quote Originally Posted by shiggy View Post
    I'd like to see you sitting calmly on the side of the trail searching your tire for foreign objects and/or booting the tire as your whole age class whizzes by you AND not swear like crazy.
    Something wrong with your bike? Blame it on super human strength and sleep well at night knowing you are more than a man.
    bt
    bt is offline
    Nov 2007
    I'm a latex salesman for Vandelay Industries.
    Feb 2007
    Quote Originally Posted by Fred Smedley View Post
    Kind of kills the argument for the superior ride and speed of tubeless then, doesn't it? There's either opportunity or there isn't.
    Latex is a low loss material, butyl is not. In road applications, latex tubes measurably lower rolling resistance over the lightest road butyl tubes. For MTB the effect would be even greater. On rough roads, road latex could save as much as 15 watts by Bike Tech's estimates, for MTB that's a pretty big deal for XC racing applications. With Nevegals, probably not.
    One thing's for sure, 26er latex tubes work just fine in a 29er. I've even used one on a Larry/P35 combo. Saying they are fragile is ridiculous FUD.
    Oct 2011
    Quote Originally Posted by craigsj View Post
    Nice to hear
    What about sharp objects, are they better than butyl, or are they equal?
    Feb 2007
    Nice to hear
    That depends on what you are comparing. Latex MTB tubes are lightweight so compared to lightweight butyl they are good. I've found that once a latex tube has been used in a tire for a while, changing the tire often results in failure if the tube is reused. That may be because I'm always using the super thin ones due to availability.
    The biggest problem with latex is price and availability. I like the Michelin ones (145g) but haven't seen them around. I use the Challenge ones, and they are available, but Challenge (95g) is really thin. I've purchased some Geax ones (135g) but haven't tried them yet. Hopefully they'll be reliable. My experience with road latex is that Challenge and Michelin are good while the others are a waste of time and money.
    I use tubes only with wheels not made for tubeless but use tubeless more often.
    Oct 2011
    No problem for me I've got the Michelins for free when I bought my new Stumpjumper HT expert 29:er last week.
    I have replaced the butyls with these, not for gaining less weight, just for more durability, I'll hope.
    JEA
    JEA is offline
    Quote Originally Posted by bt View Post
    Hey George , you can bike?
    JEA
    JEA is offline
    Tested by a Dutch farmer, difference between normal en latex tire .
    watch his wooden shoes
    Binnenband rektest - YouTube
    tl1
    tl1 is offline
    Bicyclist
    Reputation: tl1's Avatar
    I thought those were...
    Quote Originally Posted by CYCLEJCE View Post
    ...made of polyurethane not latex?
    Quote Originally Posted by tl1 View Post
    They very well could have been. It was, after all, 10+ years ago. May be a good alternative to Latex then...
Members who have read this thread: 8
