Results 1 to 26 of 26
    Reputation: wideawakejake's Avatar
    Jan 2015
    2.6 on 29 internal width wheels?
    I am currently using a 29x2.35 Butcher and 29x2.35 Slaughter on my 2019 Stumpy Comp ST. These tires are just too narrow for my liking. Might just go with tried and true dhf 2.5 and try a 2.5 Aggressor on rear. But before i do that, I was wondering how some of the new 29x2.6 tires would work on 29mm wheels? Is that too narrow of a wheel for that wide of a tire? I know the 2.6 Butcher and 2.5 Maxxis are more like 2.4 but Schwalble and some of the others always measure out.
    Specialized Camber 29
    Reputation: MSU Alum's Avatar
    I tried 27.5x2.6 Schwalbes on 23mm iw rims and they were fine. That wasn't optimum, so I now run them on 35mm, but my wife runs them on 29mm iw rims with no issues at all. If you plan on running really low pressures, 29mm may be just a bit narrow, but I think you'll be fine. I believe Maxxis has 30-35mm as optimum for their WT's, but this isn't rocket surgery. 1mm won't make a big difference.
    Out spokin'
    Dec 1999
    My rims are only 1.5mm wider than yours (i30.5mm) which is insignificant. I'm running 29x2.6" Schwalbe Nobby Nicks -- this rim/tire combo works great. Personally I wouldn't hesitate to give such tires try on i29mm rims.
    =sParty
    disciplesofdirt.org
    Jun 2014
    Agree with above comments, I am running NN 2.6 front and NN 2.35 rear on 28mm internal Light Bicycle rims and they work great. I put it all together with those tires in mind, and I am very pleased.
    My 36i seemed to big for the rekon 29x2.6....but just right for the Bontrager xr4 29x2.6...
    Combat Wombat
    Reputation: BrianU's Avatar
    I have been running a Maxxis Rekon 29 X 2.6 on a 29mm for about the last 6 months. Initially experimented with pressures down to 11.5 lbs, which felt pretty good, but I ride some rocky trails and rim strikes were too easy for my liking. I eventually settled on 13.5 lbs and under my 170 riding weight, actually feels firm. Still smack a rim occasionally, but it takes some doing on my part. Seems like a great combination to me.
    Jan 2015
    good to hear. i appreciate it. yeah, Ive got the Maxxis set up in my Amazon cart ready to go. Bike shop has some 2.6 NNs. I would imagine they are a true 2.6. I am very hesitant on the Nics though. seems they are like Ardents. People either love em' or hate em'. I had Ardents and I wouldn't wish that crap tire on anyone. Although I did give mine away to a buddy. I would love to try the new Hans 2.6, but at $90, I can live without em. Sucks because I used to love the Hans in 29x2.35. such an awesome, forgiving tire.
    Jan 2016
    I emailed Bontrager on that subject and it was OK but it depends on tire model. I suggest you write to the manufacturer about your model. Even if it is OK in my personal experience you might be heavier or more agressive or on different trails so i prefer to not allways trust what i hear or read even if it comes fom a person with good intentions.
    Reputation: jeffreyjhsu's Avatar
    Wideawakejack, I've got the same rims as you on my Specialized Enduro. I've been runnning Kenda Sabre Pro 2.6 tires for a couple of months now. No problems with fit and I can run much lower tire pressures.
    Jan 2015
    thanks Jeff, i will check those out. Haven't had Kendas since a set of Nevgals back in 210. Sort of debating between 2.35 Hans f/r, 2.6 Nics f/r, 2.5 dhf/2.5aggressor, and 2.5Agressor f/r. Had every tire except the Nics.
    Jan 2015
    So ended up just getting 2.6 purg's front and rear. My bike shop had em, and I get a nice discount. For those wondering the 29x2.6 Purgatory's are really a true 2.4. Or a Schwalbe 2.35, or a Maxxis 2.5. Basically I remembered why I got rid of my 27.5 + Tallboy, and realized a true 29x2.35 or 2.4 is pretty much optimal. I would say the Purgs are just a good all round tire choice.
    Here, diagonally!
    Reputation: JACKL's Avatar
    IMO, the Nics the strength of the Nic 2.6s is that they roll really well for a true 2.6. Grip is decent, but not stellar. But just going to a 2.6 from a smaller tire will give you more grip. The cush of a bigger tire is nice for sure.
    Oh and i29 is perfectly fine for this tire. You'll get a little more sideways flex than with a wider rim. Generally that is not a plus, but personally on faster bumpy corners I actually like a little bit of give in that area.
    Jan 2016
    Quote Originally Posted by JACKL View Post
    JACKL thanks for that info. I am just curious what do you think of the Nic 2.6 on wet rocks and roots? I like my XC hardtail with a Specialized 2.35 in front, it was fine too previously with a Continental 2.4 but it might be just to make it a bit more versatile. My frame is too narrow for it in the rear.
