Results 1 to 13 of 13
    Reputation: ccaddy's Avatar
    24 hole rear hubs ?
    Im looking at replacing the rear hub in my Easton EA 90's with a
    Hope or King but haven't seen any with a 24 hole count .
    Is there such a hub on the market ?
    Reputation: 4slomo's Avatar
    Might be a good idea to upgrade to a higher spoke count for your rear hub, and then you might not need as heavy a rim.
    Hey everybody, ride my wheels! They ride good, real good.
    I'm a wheel builder. SRLPE Wheel Works. Send me a PM.
    Reputation: shiggy's Avatar
    Dec 1998
    24 hole rear hubs ?
    Quote Originally Posted by ccaddy View Post
    Just replacing the hub is false economy. You are better off building a whole new wheel--with 32 spokes.
    mtbtires.com
    Workin for the weekend!
    Reputation: -Todd-'s Avatar
    Nobody makes a 6 bolt disc 24 hole hub. Too bad too, because those Easton wheels would be an amazing setup if that rear hub had and kind of strength.
    Todd
    24h rear hubs.
    Actually there are one or two hubs on the market which will work:
    1. I've read, but not confirmed, that Tune makes a rear 24h hub. You can search for that one.
    2. Extralite makes a rear 24h hub, the HyperRear2, quite expensive though.
    Dec 2010
    hi
    I've found also this:
    E Thirteen XCX+ 6-Bolt Rear Disc Hub
    you can find it here:
    E Thirteen XCX+ 6-Bolt Rear Disc Hub | Chain Reaction Cycles
    Someone told some problems with the rear one (you should find a 3D in this forum).
    Cheers
    Ernesto
    Presently , there are no issues with my setup as far as reliability or weight .
    I had a King on my last bike and I miss the bling and the noise and thats all
    I am looking for for my current bike .
    Ive found that White Brothers makes a 24 hole rear disc hub but Im looking for red and there colours are silver and black .
    There is a hub recall but mine is not within the serial numbers affected .
    4slomo - The Easton rim is not heavy at all .
    Extralites .... ya just a wee expensive although the Hypercamber2 has a
    really different look .
    Reputation: Bike Whisperer's Avatar
    Circus Monkey hubs on Ebay...in red even
    Couldn't be any worse than the stock Easton hubs
    6pawl 48th Rear M5 24 Hole Dati Disc Hub MTB Bike Red Enduro Circus Monkey | eBay
    If your rim continues to work for you, great! Hope you never break a spoke, though, as you'll probably be walking...
    I should be out riding
    Reputation: ACree's Avatar
    Sep 2004
    24 hole rear hubs ?
    White industries just started offering a full range of anodized colors. They look nice (pics anyway).
    If it's not powered solely by you, it's a motorcycle.
    Worshiping at the Church of Singletrack since 1993.
    Eaton spokes are not propitiatory as you may think .
    My LBS was able to replace one last season with another make .
    Only thing is it was black and didnt match the rest .
    No biggie .
    Dec 1998
    24 hole rear hubs ?
    No biggie .
    The issue is not spoke availability. It is the low spoke count.
    If/when a spoke does break the wheel is compromised much more than a 32 spoke wheel, and low spoke count wheels tend to be more flexy/less stable in the first place.
    If you are OK with that, finding replacement rims or hubs is harder, which is the problem the OP has.
    mtbtires.com
    I too had suffered with the failure of the hub bearings and freehub and after a long search for a 24 hole hub managed to find the White Industries Mi6. This hub is beautiful real quality workmanship and they are super to deal with.
    They also make it in black as well but I like shiny objects!
    Just finished lacing the wheel and about to go to true it used 298mm spokes throughout made the job a little easier. This is quite a difficult wheel to lace as Easton uses these left handed nipples that you must insert and put a half turn on them before attempting to insert the spoke thread. Some serious bending needs to be done to locate the spoke and then carefully tighten. It is very easy to cross thread the nipple in the eyelet so take it easy and I would recommend using linseed oil as the prep for both the nipples and the spoke.
    The original spokes were thinner than these DT Swiss ones and hopefully make the wheel a bit stiffer as I found plenty of flex with the originals.
  1. 36 hole pull apart hubs?
    By jawnn in forum Wheels and Tires
    Last Post: 11-29-2016, 12:47 PM
  2. Replies: 11
    Last Post: 10-16-2013, 07:12 AM
  3. Disc wheels lacing patterns - 32 hole A2Z hubs/Crest rims
    By TigWorld in forum Wheels and Tires
    Last Post: 12-11-2011, 10:14 PM
  4. Rims for 28 hole DT Hubs?
    By robotfury in forum Wheels and Tires
    Last Post: 10-17-2011, 07:35 PM
  5. 24 hole, 15mm thru axle hubs?
    By Haydos in forum Wheels and Tires
    Last Post: 02-23-2011, 03:23 PM
