    Jan 2013
    2013 sj fsr rear shock
    i need help with the red bleed off valve. i put 175 psi in the shock (black valve) and then i go to pump up the red valve to set my sage and when removing my shock pump it bleeds the whole shock to where there isnt any air left in it. i unscrew it as fast as i can and it still bleeds out!!!!! is my shock bad ? i just picked the bike up on friday. or is my shock pump bad?
    Jan 2013
    Wow okay don't listen to the salesman about how to set up your shock!!!! You are just suppose to fill the shock to 300 psi and then depress the red valve. At no point are you supposed to EVER put your shock pump on the red valve!!! Man I hope I didn't mess my shock up already!!!! I will be very mad.
    Jan 2013
    Guess you dont need any help. Hope things are well
    Jan 2013
    Well I don't think I need help but I did put 150 psi into the red valve. I hope it didn't wreck the shock.
  1. Replies: 38
    Last Post: 01-27-2014, 01:09 PM
  2. Replies: 0
    Last Post: 04-23-2013, 01:22 PM
  3. 2013 Scalpel 1 XX Rear Shock - Tips?
    By wildh in forum Cannondale
    Last Post: 04-21-2013, 07:53 AM
  4. Rear shock - 2012 RP23 to 2013 CTD
    By JTBAZ in forum Santa Cruz
    Last Post: 01-29-2013, 09:39 PM
  5. Remote Lever for 2013 Fox CTD Rear shock
    By Bruce M in forum Shocks and Suspension
    Last Post: 12-06-2012, 07:46 AM
