Results 1 to 2 of 2
    2012 specialized Stumpjumper Roval wheels - question
    I would like to upgrade my stock roval wheels any idea what the specs on the wheels - qr size, spacing, etc - can't find the specs anywhere. Any suggestions for light Clydesdale wheel set?
    Apr 2005
    I swapped out the wheels on my 2012 Stumpjumper last winter. You have a lot of options, as long as you get hubs that fit the fork and frame. The rear hub needs to be a 142x12mm thru-axle. The front hub is a 15mm thru-axle. I went with Hope Pro 2 Evo Disc hubs. They had a reputation for being well-made and they're relatively affordable.
    If you're a heavier rider, I would recommend going with 36 spokes. The stock wheels have 32. The extra spokes add a lot of rigidity. For rims, you should think about whether you'll want to go tubeless or not. I'm running tubes, and went with Mavic hoops, but if I had to do it again, I'd probably go with Stans rims, so I could have more tubeless options.
    Justin
    Salt Lake City
    2012 Specialized Stumpjumper FSR Comp 29
    2006 Specialized Allez Expert Double
  1. Specialized Roval Wheels
    By rljohnso1601 in forum Specialized
    Last Post: 06-06-2013, 04:14 AM
  2. Specialized Roval DH Wheels any good?
    By cesalec in forum Wheels and Tires
    Last Post: 04-29-2013, 07:39 PM
  3. Replies: 0
    Last Post: 04-28-2013, 07:32 AM
  4. Specialized Roval DH Wheels Tubeless?
    By nomasendo in forum Specialized
    Last Post: 02-04-2013, 06:56 PM
  5. Specialized Roval DH Wheels Tubeless?
    By nomasendo in forum Downhill - Freeride
    Last Post: 01-29-2013, 10:19 PM
