Results 1 to 15 of 15
    29 Tire pressure
    Can you please let me know what is the tire pressure on your bike.
    What should my pressure be?
    I am 160lb. I just got my bike, and the tire pressure seems low < 30 PSI.
    Seems like only 2/3 full. I can press down the tire by quite a bit.
    I will use on road or flat trial most of the time.
    Any tire pump recommendation ? I saw a floor pump with digital guage for $30 in Target.
    Thanks.
    Sep 2012
    When I'm on the road/flat dirt I use 70 lbs. with the tire noting 80 lbs. max. On MTB paths, I drop to 35 lbs. or so as I'm 205 lbs. High 28's, low 30's are normal for your weight. Most floor pumps will get the job done, you just get picky with the one you may carry.
    Sep 2012
    30-32 front, 35-38 rear depending on the trails and amount of jumps on that trail. 45 on pavement.
    I can't keep less in the rear or I get pinch flats. 205lbs on a Mamba.
    Vincit qui patitur
    Reputation: owtdorz's Avatar
    I'm 230# and ride 40psi on the road (commute)
    28-30 on trail
    Probably dropping to 25 on trail since going tubeless.
    I will be testing with psi this weekend.
    Vincit qui patitur
    2012 Salsa Spearfish 2
    2014 KONA Process 153
    2016 KONA Operator
    2013 Giant Defy
    Reputation: Justin Credible's Avatar
    I run tubeless, low 20's
    60% of the time ......it works all the time
    Feb 2010
    I'm running tubeless and run 22-26 PSI. Typically a couple psi lower in the back than the front. I find it depends somewhat on the tire and the trail.
    My road bike is tubes and I run at 80 minimum usually higher (that's running a 700 x 23 or 25 tire though and the sweet spot seems to be 100 psi for me at 165 lbs). What tire size are you running? For road try starting about 5-10 psi below max and drop in 5psi increments until you find the feel you like. For dirt start around 40 and do the same. If your running tubeless start much lower pressure like 25 psi and try adjusting in smaller increments like 1-2 psi. That's worked for me for a dozen different tires so far. I've also found I run different tires at different psi to get the best ride out of them.
    Reputation: Gasp4Air's Avatar
    Quote Originally Posted by apatron View Post
    Good advice. There is no one pressure setting that's appropriate. It depends on the tire, the riding surface and the rider.
    Use it, use it, use it while you still have it.
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    Quote Originally Posted by Gasp4Air View Post
    +1 - the width of the rim is also something to consider- particularly for low pressure if running tubeless. I can run my tires a good 2-3 PSI lower on (wide) Stan's Flow or Bonrager Duster's as opposed to (narrower) Stan's 355 or Crest rims.
    I am 190 pounds. Tubeless with Stans sealant.
    Front: Stans Flow Ex with Maxxis Ardent 2.4 = 20 psi
    Rear: Stans Flow Ex with Maxxis Ardent 2.25 = 25 psi
    Bicyclochondriac.
    Quote Originally Posted by Iam2of4 View Post
    Thanks.
    Go read the sticky at the top of the wheels and tires page.
    Rogue Exterminator
    Reputation: kjlued's Avatar
    It comes down a little to personal choice and obviously road conditions.
    I feel best at around 30psi but am usually on more difficult mountain paths.
    I am 165-170 lbs
    Wouldn't go too much below that or you risk a pinch flat.
    Reputation: Tillers_Rule's Avatar
    Sep 2004
    6'4, 200lbs, Kenda Nevegal on both my 26er and 29er.
    26er 35psi front, 40psi rear
    29er 30psi front , 35psi rear
    cross country, AM trails
    Feb 2010
    Quote Originally Posted by kjlued View Post
    Unless your running tubeless
    Always Learning
    Reputation: BruceBrown's Avatar
    Thanks.
    First of all, trust the reading on your pump or gauge about as far as you can kick it with your left foot. Best to invest in a nice digital tire gauge - and even then - not all are created equal. I say that because if you can press down the tire "by quite a bit", the 30 psi reading you are getting may not be accurate at all.
    I'm 180, run 21 psi front on a 2.35 Nobby Nic and about 23 psi rear (same size tire). Midsize tires such as 2.25's or 2.2's I will run about 22 front 24 rear. 2.1's or smaller, and I might be 2 - 4 psi or even higher front and rear depending on the tire. Everything is tubeless for me.
    Again - one man's tire gauge may be quite different from another.
    BB
    Quote Originally Posted by BruceBrown View Post
    BB
    I'll certainly back this up. Or better yet get used to the pump you use and figure out where you like your tires relative to that pump. I am 165 lbs and run tubeless 2.3 purgatorys.......my pump reads 15 psi front 18 psi rear. Now obviously that is not true, but I know relative to my pump where I like my tires.
