Results 1 to 2 of 2
    May 2010
    2010 Fox F29 Terralogic travel adjustment
    Hey guys, I wanted to ask if my current 2010 Fox F29 FIT Terralogic can be changed from 80mm (current) to 100mm? I've read several posts about F29 travel changes, which seems like it's a fairly simple process (taking out a spacer), but wanted to make sure the Terralogic models weren't any different.
    Reputation: thasingletrackmastah's Avatar
    guess you already found this topic and this post.
    To be sure:
    Take apart the fork.
    Measure the travel of the right piston (damper)
    If this is 100mm (or more) you can safely remove the spacer on the left leg (air spring).
    Belgian beer and Scotch whisky.
