Results 1 to 13 of 13
    Crash Dummy In Training
    Reputation: PauLCa916's Avatar
    Jun 2013
    15 mm Chris King Front hub to 9 mm T.A.
    Okay I picked up a set of Chris King ISO hub's the front is 15 mm T.A.
    My Stump Jumper Comp with a Reba RL fork is 9 mm Thru axle.
    Has anyone found a way to convert to 9 mm T.A ?
    And no Chris King don't make a conversion for it.
    My option's are:
    Get new lower's for my Reba and run 15 mm T.A.
    Get 9 mm Quick release conversion and run 9 mm QR.
    Or get different front hub with 9 mm T.A.
    Just thought I would put this out there in case some one has had same problem.
    T.I.A
    2015 Flyxii / ENVE /Chris King Carbon 29'er H.T.
    SRAM XX1
    2012 Stump Jumper Comp 29'er H.T. SRAM XX1
    1997 Rock Hopper / Rock Shox Recon Silver / 1 x 10 SRAM X9 XO Mix XT V Brake system
    Reputation: OldHouseMan's Avatar
    Do you have the SD or LD front hub? The SD is convertible between QR and 15mm. If you have the LD front hub it is not convertible to QR.
    Chris King hub specs
    I only ride bikes to fill the time when I'm not skiing.
    Big Boy
    Reputation: texasnavy05's Avatar
    I know that this mavic brand, but they should work universally. I just got a set for my american classic wheels and it worked perfectly.
    Mavic 15mm to 9mm Q/R Adapter | Mavic | Brand | www.PricePoint.com
    -It's time to shred some mild to moderate gnar!!
    Jun 2013
    Quote Originally Posted by OldHouseMan View Post
    I will have to check I'm not 100% sure how to tell the difference.
    I would rather not go the 9 mm QR option since I have a 9 mm thru axle now.
    Quote Originally Posted by texasnavy05 View Post
    For the price it is worth a shot.
    I talked to Chris King today and was told they don't plan on making a 9 mm thru axle conversion.
    SRAM XX1
    Mr. Buck E. Fikes
    Reputation: Oh My Sack!'s Avatar
    I run a CK 15mm TA on my Stumpy Comp with a Fox 32 Float 9mm and do so after buying an adapter from a great guy on ebaY for $20. No changing anything on the King hub, just slide the adapter into the thru axle. Use your normal skewer to hold it on. Works great!
    Mountain Bike 15mm thru Axle to 9mm Quick Release Wheel Adapter | eBay
    Jun 2013
    Quote Originally Posted by Oh My Sack! View Post
    Sweet that's what I needed.
    So this is just a sleeve that goes into the 15 mm hub ?
    I thought about having a machine shop making me one this is much cheaper.
    Thank You very much Oh My Sack
    MTBR never lets me down.
    SRAM XX1
    Mr. Buck E. Fikes
    No problem...just paying it forward. I found a nice DT Swiss hoop with a CK 15mm TA hub laced in that I couldn't resist owning. I came here to mtbr with the same question and found this ebaY seller.
    It's a nicely machined piece with 2 o-rings and the fit/tolerance is perfect. It has been working great for me.
    EDIT:
    He also has this unit if you're using a standard 5mm skewer...
    Mountain Bike 15mm thru Axle to Standard 5mm Quick Release Wheel Adapter | eBay
    Jun 2013
    Yes I saw that when I read his ad.
    Seem's strange Chris King wouldn't make this seem's simple enough can't be any harder than making hub's.
    I've got $399 in the new set of hub's 28 hole but I couldn't pass it up.
    So this $21 extra I'm still ahead of the game.
    Now just have to order Light Bicycle Carbon rim's pick my spokes and nipple's and for around $1,000 I will have a decent carbon wheel set IMO.
    Save's me $700 over the Roval SL's I was looking at.
    SRAM XX1
    Jun 2013
    My part from mtbtools on EBay came in today.
    Fit's nicely.
    <a href="http://s668.photobucket.com/user/PauLCa916/media/null_zps3889b2e9.jpg.html" target="_blank"><img src="http://i668.photobucket.com/albums/vv50/PauLCa916/null_zps3889b2e9.jpg" border="0" alt=" photo null_zps3889b2e9.jpg"/></a>
    <a href="http://s668.photobucket.com/user/PauLCa916/media/null_zpsbe873486.jpg.html" target="_blank"><img src="http://i668.photobucket.com/albums/vv50/PauLCa916/null_zpsbe873486.jpg" border="0" alt=" photo null_zpsbe873486.jpg"/></a>
    Now if I get a front fork that needs a 15 mm axle all I have to do is pull out the spacer.
    SRAM XX1
    Mr. Buck E. Fikes
    Perfect fit! I'm running the identical set up. Watching the webz for the right deal on red rear hub now.
    Jun 2013
    The guy I got this set of Chris Kings for $399 shipped said he had more when I got these.
    They are 28 hole thou.
    Let me know I can forward you his info if you want.
    SRAM XX1
    Mr. Buck E. Fikes
    Ping me via PM with that info. Thanks!
    Jun 2013
    PM sent
    SRAM XX1
  1. How to Tell Difference Between Chris King Front Hubs
    By BullSCit in forum Wheels and Tires
    Last Post: 02-12-2012, 02:39 PM
  2. Chris King 20mm Front Hub Bearing Removal
    By Freerider in forum Wheels and Tires
    Last Post: 11-24-2011, 01:24 PM
  3. *PAID FOR SPAM* 29er front wheel Chris King
    By need4gforce in forum Wheels and Tires
    Last Post: 02-18-2011, 01:14 PM
  4. Chris King front hub question...
    By Evo. in forum Wheels and Tires
    Last Post: 02-05-2011, 06:30 PM
