Results 1 to 3 of 3
    1x11 xx1 - switching from 32t to 28t - how many links to remove?
    I'm new to XX1 and recently got a Rip 9 RDO with XX1 on it. Tomorrow I'm planning on switching the front chain ring from 32t to a 28t. I'm wondering as a guideline how many links from the chain I'll need to remove - I'm thinking likely 2 or 3 but wanted to check here first for some guidance.
    Bicycle Addict
    Reputation: J3SSEB's Avatar
    The unexamined life is not worth living - Socrates
    Bearded Women Racing
    If your chain was setup at a minimum length before then you probably don't need to remove any. But in theory, 2 links - or one link, depending on how you count links.
    You are removing 4 teeth - it is a 1/2 inch chain so you have removed 2 inches of circumference from the chain ring - your chain wraps approx. half the chain ring so you have reduced the required chain by 1 inch.
  1. 1x11
    By singlesprocket in forum Eastern Canada
    Last Post: 03-06-2017, 09:40 PM
  2. X0 1x11
    By Shalom in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-14-2013, 02:25 PM
  3. Replies: 6
    Last Post: 04-20-2013, 02:01 PM
  4. Best price on Teva Links or Links Mid?
    By GTscoob in forum Where are the Best Deals?
    Last Post: 04-05-2013, 09:15 AM
  5. multiple quick links (power links)
    By BmoreKen in forum Singlespeed
    Last Post: 02-12-2013, 11:23 AM