    Oct 2015
    Quote Originally Posted by wideawakejake View Post
    The Aggessor will be just fine. The DHF will require you to be really dedicated to lean the bike over. I had the DHF on 30i rims and took it off, will put it back on for park stuff. But the DHR2 is a better tire most the time.
    Here, diagonally!
    I don't have a whole lot of experience with these tires on wet roots, but I did ride a wet trail on the Vancouver North Shore and they gripped wet roots and wooden features very well, although the soil there seems to promote grip regardless. Few other wet rides in TX, and didn't notice any bad habits out of the norm...although when there is mud on a root, the tire will slip regardless.
    Reputation: socal_jack's Avatar
    Dec 2008
    Currently running 29x2.6 Butcher/Purg combo on WTB i29 asyms, after more than a month neither has even hit 2.5" across at widest point with usually ~20/22 psi f/r. They are fairly tall tho, about the overall size of the Gomas they replaced and about same weight I believe. When I bought they had em mounted on new Stumpy looked all of 2.6 but the rims looked wide like 35mm+. Butcher seems a lot like a DHF, need to actively lean to get the most bite, probably get something else next time for the front.
    ROS9+ SS
    ROS9 SS
    GT Peace 9R SS
    A note on Bontrager XR2 2.6 Teams. High volume rounded profile goes good on a 40mm inner. 30 works for a 2.2. 35 for a 2.35.
    Oct 2015
    Quote Originally Posted by eb1888 View Post
    2.6 on 29 internal width wheels?-screenshot_20180817-091117_samsung-internet.jpg
    Stop with the BS. Trek designed the tires around 30i because that is where most people find is the sweet spot. And what they will spec on their bikes.
    You might like something different but you only speak it, as gospel.
    Jan 2009
    Do you sell rims or something? You keep pushing this idea that everyone needs wide ass rims for 2.2 tires.
    Quote Originally Posted by thesmokingman View Post
    Just about any thread that has to do with rim / tire width contains a 35mm+ rim and Bontrager tire endorsement from eb1888...
    Zealot "a person who is fanatical and uncompromising in pursuit of their religious, political, or other ideals"
    Just my experience on the XR Team 2.2 and 30mm inner rims. This info is for Bontagers only. It's a light 120tpi flexible sidewall tire. Because its high volume you need a wide rim. But then you can run it at low psi for a big footprint and traction.
    I started running that combo in 2014 before Trek had any wide rim recommendations. Not gospel but years of riding is the basis. These are higher volume with a more rounded tread profile than any other 2.2s. So that's kinda unique. I don't know of another 2.2 that goes with a 30mm inner rim.
    All last year there weren't any XR2 2.35 because of manufacturing problems. But that tire is higher volume than the 2.2 so a 35mm is logical. And the 2.6 is just out. The one person running the 2.6 is Mikesee in Park City. He's liking that tire on his 40mm inner rim wheels.
    These recommendations are only for Bonty XRs. If your terrain or speed requires heavier sidewall tires or you like another brand pick your own rim width. For the loose over hard I get to ride these are my best choice. And they last Plus are not as expensive.
    Mar 2018
    Looking for some 2.6 tires for a Stans Arch wheelset. I think they measure 30mm external and 26 internal. Is there a 2.6 tire that would work with this rim?
    Oct 2013
    Spec 2.6 Tires very narrow
    Anybody else finding that their Specialized 2.6 tires are pretty narrow?? On 30mm internal width Bontrager Line elite pro wheels, I just threw these on and they are measuring less than 2.5... I do expect they'll stretch a bit as these are brand new, but pretty bummed. I think it's a slaughter and butcher, both measure the same.
    Reputation: Lone Rager's Avatar
    Dec 2013
    I can't get a good measure using a ruler and find a calipers work better for me.
    Do the math.
    Dec 2008
    Quote Originally Posted by tgent13 View Post
    Yeah, see my post above same thing with calipers ~2.45 purgs evers so slight wider than buychers but never stretched really
    ROS9+ SS
    ROS9 SS
    GT Peace 9R SS
    Reputation: c_kyle's Avatar
    I'm running Rekon 29x2.6 and Bontrager XR2 Team 29x2.6 on Nextie 34i rims. The tire/rim combo seems to work very well and both the Maxxis and Bontrager tires measure exactly 2.65" wide and 2.65" tall from the bead. The tire combo feels like a XC tire setup, fast and grippy on XC singletrack.
  1. Min width tire width for 40mm internal rim?
    By bank5 in forum Wheels and Tires
    Last Post: 11-20-2017, 04:19 PM
  2. Replies: 3
    Last Post: 05-01-2016, 04:11 PM
  3. Internal fork width?
    By lancelot in forum Fat bikes
    Last Post: 10-30-2012, 02:58 AM
  4. Internal width of AC 29 Race or stiffness of Reynolds?
    By westin in forum 29er Components
    Last Post: 07-18-2012, 05:31 AM
  5. Roval 29 weight and internal width?
    By dlorga in forum Specialized
    Last Post: 01-22-2012, 02:34 PM
Members who have read this thread: 294
