Results 1 to 11 of 11
    Oct 2011
    2013 Rockshox reba vs SID 120mm
    Hi,
    I am building a 29er HT and have done a mountain of research on the reba and SID.
    From what I have read they are both awesome.
    My HT will be used on rocky trails.
    I am going for a lighter build without spending to much $$$.
    The Reba is about $550 and the SID about $750. (Its not the xx ver SID.)
    From peoples experience what should I get? I can afford either but is the SID extra money worth it.
    Any suggestions appreciated.
    Thank you
    Sent from my GT-N7105T using Tapatalk 2
    RockShox DIG Valve - Sea Otter Classic - 2013 Sea Otter Classic Pit Bits - 1st Edition - Mountain Biking Pictures - Vital MTB
    Since this is a SID feature for 2014 you should check it out, or find a 2012 dual air Reba.
    Oct 2011
    Thanks eb, I will check it out, The SID does look nice.
    Reputation: brentos's Avatar
    The RCT3 damper in the Sid is awesome. That damper alone might be worth the extra $200.
    Oct 2011
    Re: 2013 Rockshox reba vs SID 120mm
    Ok, sounds like the SID 120mm is the winner. Should be good on the HT.
    some know me as mongo
    Anotherthing you can do is bit the Reba and then put the rct-3 damper in it for able $100. That is what I'm probably going to do with my Reba. Saves money
    3000 mile goal for 2018
    3402.7 miles ridden in 2017
    3028.4 miles ridden in 2016
    Reputation: duggus's Avatar
    Quote Originally Posted by meerkite View Post
    I wouldn't if you are on rocky terrain. The Reba is much better at small bump and big hit together... I had both and liked the Reba better. SID is a firmer race fork... you either set the air too low and it bottoms out on big hits but has good small bump... or you go a little higher and now it feels like a rigid fork. There was no good middle ground for me. There are a couple other posts about this recently as well. Don't just get SID because you feel it is more high end looking or for the name.
    I ditched them both and went with a White Brothers Loop 120... best of them all
    ...Be careful what you're looking at because it might be looking back...
    Oct 2011
    Quote Originally Posted by duggus View Post
    Thanks duggus
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Duggus nailed it. The Reba has the best of all worlds; plush, great small and big hit response, and fairly decent weight. Reba wins, in my book too...SID is just too darn firm and rattley, when dealing with rocks on a hardtail.
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Oct 2011
    I ended up buying a reba as they where on special for 2 good of a price.
    I did some research on the white brothers 29er fork which looks very good. But I couldnt find a resonable price online and delivered to Australia.
    Thanks again
    rr
    rr is offline
    I don't do PC
    Reputation: rr's Avatar
    Hmm, I've got a new Sid on my HT and it's awesome. Set sag to 15-20%, run the RCT3 in middle position with 2 clicks of low speed comp. If you want plush just run the damper in the open position it's like a pillow, not sure why you would want that on a hardtail tho.
  1. 2013 Rockshox Reba RL Seal came out!
    By WillT19 in forum Shocks and Suspension
    Last Post: 06-10-2015, 02:11 PM
  2. Replies: 55
    Last Post: 04-10-2015, 01:57 PM
  3. 2011 Rockshox Reba RLT 29er 120mm capable?
    By KVW in forum Shocks and Suspension
    Last Post: 03-15-2012, 02:21 PM
  4. Rockshox Reba 120mm vs 140mm weight difference?
    By Ace5high in forum Shocks and Suspension
    Last Post: 01-24-2012, 09:22 PM
  5. Reba 140mm reduced to 120mm vs. Reba with 120mm stock
    By thekaiser78 in forum 29er Bikes
    Last Post: 06-30-2011, 04:15 AM
