Results 1 to 11 of 11
    Reputation: Flat Ark's Avatar
    15mm to 9mm dropout adapters?
    I'm having a custom frame built and am gonna mate it to a Fox fork that uses a 15mm thru-axle. I should have said frame/fork in my hands within a couple of weeks! Problem is my front hub is 9mm and it is not possible to convert it to 15mm. While I do plan on rebuilding the wheel with a 15mm hub at the end of the year I was wondering if anyone makes adapters to reduce the size of the dropouts in the fork to 9mm? Thx
    Huckin' trails
    Reputation: David C's Avatar
    Quote Originally Posted by Flat Ark View Post
    Unless your front hub uses a 9mm thru-QR axle, you will have a hard time fitting 4-5mm of axle sticking out on each sides of the hub into a closed drop-outs fork.
    And even if you could, I wouldn't trust such setup on a mountain bike. With the side torsion from your disc brake, chances are you won't be able to have a stiff enough front end to MTB properly and most likely always have trouble with the rotor/caliper alignment.
    I wouldn't recommend it. Maybe you can find an used 15mm front wheel on the cheap meanwhile to get you trough the season ?
    Quote Originally Posted by NicoleB28 View Post
    topless. that's what all mtb girls do. we go ride, get topless, have pillow fights in the woods, scissor, then ride home!
    Jun 2005
    Mavic makes a 15mm to QR adaptor that fits their crossmax and other wheel sets. They cost about $10. Alternatively there is a seller on ebay, mtbtools i think, who sells an aluminum axle that fits in just like a 15mm thru axel. you can use either a standard qr or a 9mm RWS thru-bolt to mount to the fork.
    Mountain Bike 15mm thru Axle to 9mm Quick Release Wheel Adapter | eBay
    this is a link to the one I bought but he also makes one that uses a standard QR. I have used both the mavic and the ebay adaptors with no issues.
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    Haven't tried one yet but this is purported to be a good solution.
    http://www.ebay.com/itm/Mountain-Bik...item3a75206910
    I recently picked up a wheel set with a 15mm front that I am hoping will end up a spare for my 9mm rigid SS front with this adapter.
    eDub
    【ツ】 eDub 【ツ】
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    Corrected
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    Quote Originally Posted by meltingfeather View Post
    Just to clarify, the adapter on eBay linked by Oldnslow is for use with a 9mm Thru Bolt alla DT Swiss, which is not your standard 9mm quick release.
    That same dood makes the adapter kit for a standard quick release (link).
    I have seen the Mavic adapters (here) work, but the construction of the eBay guy's stuff looks a lot more solid to me.
    Neither one of these will work for the OP. He has a 9mm wheel but wants to use it with a 15mm fork.
    Corrected... Had it backwards.
    Huckin' trails
    Corrected too.
    Quote Originally Posted by David C View Post
    It's not like we're doing each other
    Huckin' trails
    Im glad you enjoy rubbing it in and felt motivated to let the whole community know.
    Haha, come on don't get all excited at me. It's not like we're doing each other's hair and make up.
    I bought one of the Ebay gizzmoes last year for my Hopes and like it.
  1. CB Iodine 15mm hub adapters
    By bayareaflip in forum Ibis
    Last Post: 08-02-2013, 08:13 PM
  2. 15mm QR to 9mm QR fork adapters.........
    By qkenuf4u in forum Shocks and Suspension
    Last Post: 06-17-2013, 03:50 AM
  3. 15mm Through Axle adapters?
    By BigDaddyFlyer in forum Airborne
    Last Post: 03-24-2013, 05:45 PM
  4. Replies: 7
    Last Post: 09-19-2012, 04:59 PM
  5. 15mm axle - 9mm dropout - am I screwed?
    By trojans1993 in forum Wheels and Tires
    Last Post: 05-29-2011, 09:31 PM
