Results 1 to 5 of 5
    2006-2009 Reba Lowers Upgrade?
    Has anyone on mtbr upgraded a 06-09 Reba fork with 9mm lowers to the 15mm or 20mm lowers...can it be done?
    I know that you cannot use the 15mm lowers on you older fork. The newer forks with 15mm lowers have different bushing position, damper shaft lengths and other parts to match the shorter length of that generations stanchions.
    I'm pretty sure that the 20mm lowers will work, but I didn't look it to confirm.
    In the end though, why bother. Your fork is old, probably could use a complete overhaul, and lowers are not cheap. You should just sell that fork and use that money plus the money you would spend overhauling it and getting new lowers to buy a new fork with the axle type you want.
    Crash Dummy In Training
    Reputation: PauLCa916's Avatar
    Jun 2013
    From what Rock shox told me is that if I send my 2012 Reba RL in for an overhaul that for another $100 they will replace the lowers with 15 mm.
    I would call them.
    2015 Flyxii / ENVE /Chris King Carbon 29'er H.T.
    SRAM XX1
    2012 Stump Jumper Comp 29'er H.T. SRAM XX1
    1997 Rock Hopper / Rock Shox Recon Silver / 1 x 10 SRAM X9 XO Mix XT V Brake system
    Quote Originally Posted by PauLCa916 View Post
    I would call them.
    It nevers hurts to make a phone call, but his older fork is not compatible with the 15mm lowers. Your newer fork is.
    Maybe though they would do something similar for him and the 20mm lowers if they still have them?
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    In 2010, Rock Shox went with 32mm stanchions and 15mm Maxle Light compatibility. Pre-2010 RS forks across all lines, cannot go 15mm TA. Sorry....
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
  1. Why are Reba Rl lowers recessed?
    By Thumper71 in forum Shocks and Suspension
    Last Post: 12-28-2011, 09:03 AM
  2. 15mm Reba lowers on Brain 9mm Reba?
    By Le Duke in forum Shocks and Suspension
    Last Post: 12-21-2011, 06:13 AM
  3. Where to get 2006 888 lowers?
    By 67rider in forum Downhill - Freeride
    Last Post: 08-26-2011, 01:09 PM
  4. Reba 20mm lowers on a '10 SID XX?
    Last Post: 08-14-2011, 02:14 AM
  5. 29er lowers on 2006 Minute 3:00 130
    By p_mihai_ro in forum Shocks and Suspension
    Last Post: 04-22-2011, 01:40 PM
