Results 1 to 19 of 19
    Reputation: tailwaters's Avatar
    1x9 to 1x10 is it worth it??
    About 10 months ago I built up a new Niner air9 with a 2x9 setup. Great setup and have been very happy with it. I decided a month ago to convert to a 1x9 to simplify things. Have been very happy, but has taken me a little bit to get used too. The current gear selection is very close to what I used to have but just little off that I do notice it. I know time will cure that as I figure I've been riding the same basic gear set for 10 years now. With the only exception of the prior being a 3x9 setup. So I was kicking around the idea of going to a 1x10 to give me one more granny gear. Currently I have a 1x9 with an 11-34 cassette. The 1x10 would be an 11-36. A lot of guys I ride with ride the 2x10 or 1x10 setup and love it. I'm just not sure the cost justifies the gains?? I figure it will cost me $250 to make the change and if I sell my current parts probably a $100 investment.
    1x10 is the cats pajamas. But for that price, I would wait till you wear you current parts out then upgrade.
    18 Focus Raven Lite
    17 Focus o1e
    17 Yeti ASR-cT
    16 Bianchi Specialissima
    15 Echo Big Deal
    Sep 2012
    How about just throwing a smaller front ring on... going from 34-36 in the rear isnt going to make that big of a difference.. But going from 32 to 30 or 28 up front will make a big difference and cost way less..
    Reputation: pascale27's Avatar
    Quote Originally Posted by SB Trails View Post
    exactly, I'm running a 30T chainring up front, it gives me the extra "granny" I need for long steep climbs. Love my 1x10
    Salsa Timberjack 27+
    Niner Jet 9
    Misfit diSSent 1x11
    I did drop down to a 32t up front when I made the conversion. Maybe dropping to a 30T would be the best way at $20 or so.
    Shimano CS-HG61 29er Cassette 12-36
    Shimano makes a 9-speed 12-36 cassette, that's what I use.
    B.Ike
    Reputation: ElwoodT's Avatar
    Mar 2011
    The difference between 32-34 and 32-36 is barely noticeable and not worth the weight penalty imho. (more like half a gear) You could also keep your current drive train and just get a 36 cog or a new cassette.
    For a long time I thought that 9 speed was always going to be the cheaper alternative, but this season it seems like 10 speed takes the cake for good deals (especially on the oe stuff).
    TBMD9er Thanks!! I was not aware of that.
    Reputation: thasingletrackmastah's Avatar
    Quote Originally Posted by TBMD9er View Post
    Quote Originally Posted by tailwaters View Post
    I compensates for the 10% extra circumference of the 29" wheel , but it's only in Deore, no spider, so it weighs quite a bit more then the XT 11-34
    Belgian beer and Scotch whisky.
    I did some research last night and discovered the weight issue. I'm not looking to add any weight so that's not going to be an option.
    hold my beer & watch this
    Would not be worth it to me - I only use about 4 or 5 rings, not sure if I have ever used the big ring in the back. Pretty flat around here, most rides I may only use 2 rings. My bike has a 10 spd rear, single on the front, but 9 would have been fine with me.
    Women and cats will do as they please, and men and dogs should relax and get used to the idea.
    -- Robert Heinlein --
    Reputation: Bike Whisperer's Avatar
    I got an 10 speed SLX shifter and cassette with an XT med cage derailleur and chain from Jenson USA for under $200. You should be fine with your front chainring though you'll probably want a guide.
    30t chainrings for a 104bcd crankset are rare and usually involve modifying your tabs a bit.
    Reputation: mattbryant2's Avatar
    Apr 2005
    This thread is funny. Splitting hairs if you ask me.
    Just Ride!
    Reputation: kustomz's Avatar
    I run a 1x9 setup with a 38 ring on 180mm cranks and an 11-34 cassette and have never felt I lacked anything. Plus, I can't imagine a 1x10 shifting any better either.
    Dec 2010
    Going from a 32t to a 30t in front is the same as going from a 34 to 36 in back. There is no difference. But true, that cost would be much less. With a 30t or 28t, you will more than likely spin out on flats.
    I live in SE Michigan, and it's fairly flat. I run 32t(sometimes 34t) 11-36 1x10 and I sometimes spin out with the 32t. I run 1x10 only because my bike came with 10spd. I would have been happy with 32t 11-34 1x9.
    To me, 1x10 isn't about better shifting, it's about having that 36t cog. Road riding benefits 10spd more, as having a steady cadence is easier with 10 speeds. I recently converted my road bike from 2x10 to 1x9. 10 speed was better, but I have an MTB cockpit( XO gripshifters, SD7 levers, flat bar) and it's pretty cool.
    Anyway, stick with the 1x9. And as irishpitbull mentioned, upgrade when parts wear out.
    Good luck
    10 vs 9 is only worth it if Shadow Plus benifits you.
    For me, Shadow Plus was benificial enough to convert.
    My 9 sp was like silk, and so far ten speed is as good.
    Quote Originally Posted by mucky View Post
    For final gear? awesome!
    Quote Originally Posted by plstrns View Post
    Table of gear-inches for 29er. Rows are chainrings, Columns are cogs.
    22 24 26 28 30 32 34 36 38 40 42 44
    51 56 61 65 70 75 79 84 89 93 98 103 11
    47 51 56 60 64 69 73 77 81 86 90 94 12
    44 47 51 55 59 63 67 71 75 79 83 87 13
    40 44 48 51 55 59 62 66 70 73 77 81 14
    38 41 45 48 51 55 58 62 65 69 72 75 15
    35 39 42 45 48 51 55 58 61 64 67 71 16
    33 36 39 42 45 48 51 54 57 60 64 67 17
    31 34 37 40 43 46 49 51 54 57 60 63 18
    30 32 35 38 41 43 46 49 51 54 57 60 19
    28 31 33 36 39 41 44 46 49 51 54 57 20
    27 29 32 34 37 39 42 44 47 49 51 54 21
    26 28 30 33 35 37 40 42 44 47 49 51 22
    25 27 29 31 34 36 38 40 42 45 47 49 23
    24 26 28 30 32 34 36 39 41 43 45 47 24
    23 25 27 29 31 33 35 37 39 41 43 45 25
    22 24 26 28 30 32 34 36 38 40 42 44 26
    21 23 25 27 29 30 32 34 36 38 40 42 27
    20 22 24 26 28 29 31 33 35 37 39 40 28
    20 21 23 25 27 28 30 32 34 35 37 39 29
    19 21 22 24 26 27 29 31 33 34 36 38 30
    18 20 22 23 25 27 28 30 32 33 35 36 31
    18 19 21 22 24 26 27 29 31 32 34 35 32
    17 19 20 22 23 25 26 28 30 31 33 34 33
    17 18 20 21 23 24 26 27 29 30 32 33 34
    16 18 19 21 22 24 25 26 28 29 31 32 35
    16 17 19 20 21 23 24 26 27 29 30 31 36
    Reputation: AmericanTemplar's Avatar
    I'm getting one of those new MRP 28T rings for Christmas. I currently have one of those Shimano 12-36 9 speed cassettes and I'm thinking about putting an 11T on in place of the 12. Should be the perfect range!
